Brakes & Suspension Forum sponsored by The Tire Rack |
12-04-2022, 11:31 PM | #1 |
Member#: 17911
Vehicle:2002 WRX Platinum Silver Metallic |
2018 Wrx Performance Pack Brake Pads?
Hi, own a 2018 WRX with the Performance Pack. It came with red calipers and upgraded brake pads. I believe they are Julian(?) pads which I assume are the same pad material used on Bimmers (sure create enough black dust like a BMW pad). Are the red calipers and pads the same dimensionally as a standard limited wrx caliper/pad? I would like to change them to Akebonos (half the price subaru wants for red caliper replacement pads). Thanks.
12-07-2022, 01:13 PM | #2 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
Just looking at pictures online, and based on the description of what the Performance Pack is, the calipers appear to be the same as non-PP WRXs, they're just painted red. That same caliper has been used by Subaru on all sorts of models, dating all the way back to 2005ish, so there should be tons of pad options available - take a look on rockauto.com and you'll find some Akebono options and many others.
According to cars101.com, the pad manufacturer is Jurid. There are plenty of brake pads that create lots of brake dust, so I'm not sure why dusty = Bimmer pad compound , but that's neither here nor there. What part number were you able to find for the Jurid PP pads? |
12-07-2022, 01:52 PM | #3 |
Member#: 11554
Vehicle:2018 STI RA World Rally Blue #225 |
Might want to look at ACT 1078A for the front..........
ACT 1114A rear with manual parking brake ACT 1808 rear with electric parking brake Last edited by Barry; 12-07-2022 at 01:59 PM. |
12-07-2022, 02:26 PM | #4 |
Member#: 17911
Subaru part number for the Jubid front pads is 26296SG011 according to SubaruParts.com.
12-07-2022, 02:27 PM | #5 |
Member#: 17911
Subaru part number for the Jubid front pads is 26296SG011 according to SubaruParts.com. I like ceramic Akebonos based on past experience with them.
12-28-2022, 03:34 PM | #6 |
Member#: 532648
Vehicle:2018 wrx white |
hey man i have a question for you, i have the exact same car as you, do you have any problems where when you start slowing down the brakes start screeching noise? i had them when i got the car and the noise went away, this time when i changed my brakes i got 4 brand new rotor and pads and its still making that noise. im hoping either you and someone on here can help me out with this noise on my wrx
12-28-2022, 03:35 PM | #7 |
Member#: 532648
brakes
12-28-2022, 10:39 PM | #8 |
Member#: 17911
Never had a noise problem with the Jurid brake pads. I special ordered my wrx, not sure if yours would be any different than mine if you bought yours off the lot. Bought new rotors (centric) and pads (akibono) for the fronts. When I have a chance to install them, I'll let you know if there is a noise problem. Did you grease areas called out in the subaru maintenance manual for brake installs?
01-06-2023, 04:36 PM | #9 |
Member#: 17911
Finally found the time to change the front brake pads and rotors. Working fine, no screeching noise. Might want to look at the caliper pad retainer springs being bent during install. Also, the brake pad spring clips are supposed to be at the bottom of each pad. I could see someone easily bending the caliper springs and hitting the rotors during braking getting a screeching noise. Hope this helps.
