Tire & Wheel Forum sponsored by The Tire Rack |
01-21-2003, 11:47 PM | #1 |
Member#: 456
Vehicle:2008 Forester XT Steel Gray Metallic |
wheels that will fit over the STi brakes
(copied from IWOC) at the moment there aren't a huge range of wheels which will fit. Prodrive do a couple of wheels in an 18 inch size. One is a OZ 10 spoke WRC/P1 style wheel, which is available in a matt gold colour, or silver. There is also a 7 spoke alloy called the PFF7, which is a lightweight wheel using the latest flowforming technology. This is available in gold, silver or bright flitter (actually like a pweter/metallic anthracite colour). Speedline also sell the Turini model in an 18 inch wheel which will fit. THis again uses the flowforming technology to make the wheels both lightweight and strong. The OZ Superlegarra wheels will fit in the 19 inch size, but unfortunately not the 18 inch size. Other than the standard 17 inch rims which come with the car, I'm not aware of any other 17 inch rims which will clear the STi Brembo calipers without using spacers (which I wouldn't recommend). ~~~~~~~~~~~~~~~~~~~~~~~~ (copied from IWOC) I spoke with OZ and Speedline recently, they are aware of the STI calipers issue and the modified 17 Superleggera (OZ) and Corse (Speedline) in gold will be released shortly, especially for the STI7-8. They should be available in europe until the end of first quarter, for the same price as the 17s for the WRX. ~~~~~~~~~~~~~~~~~~~~~~~~ |
01-22-2003, 12:13 AM | #2 |
Member#: 4024
Vehicle:2004 impreza WRX STi World Rallye Blue |
Man... what kind of rims we have to use for winter tire ? 18'' ???
01-22-2003, 12:31 AM | #3 |
Member#: 456
The JDM STi 17" rims would be a good choice.
01-22-2003, 12:59 AM | #4 |
Member#: 4024
That's not very cheap for a set of rusty wheels...
01-22-2003, 08:57 AM | #5 |
Member#: 4109
Vehicle:2005 STI WR Blue w/Gold |
The Volk CE28N should fit over the Brembos fine since they're spec'd on the s202 which has the same brakes if I'm not mistaken.
01-22-2003, 09:12 AM | #6 |
Member#: 10821
Vehicle:2008 WRB STi |
damn, if the stock 17s are the winter wheels, then summer wheels + tires package (running 18s) will be around $2k+. Oh wow...
01-22-2003, 09:29 AM | #7 | |
Member#: 14112
Vehicle:2002 wrx wagon 2010 STI DGM |
thanks Glenn - STi information guru mitch |
01-22-2003, 09:57 AM | #8 |
Member#: 6120
Vehicle:BE5B AVOed B4-RSK Sorta White |
A few that are OK...
These fit - in 17"x 7.5" ET48: WedSports RS-5SS-TSSCs - strong, light and pretty reasonably priced, at least over here.
As do these in 17x8 ET44: Volk CE28N - another strong, light weight wheel (as seen on the S202). Cheap? - er, no... Volk has a load of other wheels that fit too... but lots of small print suggesting that some will and some won't among the same range - quite confusing. Then there are these: Tommy Kaira rims... edit to fix a link |
01-22-2003, 10:14 AM | #9 |
Member#: 4374
Vehicle:2017 BRZ PP |
since some 17s fit, it seems as though the overall diameter isnt the issue, its the wheel spokes clearing the caliper that is the problem.
A good place to start would be the wheels confirmed to clear the stoptechs. I am willing to bet most of those will clear the STi brembos as well |
01-22-2003, 10:14 AM | #10 | ||
Member#: 456
01-22-2003, 10:17 AM | #11 |
Member#: 2184
Vehicle:2005 Legacy GT wagon Platinum Silver Metallic |
The P1s don't clear?
Kevin |
01-22-2003, 11:28 AM | #12 | |
Member#: 768
Vehicle:OB, volt, 911, ram 1500, 1098s, m620 |
Re: A few that are OK...
01-22-2003, 01:06 PM | #13 |
Member#: 8351
Vehicle:2002 WRX Wagon |
I am hoping to use my 17 inch UK rims for winter. They are supposed to fit over stoptechs, so here's hoping they will fit. I'll let you know as soon as my STi gets here...
