09-11-2003, 12:44 PM | #1 | |
Member#: 8193
Vehicle:2008 WRX STI Blue |
ODBII output question
Does anybody know if there is a power and a tach signal on ODBII in a STi? I am looking into DL90 and there is an option for ODBII module for Porsche to pick these signals from there.
I am wondering if it will work on STi. Here is a page: http://www.cb-racing.com/logger-ordering.htm And this is a quote from my email: Quote:
09-11-2003, 01:34 PM | #2 |
Member#: 456
Vehicle:2008 Forester XT Steel Gray Metallic |
Most standard OBDII outputs are able to output a continous tach value, but it isn't a "signal pin" per se, you need to request it and decode the data.
However, you can find the tach signal on the ECU itself. As to power, the closest thing is "load" which isn't exactly the same, nor is it an absolute measure. To learn more about OBD-II and how it works, there is a pretty grognardy book from the SAE called HS-3000 which contains all the relevant specs. Glenn |
09-11-2003, 03:01 PM | #3 | |
Member#: 8193
Here is an additional response I got:
09-11-2003, 03:03 PM | #4 |
Sooby Guru
Member#: 1914
SWIC
Vehicle:2000 2.5RS w/ EJ22T swap and N20. gone. : ( |
I'm pretty sure every manufacturer puts a tach output in the standard OBDII plug. It is important for their techs when they are working on the vehicles. Whether it is a direct tach lead or a different signal that gets converted to a tach signal once in the Scan Tool though I don't know.
09-11-2003, 04:03 PM | #5 |
Member#: 456
I don't think the standard provides any "spare pins", I'd say it is all software.
09-11-2003, 10:52 PM | #6 |
Member#: 41762
International
Vehicle:04 STi in ur Floriduh |
EDIT: engine revolution (RPMs), no HP or torque-
Here's what the service manual has to say about OBD-II output: EN(STi)-25 ENGINE (DIAGNOSTICS) OBD-II GENERAL SCAN TOOL 8. OBD-II General Scan Tool A: OPERATION 1. HOW TO USE OBD-II GENERAL SCAN TOOL 1) Prepare a general scan tool (OBD-II general scan tool) required by SAE J1978. 2) Open the cover and connect the OBD-II general scan tool to data link connector located in the lower portion of instrument panel (on the driver’s side). 3) Using the OBD-II general scan tool, call up DTC and freeze frame data. OBD-II general scan tool functions consist of: (1) MODE $01: Current powertrain diagnostic data (2) MODE $02: Powertrain freeze frame data (3) MODE $03: Emission-related powertrain DTC (4) MODE $04: Clear/Reset emission-related diagnostic information (5) MODE $06: Request on-board monitoring test results for non-continuously monitored sys-tems (6) MODE $07: Request on-board monitoring test results for continuously monitored systems (7) MODE $09: Request vehicle information Read out the data according to repair procedures. (For detailed operation procedures, refer to the OBD-II General Scan Tool Operation Manual.) NOTE: For details concerning DTC, refer to the List of Di-agnostic Trouble Code (DTC). <Ref. to EN(STi)-66, List of Diagnostic Trouble Code (DTC).> 2. MODE $01 (CURRENT POWERTRAIN DIAGNOSTIC DATA) Refers to data denoting the current operating condition of analog input/output, digital input/output and/or the powertrain system. A list of the support data and PID (Parameter Identification) codes are shown in the following table. NOTE: Refer to OBD-II general scan tool manufacturer’s instruction manual to access generic OBD-II PIDs (MODE $01). EN-01163 PID Data Unit of measure 01 Number of emission-related powertrain DTC and malfunction indicator light status and diag-nosis support information — 03 Fuel system control status — 04 Calculated engine load value % 05 Engine coolant temperature °C 06 Short term fuel trim % 07 Long term fuel trim % 0B Intake manifold absolute pressure kPa 0C Engine revolution rpm 0D Vehicle speed km/h 0E Ignition timing advance ° 0F Intake air temperature °C 10 Air flow rate from mass air flow sensor g/sec 11 Throttle valve absolute opening angle % 13 Check whether oxygen sensor is installed. — 15 Oxygen sensor output voltage and short term fuel trim associated with oxygen sensor V and % 1C Supporting OBD system — 24 A/F value and A/F sensor output voltage — and V 34 A/F value and A/F sensor current — and mA Hope this helps z Last edited by z; 09-11-2003 at 11:41 PM. |
09-11-2003, 11:36 PM | #7 |
Member#: 40671
Vehicle:2006 STI, Outback XT Grey, Blue |
Hi RafalW,
Let me know what you find out - I have a DL90 and would like to get this data as well. Thanks Ray |
09-11-2003, 11:50 PM | #8 |
Member#: 40671
Hi,
I just went through the schematics. There is no easy way to get thengine speed out of the computer. The Tach and Speedometer information is derrived locally (in the instrument cluster) from some data - probably digital in nature sent to the instrument cluster from the ECU. I am unable to tell what kind of signal currently drives this. Also, best I can tell, none of the spare OBD II pins carry any useful information. Ray |
09-12-2003, 12:14 AM | #9 |
Member#: 456
Typically there are tach and VSS (speed) signals going to the cluster from the ECU. The ECU is the most convenient place to get at them.
09-12-2003, 12:38 AM | #10 |
Member#: 41762
International
OBD II reads the engine revolution (aka Tach, aka RPMs)
Similar Threads | ||||
AEM UEGO analog output question | twinturbo_z | Newbies & FAQs | 3 | 01-16-2010 08:40 AM |
stock td04 output question. | PSolbergfan | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 13 | 05-30-2007 10:36 PM |
Engine output question | watsonsd | Newbies & FAQs | 3 | 11-08-2006 10:34 AM |
ODBII Cable Question?? | SnowmanFX | Engine Management & Tuning | 4 | 10-16-2005 10:29 PM |
TEC2 / OBD2 output question | R Diamond | Technical Forum Archive | 0 | 06-23-2000 10:38 AM |
