09-16-2020, 11:21 PM | #1 |
Member#: 500179
Vehicle:2017 WRX |
Grimmspeed 3 port EBCS Boost Spiking (2017 wrx)
Hey guys, I'm in the process of getting and E tune and I'm running into the problem of boost spiking even though I have a 3 port grimmspeed ebcs.
Any suggestions on troubleshooting other than the tune (which is locked by my tuner) https://photos.app.goo.gl/pn81rUR37buQgvGJA
09-17-2020, 09:19 AM | #2 | |
Member#: 486921
NESIC
Vehicle:2018 Outback Tungsten |
Can you post your data logs? |
09-17-2020, 09:36 AM | #3 |
Member#: 480524
Vehicle:2015 WRX Black |
09-17-2020, 11:08 AM | #4 | |
Member#: 500179
Vehicle:2017 WRX |
https://drive.google.com/file/d/1hen...ew?usp=sharing |
09-17-2020, 12:38 PM | #5 |
Member#: 424692
Vehicle:2015 WRX WRB |
You should upload the data to datazap, allow the data to be available to the public, and post the link in this thread.
09-17-2020, 03:33 PM | #6 | |
Member#: 500179
Vehicle:2017 WRX |
https://datazap.me/u/thenumb55/s?log=0&data=10-30 Last edited by TheNumb55; 09-17-2020 at 03:39 PM. |
09-17-2020, 04:24 PM | #7 | |
Member#: 486921
NESIC
09-17-2020, 04:30 PM | #8 |
Member#: 500179
Vehicle:2017 WRX |
09-17-2020, 06:18 PM | #9 | |
Member#: 486921
NESIC
That being said I wouldn't call that a spike, thats your turbo being fully spooled and your car regulating the maximum boost. Notice how its pretty flat throughout the rest of your rev range as it begins to taper at the higher RPM. The stock WRX turbo isn't that big but its very efficient being a twin-scroll. Older turbo cars tended to have a big lag where the turbos wouldn't fully spool or produce max boost until the end of the RPM range and you'd get a huge surge in power. |
09-18-2020, 09:43 AM | #10 | |
Member#: 500179
Vehicle:2017 WRX |
So do you think that small overboost is just a tuning issue then? |
09-18-2020, 10:02 AM | #11 |
Member#: 486921
NESIC
Well from some of the other recent threads about boost spikes and the like it seems to happen for a few different reasons however it doesn't seem like your car is exhibiting them. I'm not a tuner but it totally could be tune related.
09-18-2020, 10:02 AM | #12 |
Member#: 453427
Vehicle:2017 WRX Crystal White Pearl |
Boost curve looks a bit wacky, I would discuss this with your tuner and ask them what the boost target is set at and if the creep up to 21psi in the 4000ish range is intended.
You don't have any boost parameters logged so we can't really tell if this is intentional or not. https://datazap.me/u/thenumb55/s?log...30&zoom=97-445 |
09-18-2020, 10:14 AM | #13 |
Member#: 448185
Vehicle:2016 WRX DGM |
I fail to see what the issue is here. Looks fine. An EBCS operates at a set interval. IDK what the "refresh rate" (for lack of a better term) is of the Grimmspeed unit, but it actuates X (20-30?) number of times per second. That is going to give it an inherently spiked appearance because it can never be fully smooth. That's what a peak and a valley are in your boost chart. You can actually count ~25 peaks and valleys on your datazap between 3 and 4 seconds if you add time into the chart.
I do not think it's really an over boost issue. The turbo was just more efficient at that RPM range between the refreshes in your EBCS. Also, that "over boost" at 3370 RPM is so minuscule, I wouldn't even call it that. |
09-18-2020, 10:17 AM | #14 |
Member#: 424692
That all looks pretty normal to me. If you really want to see if it is, log commanded boost and compare it to your actual boost to see if you are overboosting by a significant amount.
09-19-2020, 06:38 PM | #15 |
Member#: 500179
Vehicle:2017 WRX |
My tuner (iaTuning) says that the thing to check is for a boost leak and a faulty BPV.
"Since the stock EBCS is not available, and the boost curve’s dip remains, then here are ideas of how to proceed. Perform a Boost leak test and verify the BPV is not leaking prematurely." I guess his concern may be that the boost drops down after the initial "spike" I'll datalog target boost tonight. |
09-19-2020, 10:24 PM | #16 |
Member#: 503820
I have kind of the same problem on my 2011 Wrx. For me at target boost of 20psi I just keep build boost to cut off 24psi. I have the same tuner IA Tuning Stephen Clark. He did not help me at all. Said it was my new turbo. So I’m still having this problem.
I’m interested in the bpv as I put a brand new one on and this problem started. If you figure it out let us know. |
09-19-2020, 11:22 PM | #17 | |
Member#: 500179
Vehicle:2017 WRX |
I'm very much tempted to just drive up to chicago next week to get a pro tune lol |
09-21-2020, 09:26 AM | #18 |
Member#: 453427
I have a stock BPV and do not have this boost issue, I understand the logic that it could be a boost leak, but I doubt there is faulty hardware if the boost ramps up and stays somewhat stable as it does later in the pull.
09-21-2020, 11:15 AM | #19 |
Member#: 480524
09-21-2020, 04:28 PM | #20 |
Member#: 453427
