09-11-2003, 09:18 PM | #1 |
Member#: 5700
Vehicle:2004 STI White |
WRX and STI questions!!!
can the parts from the 02' WRX fit to the STI??? i mean BOV, downpipe, exhaust, suspension and sway bar, etc......
09-11-2003, 09:22 PM | #2 |
Member#: 24569
South East
Vehicle:2004 Mazda RX8 Titanium |
from what I've seen, the only one you might have an issue with is the suspension......sifferent top hats and such...should be no prob at all with the exhaust
09-11-2003, 10:00 PM | #3 |
Member#: 5700
so is that means only suspension stuffs like coilovers, strut bars...... wont fit
what about sways bars, BOV and engine parts??? thx for all the helps |
09-11-2003, 10:10 PM | #4 |
Member#: 24569
South East
For the most part you won't have a problem with anything. If something doesn't fit *perfectly* I'm sure it can be adapted to fit.
sway bars>should work BOV>different TMIC, so I don't know if it will fit |
09-11-2003, 11:01 PM | #5 |
Member#: 40988
Vehicle:05 wrx silver |
curious, why would you want to put wrx parts on an sti? maybe the other way around!
09-12-2003, 12:03 AM | #6 |
Member#: 18928
South East
Vehicle:2002 jdm wrx v7/v8 inter/w Spec C roof vent |
Because if you already had a turboback on your wrx,you could switch it to your STI..say turboxs..Do you have a STI?
09-12-2003, 12:24 AM | #7 |
Member#: 524
Vehicle:04 STi White |
Some stuff fits, some doesn't.
For instance the 6spd tranny is wider than the 5spd so some downpipes don't work. Also the 04 seems to be slightly different in some of the heatshields for the exaust. Suspension is exactly the same mounting points for all 02+ imprezas. The rear top hats are different but the strut bolts to them the same, and the top hat bolts to the car the same so its a meaningless point. |
questions about wrx and sti seats | vortectoy | Interior & Exterior Modification | 6 | 01-14-2009 10:28 PM |
hello! trannie swap question with a wrx and sti | Theanimedude | Newbies & FAQs | 18 | 08-02-2006 01:25 PM |
Quick Question, need answer from both WRX and STI | buyos1717 | Electrical & Lighting | 1 | 04-21-2005 03:06 PM |
WRX and STi exhaust question.. | 2003forcefed | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 7 | 11-29-2003 02:10 PM |
