09-11-2003, 08:10 PM | #26 |
Member#: 19236
Vehicle:Axis GT35/40R STi Not back yet |
I did a little dyno research with a drop in/silencer mod vs a injen "type" CAI.
While the injen "type" CAI made 3-4 more HP than the drop in with silencer mod on the STi, this was mainly due to leaning the car out a little, plus the additional volume of air passing by the MAF made it work much harder. Due to the harsh effect on the A/F the MAF had, I went back to the drop in w/silencer mod until I can tune for the CAI with a slightly larger piping. If the APS is truly the same size as the stock MAF hosing diameter, then it would make sense that is a viable option. Just have to weigh the cost of a drop in vs the APS CAI and is it worth 3-4 HP? Just my 2c.
09-11-2003, 08:32 PM | #27 | |
Member#: 15059
Vehicle:2004 WRX STi 1991 TSi |
09-11-2003, 09:43 PM | #28 | |
Member#: 4764
TXIC
Vehicle:2004 STi sold :( forizzle |
09-11-2003, 09:44 PM | #29 | |
Member#: 4764
TXIC
09-11-2003, 10:46 PM | #30 |
Member#: 37581
Vehicle:2004 SZ55'd STi 375whp on 91/404whp on 95 |
To all the guys with the 65mm APS CAI on their STi's...where did you guys order them from?
-STiLL |
09-12-2003, 12:14 AM | #31 | |
Member#: 15059
09-12-2003, 12:18 AM | #32 |
Member#: 18928
South East
Vehicle:2002 jdm wrx v7/v8 inter/w Spec C roof vent |
I wouldnt mess with the intake..I know a friend putting down 353 hp with the stock intake on his wrx.
09-12-2003, 03:03 AM | #33 |
Member#: 17493
Vehicle:2004 STi Boring Blue |
HKS and Zerosports
I have the HKS Super Mega Flow intake with the Zerosports intake pipe. I have also done the intake silencer mod(cut off the lower portion of the silencer and sealed it with a piece of plastic to make it a u bend, ghetto but does the job). As previous people have said it sounds awsome. HKS seems the most common intake in the UK so I thought I'd give it a try. Absolutely no CEL's.
09-12-2003, 07:58 AM | #34 |
Vendor
Member#: 3600
Blitz SUS. Made 10 whp on a mostly stock WRX over a drop in filter. Made about 15 whp on my STi with just downpipe. Simply amazing. No other intake I've tried has done that.
09-12-2003, 09:20 AM | #35 | |
Member#: 37205
RMIC
Vehicle:2004 STI WRB |
09-12-2003, 10:28 AM | #36 |
Member#: 39224
Vehicle:04 STI Black |
I have the Apexi Gt-spec exhaust and he realitively unknown Apexi Power Intake with the air intake heatshield kit. No cels or apparent effect on gas mileage. It definitely sounds better and it definitely pulls harder. No proof though as I have not dyno'd the car nor have I installed my gauges yet.
Soon.... Apexi gauges and a hopefully a Godspeed downpipe when they get caught up..... George |
09-12-2003, 01:11 PM | #37 |
Member#: 19467
SCIC
Vehicle:04 WRX STi WR Blue - original owner |
any APS authorized dealer will carry the new 65mm intake.
see www.aps-wrx.com for list but if you must have a contact now: www.fi-systems.com (jason) phone in website. (texas) www.isrperformance.com (pam) phone in website. (So. Calif.) |
09-12-2003, 01:17 PM | #38 | |
Member#: 37581
Thanks again, -STiLL |
09-12-2003, 01:20 PM | #39 | |
Member#: 19467
SCIC
Upgrade intake and turbo back. (including headers) Upgraded turbo (maybe APS SR-50, or PE1820, or Shiv's new turbo) Upgraded injectors. STi lighweight 6MT Flywheel. I'm pretty darn sure that the High Flow intake will oversee some HP advantage over the stock paper-filter intake for this kind of mods. Also, regarless of tuning or not. Any High Flow intake will improve responsiveness of the car specially in the low end. So that by itself is well worth it. Once again, this applies when the MAF sensor does not get affected. |
09-12-2003, 06:04 PM | #40 | |
Member#: 42440
Vehicle:04 Impreza WRX STi Platinum Silver |
Feel free to correct anyone if I am way off base : ) -st |
09-12-2003, 06:06 PM | #41 | |
Member#: 42440
I just read in some crappy mag (can't remember which) that they removed the filter and threw it on the dyno and lost 8 HP. -st |
09-12-2003, 06:11 PM | #42 | |
Member#: 42440
09-13-2003, 09:58 AM | #43 | |
Visiting NASIOC Timeout
Member#: 40648
Vehicle:2004 STi Blue, of course |
Re: HKS and Zerosports
Ah yes, then you are also basically using no air filter. You want to check on filtering tests, man. I ran this filter on both my previous cars and you should SEE how black the engine oil gets at changes. A portion of all that extra crap that gets by the filter ends up in your oil. After seeing my oil sometimes I'd wonder how the car still ran... -Sporty |
09-13-2003, 10:59 AM | #44 | |
Member#: 19236
This condition can be corrected with ECU programing. To the point above, I know of a 02 WRX that is making 396 WHP on the stock box with a drop in. So if the stock box can support almost 400 WHP then I think it should work for most applications. |
09-13-2003, 11:46 AM | #45 | |
Member#: 42440
Thanks again, -st |
09-13-2003, 02:56 PM | #46 | |
Member#: 19236
Actually both. Its amazing even what a milimeter or two will do. |
09-13-2003, 04:19 PM | #47 | |
Member#: 42440
-st |
09-13-2003, 05:04 PM | #48 |
Member#: 13540
Vehicle:2006 MKV GTI Black |
One thing you guys seemed to not have tried, is cutting the front of the air box in the fender off (that butt ugly box at the bottom of the plastic intake hoses). This in effect sort of makes it not only a CAI, but a ram intake as well. Worked wonders on my WRX, and was way better than the MRT POD filter I was using.
09-13-2003, 05:04 PM | #49 | |
Member#: 39724
Vehicle:04 WRX STI Silver |
Re: Re: HKS and Zerosports
K&N intakes for STI and WRX. | MastroWRX | Engine/Power/Exhaust | 3 | 12-27-2004 08:16 AM |
FS: OEM CD Changer & Blitz SUS Intake for STi | Anonymouse20910 | Mid Atlantic Impreza Club -- MAIC | 0 | 07-21-2004 11:22 AM |
Intake for STI? | AoR STI | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 18 | 02-28-2004 06:32 PM |
Short Ram Intake for STI Question? | raytang_c | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 32 | 01-11-2004 01:04 AM |
awesome Intake for STi help | Hornda Owner | Car Part Reviews | 1 | 01-11-2003 07:35 PM |
