08-30-2003, 03:58 AM | #1 |
Member#: 25247
TXIC
Vehicle:1999 Coupe L White |
Drivetrain issue.
One of the STi owners in town(not a online kind of guy), is having some problems.
At cold low speeds he can feel the front work or not work, front axles feel like they are locking or skipping. ?. Also when he backup the rear is making some clunking. He says that he noticed these changes about two days after he changed to Redline Shockproof Lightweight. He is also worried about the rear noise coming from jacking up the rear by the rear diff, he thinks he may have hurt the bushings. Let me if you guys have ideas. He is Blue/Gold no mods and about 6,5++ miles.
08-30-2003, 05:19 AM | #2 |
Member#: 5627
South East
Vehicle:06 WRX STi Black |
The rear diff is a jacking point for the chassis and as such shold not have caused any damage.
Redline themselves do NOT reccomend using the Shockproof in the WRX or STI. Instead run the Redline 75w90NS. The rear diff is a mechanical unit and as such does not need or want the extra slip addatives in the other oils. The NS is the Non-Slip addative formula and is waht both the rear, & front/center/tranny all require. --Matt |
08-30-2003, 01:12 PM | #3 |
Member#: 456
NWIC
Vehicle:2008 Forester XT Steel Gray Metallic |
Why did he change gear oil? Was there something wrong with the factory oil?
The rear clunking is normal if you are turning a tight corner (it is from the rear LSD). Glenn |
08-30-2003, 02:31 PM | #4 | |
Member#: 11316
Vehicle:1988 E30S52 DD S14VQ35 & S13KA racecarzz |
Re: Drivetrain issue.
08-30-2003, 04:40 PM | #5 |
Member#: 41507
Vehicle:2004 sti blue |
Not to be an alarmist,But after my dccd failure light started coming on,in the morning
after I started up the car and would back out of my driveway it started making this weird noise and feeling like two things binding together the noise and feeling was from the rear of the car.Later they told me it was likely the failure and it was going from manual to automode.It has been in the shop for repairs(replacing tranny/center diff).Matt also the car was going straight no turn,different noise then what you get when you make sharp turn(I heard that noise too). |
08-31-2003, 11:45 AM | #6 |
Member#: 25247
TXIC
Sorry to take so lost to respond, he had changed it because when he would shift into 4th and 5th gear near 6.8K rpms he would grind the gears go into gear. He said the redline cleared that up, however, the new issue popped up.
I will get him to change back to a regular SL-5 gear oil. |
08-31-2003, 06:14 PM | #7 |
Member#: 456
NWIC
Huh, my STi has not grinded (ground?) into any gear.
09-02-2003, 01:43 AM | #8 |
Member#: 25247
TXIC
I think he had worn out the gear oil/broke the oil down. With the new Penziol he has not had any grinding and the diffs are not making noise now.
09-02-2003, 01:44 AM | #9 |
Member#: 10334
Vehicle:91 RX7 LSx swap '09 CC 3.6 4motion |
grind...6spd? I have a 6spd (albeit JDM) and I CAN'T hurry the syncros on a upshift. I have tried. fwiw I am using NEO 75-90RHD |
2002 WRX Drivetrain Issue (Center Diff.) | bsbretly | Transmission (AT/MT) & Driveline | 13 | 05-06-2012 11:25 PM |
Merry Christmas drivetrain issue? | foxfireWRX | Newbies & FAQs | 8 | 12-25-2009 11:32 PM |
Drivetrain noise, pin-point issue? | QfactorRS | Newbies & FAQs | 2 | 02-22-2007 08:54 AM |
clutch/drivetrain issue | qwkwrx | Transmission (AT/MT) & Driveline | 3 | 01-28-2007 02:28 PM |
Somewhat "Unique" drivetrain issues... What should I do? | Kostamojen | Transmission (AT/MT) & Driveline | 10 | 05-13-2005 11:10 PM |
