10-16-2003, 06:26 PM | #1 |
Member#: 24827
Vehicle:2008 Kia Spectra |
Extracting ball joint from knuckle
How on earth am I supposed to remove the ball joing from the knuckle? Any tips? I removed the bolt that pinches the knuckle around the ball joint, but I can't for the life of me get the ball joint out of the knuckle!
10-16-2003, 09:23 PM | #2 |
Member#: 24827
Someone?
10-16-2003, 09:29 PM | #3 |
Member#: 13110
NESIC
10-16-2003, 09:33 PM | #4 |
Member#: 24827
Ball joint seperator? Hmmm, ok any other ideas?
10-16-2003, 10:22 PM | #5 |
Member#: 28716
SCIC
Vehicle:2006 STI |
I take it you have the knuckle off the car and are changing out the ball joint? Not sure on Subarus but they're usually pressed in so you have to use a hydraulic press or hammer it out.
If you're trying to separate the knuckle from the lower arm you're better off removing the castle nut and undoing it from there. |
10-17-2003, 12:20 AM | #6 |
Member#: 24827
Knuckle is off the car and seperated from the lower control arm already. Just need to remove the ball joint from the knuckle. There is no way to get at the top of the ball joint (except through a tiny slit in the knuckle). So I either have to pull on the ball joint, or pry it somehow. I just don't have the proper prying tool to do it easily (a ball joint seperator may do the trick). I've gotten the ball joint pulled out about 2mm but it won't go any further. It is loose enough to spin freely in the knuckle, but won't budge any further when I try to pull on it. I was just curious if there was a special "Subaru" procedure or tool to aid in removal.
10-17-2003, 02:09 PM | #7 |
Member#: 23547
Vehicle:13 Focus ST Blurple |
If its off the car, take it to your mechanic or the dealership.
10-18-2003, 08:48 AM | #8 |
Member#: 7089
NWIC
Vehicle:2016 STi |
Replace the lower control arm - you don't need to torque down the castle nut, but get it snug.
You now have a lever arm to tap on - tap downward on the lower control arm and the ball joint will come out. |
10-20-2003, 12:39 AM | #9 |
Member#: 23751
Vehicle:2003 Passat W8 Wagon Reflex Silver |
The pickle fork that Karl suggested above wouldn't work ?
10-20-2003, 02:01 AM | #10 |
Member#: 24827
I dunno, I haven't tried. Just looking for ideas before I go renting tools.
10-20-2003, 01:21 PM | #11 |
Member#: 30727
South East
Assuming your car has the same suspension setup as my two older Subies, just pop the knuckle off the balljoint and take a tie-rod fork lever and slide it in between the top of the balljoint and control arm and start pounding them apart. Your car is fairly new, so you shouldn't have to fight 16 years of corrosion and heat settlement like I did on my XT
10-20-2003, 10:25 PM | #12 | |
Member#: 28716
SCIC
Vehicle:2006 STI |
I would try what Austin suggested, that's a great idea. If you want to get ghetto, you can put vice-grips on the end of the ball joint and hammer on it which is kinda the same principle. |
10-22-2003, 07:52 AM | #13 |
Member#: 4817
NESIC
I don't know if this applies to Subarus, but on my MR2 the procedure is to use a gear puller and basically force the ball joints out with that. I plan on picking one up soon to do just that, and my WRX may be next, since it seems to be wandering excessively on the highway already, even though it's only got 40,000 miles
10-23-2003, 01:32 AM | #14 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
Here's what I did. YOu need a decent flat screwdiver that starts thin and gets fat after about 1/2 inch. And you need another thin screwdriver. And a hammer.
I am assuming that you have everything exposed. You want to hammer the larger screwdriver into the slot. If you look at it you'll know. You do need to remove that bolt first. YOu don't need to beat it in there too much, You just want to spread it apart a bit. leave that sucker in there. Now take the smaller screwdriver and slide it in past the bigger one and pop that ball joint out of there. You should be able to wedge it out enough to get the tip of the screwdriver under that lip and with a little effort, out she comes. These are not concise and perfect directions, but once you start trying it you should be able to get the gyst of what I meant. It took me about 3 hours to figure out how to do it the first time. And I could do it in about 30 seconds now. Good luck |
10-23-2003, 02:16 AM | #15 |
Member#: 24827
Thanks tim. I did try beating it out with a screw driver from above. I didn't think of wedging a screwdriver in the slit to expand it. I figured it wouldn't expand much.
