11-08-2019, 06:50 PM | #1976 | |
Member#: 420856
11-08-2019, 07:05 PM | #1977 |
Member#: 419593
That HAS to be a troll post. Please tell me that was a troll post. PLEASE!
11-08-2019, 07:17 PM | #1978 |
Member#: 395275
RMIC
Vehicle:2012 STi SWP |
Haven't changed my oil in 12k
doing 145 in 5th gear on the highway. blows engine Sounds like nasioc all right |
11-08-2019, 07:38 PM | #1979 |
Member#: 504042
SCIC
Vehicle:2018 WRX ISM |
I feel like a lot of 15 and 16 in here. FA20DIT was so new back then that Subaru must have messed it up for the first 2 years.
11-08-2019, 08:10 PM | #1980 |
Member#: 423270
Vehicle:2015 WRX (sold) |
11-08-2019, 08:28 PM | #1981 |
Member#: 480524
Vehicle:2015 WRX Black |
11-08-2019, 11:18 PM | #1982 |
Member#: 460907
RMIC
Vehicle:2020 Golf GTI |
11-11-2019, 02:14 PM | #1983 | |
Member#: 431550
Vehicle:2016 WRX ALL THE STAGES |
You take care of it and chances of it sploding drop significantly. Keep in mind my personal situation is at stage 1. A lot of people went stage 2 and then blow up relatively low mileage stock blocks. |
12-21-2019, 12:15 PM | #1984 |
Member#: 436423
Model/Year:15 WRX
Milage:85,000 EM: OEM Mods: None Fuel: 93 Oil: Dealer changed Circumstances: Car has lived an easy life, I just use it to drive to and from work - buzz up and down the highway. A day prior to it breaking it seemed to be down on power as I pulled on to the highway but not not so much that I gave it a second thought. The following morning I was caught in a traffic jam and moved maybe 500 yards in 45 minutes. When traffic broke I took it up to a decent speed, something I don't normally do. About 5 minutes after, power was coming and going and the motor developed a horrid knock. The oil light came on as I pulled off the highway and shut it down. The car is at the Subaru dealer and they are working up an estimate to tear it down. That knock sounded expensive. Any advice on this situation is appreciated. I feel I'm screwed no matter what though. |
12-21-2019, 05:38 PM | #1985 | |
Member#: 416873
NESIC
Vehicle:2015 WRX |
12-21-2019, 07:58 PM | #1986 |
Member#: 427632
TXIC
Vehicle:2011 Impreza WRX Satin White Pearl |
Lol stage 2 is more efficient power-wise.
12-22-2019, 11:46 AM | #1987 | |
Member#: 431550
Personally blown blocks that i know? what does that matter lmao anecdotal evidence... sure. I know 3 local FA20DIT that blew at stage 2. Why? They drove like the typical tard --- high load/low revs & generally abusing the car. |
01-02-2020, 02:27 PM | #1988 |
Member#: 501446
Vehicle:'15 WRX gone plaid |
Model/Year: 2015 WRX
Mileage:63k, didn't do any mods 'til at 52k EM:Bren E-Tune Mods:Turboback, Cobb CAI, TGV delete, EBCS, BrenTune Fuel:Chevron/Shell 91 only Oil:Mobil 1 Full syn Circumstances: E-tune for TGV delete. No knock showing while running new map, then tons of knock about 2min after one 3rd gear pull to redline, while cruising back to town. Map was solid, pull log looked great. Actual engine failure: Piston 1 Ringland failure, oil on sparkplug, etc. Mechanic I'm working with doesn't think the failure has anything to do with mods/pull. Going to be building a new short block up. Not sure if I'm going to buy an assembled Crawford or build up one with tuner out here. Waiting on bid estimate. |
01-02-2020, 03:30 PM | #1989 | |
Member#: 477489
Vehicle:2018 WRX Limited CWP |
Man, that's rough. How bad were the knock readings after the pull? Bren have any insights as to what might have caused this?
Good luck. Quote:
01-06-2020, 09:01 PM | #1990 | |
Member#: 501446
Knock readings were in the mid-teens. Last edited by SnoBrrru; 01-15-2020 at 10:03 AM. Reason: Didn’t answer question |
01-13-2020, 06:27 PM | #1991 |
Member#: 330601
BAIC
Vehicle:2014 Forester 2.0XT White |
How about a Forester?
Model/Year: 14 Forester 2.0XT Milage: 88xxx EM:Stock Mods: Stock Fuel: Good ol' California 91 Oil: 5w30 Pennzoil Synthetic every 5k miles (or less if I don't drive it for a while, it's a backup car we use for trips only) Circumstances: Severe knock, misfire on cylinder 3, no power Actual engine failure: Piston skirt on cylinder 3 broke, looked like the crankshaft counterweights have been rubbing on the block for a long time. Contacted SOA about it but I'm probably ****ed. Anyone seen piston skirts break like this? I got a used engine out of a wrecked Forester and it had the EXACT SAME FAILURE! I'm not sure which cylinder failed in the used engine but we happened to drop the oil pan and noticed a piece of piston sitting in it almost the exact same shape. Now I'm waiting for the THIRD engine from these guys... No car for almost a month so far. |
01-13-2020, 09:29 PM | #1992 | |
Member#: 480524
01-14-2020, 08:10 AM | #1993 |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
Had it happen to our FA WRX. Check for a very slightly bent rod.
The markings you see on the block are likely factory clearance machining for the crank. If the crank actually contacted the block, you'd know it!! It's common to mistake this machining for rubbing as it's not the prettiest of finishes. |
01-14-2020, 10:05 AM | #1994 | |
Member#: 431550
01-15-2020, 11:02 PM | #1995 | |
Member#: 330601
BAIC
The car has displayed an odd surging and very occasional misfire in the past but it never set a code. When the rod knock started it was very sudden. I posted pics on subaruforester.org in an engine failure thread I started. I did find it amazing that one of the bad engines I got from the wrecker had an identical piston fragment in the pan. The yard swore the engine ran perfectly before they pulled it and urged me to install it anyway. I politely declined. Last edited by aliveoutofhabit; 01-15-2020 at 11:12 PM. Reason: Typo |
01-16-2020, 05:08 PM | #1996 |
Member#: 330601
BAIC
Here are some of the pics I posted over at subaruforester.org
01-17-2020, 03:53 PM | #1997 |
Member#: 504227
This is probably the most depressing thread on any forums I've been apart of and I have been on and off car forums since 2000 haha. I see failures of this motor happening with bad driver mods/bad tuning knowledge (especially in the beginning when it first came out )/getting passed around to multiple owners/poor maintenance. I feel like I need to start a more uplifting thread like '15+ successful WRX motor tuning roll-call' seriously ...
01-17-2020, 04:10 PM | #1998 | |
Member#: 452248
Vehicle:2017 Base WRX WRB |
See here https://forums.nasioc.com/forums/sho....php?t=2756819 |
01-17-2020, 04:10 PM | #1999 | |
Member#: 453427
Vehicle:2017 WRX Crystal White Pearl |
01-22-2020, 09:29 PM | #2000 |
Member#: 418964
Vehicle:2015 wrx blue |
and here is a not broken yet.
WRX 2015 270hp - DAM dropped to 0.812 three months ago and never reset. Timing must have been pulled significantly and there were no knock events, during that period. Reflashed back to 91 recently and all looks normal so far, DAM holding at 1.0. Will be seeing tuner soon as a service is due. Last edited by dogtrumpert; 01-22-2020 at 09:37 PM. |
