09-12-2003, 07:34 AM | #1 |
Member#: 5540
Letting off the gas at 3.5k rpm
I just got my STi within the last week and I have a couple of questions.
I am going through the breakin period and keeping it under 4k rpm, and trying to vary my engine and road speed as much as possible. When I am in 3rd or 4th gear (more likely 4th I believe), am at a little lower than 4k rpm, probably only going like 35-45 mph and I let off the gas...well I feel the car engine braking a lot. I'm not sure if this is a car term or not, but I feel like the car is "backing off" really hard. Kinda bogging down, but really just engine braking. Is this normal for the STi? Does it really like to be towards the higher rpm band? Does yours back off that hard? It's probably not as dramatic as I am making it sound, but I just want to know if it's normal. Thanks for any responses.
09-12-2003, 07:48 AM | #2 | |
Member#: 34388
Vehicle:04 WRX STi Black w/gunmetal |
But what about that exhaust/engine rumble... Isn't it delightful? |
09-12-2003, 08:34 AM | #3 |
Member#: 3568
NESIC
Vehicle:2019 BMW F22 M240i |
It could also be that even keeping it under 4000rpms, the car accelerates so fast that when you let off, you feel a drastic change in speed and the car isn't really engine braking as hard as you think.
-BrianK |
09-12-2003, 09:00 AM | #4 |
Member#: 5540
I actually had a '98 2.5RS before this, so I think I would be used to Subarus in general. But the STi is really a whole different kind of monster, so it may be that I'm just not used to it. And yes, I think it is about 400 lbs heavier.
And it's not really that I am accelerating and then suddenly letting off or anything like that. I'm just crusing at about 3500 or 3700 rpm and let off and then I feel it. I don't really think it's a problem. I just want to make sure it isn't. |
09-12-2003, 09:02 AM | #5 |
Member#: 25956
Vehicle:2004 STi white/gold |
it's just because you are in a lower gear. Do the same thing in fifth and I bet it doesn't "brake" as hard
09-12-2003, 09:07 AM | #6 |
Member#: 37205
RMIC
Vehicle:2004 STI WRB |
I have noticed this head snapping tendency. I attribute it to the extra sensitivity of the drive by wire throttle. You have to be very smooth with it, or sometimes it will snap at you like an angry pit bull. I realized that most of my problem is that I used to drive a car that I had to floor all the time. The STi will take you past 100 mph before you realize you are pushing a little too hard on the gas. It takes time to adjust, but it sure is worth it.
09-12-2003, 09:41 AM | #7 |
Member#: 5540
Thanks for the help and reassurances.
I guess I just need to get used to it. And become more in tune with the car. |
09-12-2003, 01:34 PM | #8 |
Member#: 393
Vehicle:2021 Tesla 3&Outback White & 99 Ducati 900ss |
mmmm. it does make a nice rumbly sound doesn't it....
09-12-2003, 06:25 PM | #9 | |
Member#: 42440
Vehicle:04 Impreza WRX STi Platinum Silver |
Re: Letting off the gas at 3.5k rpm
-st |
09-12-2003, 06:53 PM | #10 |
Member#: 43179
NWIC
Vehicle:2005 STi WRB |
What kind of ungodly gas mileage are you getting if you are
"cruising around @ 3700-4000 rpms"? Try running in the 1800-2200 rpm range, a little lag, but if you're going 25 mph in town, whats the big deal anyway. My engine slows quickly from 5500 rpms in second gear too, wouldn't you? hehe. Later tykes |
whirring noise when I let off the gas | alacrity024 | Transmission (AT/MT) & Driveline | 10 | 08-14-2007 07:10 PM |
power dip at 3.5k rpm? | engr | Engine Management & Tuning | 2 | 07-05-2006 11:02 PM |
Noise when I let off the gas | BlackRex05 | Service & Maintenance | 10 | 10-02-2004 11:21 AM |
Whats the deal with the power surge when you let off the gas? | Keith | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 05-17-2001 10:11 AM |
Weird winding noise when I let off the gas... | Siper2 | General Forum Archive | 12 | 12-09-2000 09:15 AM |
