08-30-2003, 04:36 PM | #1 |
Member#: 12694
Vehicle:02 WRX/JDM EJ207RA Unabomber Eeee-thug |
Re: sti transmission cooler configuration
I would very much appreciate it if one of you lucky sti owners could please take a look and describe the six speed tranny cooler setup in your car. I believe the oil cooler is incorporated into the the bottom of the radiator. I would just like confirmation of this. A picture would speak a thousand words, hint hint.. I would love to know the route the oil lines take to get to the radiator. I have a six speed to be installed into my rex and I want to use the same setup as factory. I have a theory that the radiator used for the six speed is the same radiator used in the automatic trans WRX's.
Thank you, Tom..
08-31-2003, 09:43 AM | #2 |
Member#: 12694
Hello anyone ??
08-31-2003, 09:51 AM | #3 |
Member#: 8343
Vehicle:2005 2012 Jeep 2013 DGM BRZ |
I'd be interested in the factory setup as well. I made my own for my 6MT and have been using it for a few months. The parts for the factory one seemed to be way too much when sourced from Japan. Might be cheaper from the US though.
09-01-2003, 08:41 PM | #4 |
Member#: 12694
I feel like I'm begging for an answer here...
Could someone please look at the bottom of their radiator to see if there are two small rubber lines comming off the bottom of the radiator. This will help those that are doing 6 speed swaps in the future. I would just drive to the dealer and look but I'm over 40 miles away to the nearest one. So an answer would be most appreciated. Thanx, Tom |
09-01-2003, 10:23 PM | #5 |
Member#: 41762
International
Vehicle:04 STi in ur Floriduh |
Tom,
I don't think the transmission has an oil cooler- oil cooler for WRX = AT only STi = M/T only = no trans oil cooler it does have an oil pump and an oil tube that sprays oil on top of the gears instead of them being submersed in gear oil -engine oil cooler only I would post picts but I have no url to link them from- PM me with your email address, and I will email you all the info I have on the MT6- z |
09-02-2003, 12:10 AM | #6 | |
Member#: 12694
Japanparts.com use to carry a sti "6" speed oil cooler. They called it a cooler / radiator combo. Unfortunately they do not offer it for sale any longer. They said that sti is not making it anymore. It could be because they are offered as standard equipment on the six speed with front lsd option ??? Dunno. That what I am trying to find out. Thank you for offering to send pics by the way. Tom.. |
09-02-2003, 01:36 AM | #7 |
Member#: 41762
International
According to my STi marketing brochure, the 6MT has a transmission oil cooler.
But, according to my STi service manual, there is NO MENTION of an transmission oil cooler. Who should I believe?? their marketing department, or their engineering department who wrote the service manual?? I seriously don't think there's one on there! took a look and I only see the main inlet and outlet hoses to and from the block. I could be wrong though-anyone else?? Do I smell free gear oil cooler, compliments of Subaru- or maybe they'll buy them back like the Mazda rx-8's--Just kidding here's a ton of info on the swap though Also, I can still email the info I have on the 6MT-sans oil cooler this post is going crazy...I keep trying to post a link to i-club and it's changing it to nasioc! you have to copy the url below and paste it into your browser and delete the spaces between w w w. wrx MT6 swap intro w w w.i-club.com/forums/showthread.php?threadid=3540 swap part 1 w w w.i-club.com/forums/showthread.php?threadid=4487 swap part 2 w w w.i-club.com/forums/showthread.php?threadid=6146 if that doesn't work, go to i-club.com and do a search for "WRX MT6 swap" Last edited by z; 09-02-2003 at 01:56 AM. |
09-02-2003, 07:55 AM | #8 |
Member#: 12694
zavigm,
Yeah I am familiar with the technicals regarding the six speed. I've done my research prior to buying. Doing the swap will be no problem either. I am surprised that the USDM sti does not have the optional tranny oil cooler, especially when it is outfitted with a front lsd. Tom |
09-02-2003, 10:26 AM | #9 |
Member#: 8343
The only STi that comes with the oil cooler is the RA Spec C tarmac edition, of which very few are probably outfitted. The rally teams that use the 6MTs generally don't use them either, they just tie together the two lines coming out of the transmission.
09-02-2003, 10:55 AM | #10 | |
Member#: 12694
Anyways I have a plan which will be to use an auto WRX radiator which will work fine for my needs. The winters in Vermont are extremly cold and gear boxes don't like that so the coolant will work great as a warmer for cold start ups. Tom |
09-02-2003, 12:44 PM | #11 |
Member#: 41762
International
I just want to know why my STi brochure and other specs on different websites say that the STi comes with a 6MT with transmission oil cooler!
09-02-2003, 01:01 PM | #12 | |
Member#: 12694
Tom |
09-02-2003, 01:40 PM | #13 |
Member#: 8343
No, the majority of the JDM 6MTs I've seen do not have the transmission cooler. Of the 20 or so that I saw only 2-3 had the correct lines for the oil cooler. I'd guess if you had your sti on a lift it'd be easy to see where the lines go. I'm using a air-oil cooler setup with mine currently.
09-02-2003, 02:47 PM | #14 | |
Member#: 12694
By the way what type of cooler did you use ?, and are using a thermostat ? Where did you mount it ? Tom.. |
f/s oil cooler, diff/transmission cooler combo so cali 220$ | wesuri | Engine/Power/Exhaust | 12 | 02-12-2008 05:41 PM |
general question re: manual transmissions | Butt Dyno | Newbies & FAQs | 6 | 06-19-2002 10:59 AM |
spark plugs, oil coolers, transmission coolers, upgraded radiator, who has them? | ChristophWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 06-04-2002 12:48 AM |
Transmission Cooler?? | AC | Vancouver Impreza Club Forum -- VIC | 3 | 11-22-2001 06:36 PM |
Anyone install a transmission cooler? | lustreking | Legacy Forum | 2 | 07-16-2001 09:50 AM |