I did end up getting it removed tonight. The method I used was using two pickle forks. I wedged em on the spindle part of the ball joint and wacked on the forks. And I had to wack the HELL out of it! See illustration: |
10-23-2003, 04:04 AM | #16 |
Member#: 21977
NWIC
Vehicle:2002 WRX Wagon Blue (again) |
dude, it's such a bear that when I got mine out, I saved one to remind me how hard it was.
10-23-2003, 10:08 AM | #17 |
Member#: 6436
Vehicle:1998 Impreza 2.5RS BDP |
crazy
This is crazy. The proper tool is available for about $15 and is often available to borrow for free from local auto parts stores. No banging, no damage. Easy, 5 minute job.
For example: http://www.jcwhitney.com/webapp/wcs/...&storeId=10101 |
10-23-2003, 11:35 AM | #18 |
Member#: 24827
I can't figure out how this tool would work on the Subaru knuckles. If you look at em, you'll see what I mean.
10-23-2003, 11:47 AM | #19 | |
Member#: 6436
Sorry
10-28-2003, 03:39 AM | #20 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
air hammer it out of the knuckle and press the new one in
10-28-2003, 10:30 AM | #21 |
Member#: 17252
Vehicle:'06 WX8 59E |
That tool should work for removing the threaded end of the joint from the control arm.
10-30-2003, 08:24 PM | #22 |
Member#: 18589
SCIC
Vehicle:2002 WRX, Formerly it was blue |
Having just replaced my clutch, which involves removing these lower ball joint "knuckles" from the housing, so the front drive shafts can be removed from the transmission. Here is what I did:
I removed the bolt that holds the ball joint knuckle in place on the housing. I disconnected the sway bar from the housing. After a bunch of fiddling, I pulled out my Nylon and Rubber Mallet, and hammered down on the lower A arm. The lower A arm turns out, has about another 15 degrees it can drop. The knuckle then came right out of the housing. I didn't have to hit the lower A-arm that hard, just a couple of firm whacks. Now I live in So. Calif. so there is no road salt and other non-sense. I didn't have to try and pry open the slot that the bolt closes up or anything else. If I wanted to remove the ball joint completely, after that (from the lower A-arm), I would then just hammer it out (after removing the castle nut). A lot of folks appear to have never removed a Subaru lower ball joint. It is not bolted in, nor pressed into the housing (hub). The ball portion fits into a hole that is then compressed when the housing bolt is in place. Most of the tools that everyone has been showing and referring to are for separating the ball joint shaft from say an A-arm. BTW Getting the knuckle back into the hole was a bit of a trick with just one person. I had to pull the A-arm down fitting the rubber that wanted it to go back up, and then try and level out the knuckle, so that it would slide into the hole without tilting and jambing (very similiar to compressing a brake slave piston back into the caliper. |
10-31-2003, 02:45 AM | #23 |
Member#: 24827
Mine were really rusted in the housing, that's why it was so hard to get em out. I did get em out though. The first one via the method I showed above of brute force. The second, I decided to try the screw driver and it worked.
I took a fat flathead screwdriver. Starting from the bottom of the slit, I hammered it up into the slit, spreading it apart. Then the ball joint came out with a minor bit of tugging. I cleaned the rust buildup from the housing, and the new b-joints slid in like cake. Inserted the bolt and tightened down to torque. Ball joints are securely mounted. Now the knuckles are back on the car, resting atop the new forged alluminum control arms w/ anti-lift kit. Yum! |
10-31-2003, 02:48 AM | #24 |
Member#: 24827
Now I just need to order the Tarmac struts, STi trailing arms, and STi 6-piece lateral links. Then my suspension upgrades will be complete.
10-31-2003, 03:23 AM | #25 |
Member#: 6551
suby-you didn't need to removed the axles, there's room to get them off w/o removing the axles.
Jeremy |
Trick for getting the ball joint out of the knuckle? | ValpoFz | Brakes, Steering & Suspension | 4 | 12-29-2009 06:46 PM |
04 wrx clucking on left turns from passenger side, ball joint? | killa996 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 11-27-2009 07:25 AM |
snapped ball joint/knuckle bolt. safety questions | todeswalzer | Brakes, Steering & Suspension | 7 | 11-07-2009 08:36 PM |
oem ball joints vs moog ball joints | ROC pit-bull | Car Part Reviews | 2 | 07-14-2006 11:21 PM |
outer tie-rod-end or ball joint? | driver | Brakes, Steering & Suspension | 4 | 02-27-2002 10:48 AM |