I believe they used gold versions of the silver UK rims on the old STi v7 wagons (didn't v7 get the Brembos?), so I think they'll work. TRS |
01-22-2003, 01:26 PM | #14 | |
Member#: 456
Glenn |
01-22-2003, 04:02 PM | #15 |
Member#: 5886
Vehicle:2006 Outback 2.5I Black/Black |
i was curious about this as well. what happens if you want to hit the trails? 17 is a bit large and they'd be getting dinged pretty bad. or am i the only one that would be sliding around in the dirt with one?
01-22-2003, 04:26 PM | #16 |
Member#: 31656
I've looked at this site:
reay engineering wheels And a good portion of the wheels have specific notation of which wheels and offsets will fit over which size calipers. STi specific calipers in fact, as well as GTR, Supra, etc. The most interesting thing I've seen was a setup for autocross recommending 17x9.5 in the front and 17x8.5 in the back but with a 255/40/17 on both rims, this for the STi GD. Big Meats! BTW, that last was from the Racing Hart cp-035 fitment page. |
01-22-2003, 04:32 PM | #17 | |
Member#: 5886
01-22-2003, 05:33 PM | #18 | |
Member#: 5960
Vehicle:FXT 11.6@118 93 oct NSX 450 whp SC'd (93 oct) |
#1 UK 17x7 5 split-spoke, which I have a set of in silver #2 Overseas gold 17" 5 spoke STi 7 rims. BTW, please do confirm whether your UK's fit. My set is for sale, and they'd be perfect for some STi owner out there, since my car is now retired. I have some great pics of my car with the UK's, I should post them online. |
01-22-2003, 06:42 PM | #19 | |
Member#: 456
Glenn |
01-22-2003, 07:23 PM | #20 |
Member#: 6120
To add to Glenn's comment:
The UK WRX 17" wheel (which was originally the Legacy B4 and GT-B wheel, but superseded a while back), and the JDM STi Wagon (RIP ) 17"s are one and the same, just painted gold (and the STi wagon missed out on the Brembos, among other things). These wheels most certainly do NOT clear the Brembos. The UK STi 17" and the JDM STi 17" (in fact that is the std. STi wheel around the world) are one and the same. The 9 spoke BBS 17"s are part of the optional pack for the STi here that includes RE070 gumballs - and it looks as though the US is going to see that combination too. They are not identical to the bugeye STi RA Spec C wheels - some detail work was done to stiffen them at the model update. Phew, hope that doesn't over inform y'all. As I said there are lots of wheels that do clear the Brembos, you just have to be a bit careful Keep on enjoying the run up to the release |
01-22-2003, 08:05 PM | #21 |
Member#: 19471
i would really like to keep my volks, and then sell the bbs wheels, so would anyone know if volk le-37k's fit, 17x7.5 48+ ? if so ill keep them and put them on.
03-18-2003, 02:49 PM | #22 |
Member#: 13182
Vehicle:1987 White/Black "Panda" Levin AE86 |
From the looks of the Ray's Engineering site, its seems as though the Gram Light 57Pros in 17x8 +40mm(?) offset will clear the STi calipers. Can either of my 2 favorite B4 owners confirm or deny this? I can't say I am a huge fan of the 10 spoke Spec C wheels, and I have always loved the Gram Lights, so it would be great if they did fit.
If they don't, JDM STi 5 spoke here I come. dan |
03-18-2003, 05:00 PM | #23 |
Member#: 456
The Spec C BBS forged wheels are absolutely top-drawer. Very stiff and reasonably light.
03-18-2003, 05:43 PM | #24 |
Member#: 5946
Does anyone know if ROH Azzuro's in 18's will fit?
03-18-2003, 06:24 PM | #25 | |
Member#: 21618
SCIC
Just a guess: use an appropriate car? --scott |
Similar Threads | ||||
? on 16in Wheel that will fit rear 04 STI | WRX 2002 | Tire & Wheel | 3 | 02-24-2005 02:16 AM |
What's the smallest wheel that will fit on the WRX? | Tattoo Collector | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 12-07-2003 01:33 PM |
WTB: cheap winter wheels that will fit over brembos (STI) | sweetsuby | Private 'Wanted' Classifieds | 5 | 10-23-2003 10:51 PM |
17" Rota wheels that WILL fit over STi brakes... | maengelito | Tire & Wheel | 2 | 10-14-2003 10:39 PM |
What wheels will fit over the sti brembo brakes? | D-I-Z-Z-L-E | Brakes, Steering & Suspension | 7 | 07-07-2003 07:53 PM |
