11-09-2018, 11:00 AM | #1776 | |
Member#: 10605
NESIC
Vehicle:2015 WRX Crystal White Pearl |
11-09-2018, 07:10 PM | #1777 |
Member#: 488173
Vehicle:2018 WRX Black Silica |
Is it just me or does it seem like an abnormally large amount of 15s are the ones with majority of the engine issues? I haven't seen a terrible amount of 16+
And yes I realize that these are still newer years and don't have the miles on them yet, but I am sure there are plenty of people who are putting quite a few miles on them |
11-09-2018, 07:18 PM | #1778 | |
Member#: 419593
11-09-2018, 09:27 PM | #1779 |
Member#: 411169
Vehicle:2015 WRX Lightning Red |
11-10-2018, 01:52 PM | #1780 |
Member#: 488173
11-12-2018, 06:15 AM | #1781 |
Member#: 493932
Model/Year: 2016 WRX Premium 6MT
Mileage: 27000 miles on the first, 30000 on the second (about 52000 miles on chasis. Mods: intake, j pipe, 3" exhaust, ebc, tgv deletes, verticooler, chargepipe, bov, cobb flex fuel kit, Cobb Accessport with protune from snail performance. About 310whp 330lbs on pump 91 and 360whp 380 lbs on a e55 blend. (Both motors) Fuel: flex fuel Oil: Motul 5w-40 on the first, Mobil 5w-30 on the second, OEM filter. Changed every 3000 miles. Circumstances: Daily-driven with mostly highway miles. Every part was installed and tuned for, the only time the car was driven without a proper tune was with a base map sent by my tuner driving my car to the shop to get dynoed. On the first motor I was passing a car 2nd to 3rd pull then after passing the car I started to hear the knock, drove it home (about 2 miles from where it happened) spun a bearing. Oil levels were good but I guess I didnt warm the car enough ***128546; also I had just done a oil change 700 miles prior to the incident (07/23/2017)***128148;***128148; Got a new stock motor dropped in and ran perfectly till about last week (11/06/2018)***128148; again passing a car on my way to work doing about 70 (car was warm,oil levels good, 1200 miles on the oil, oil temp was at about 195°), this time I didnt hear it right away but I'm assuming that's when it happened, i didnt pass any more cars then nor did i beat on it, just cruised to work bumping some linkin park....it was until I pulled up to work to park that I heard someone knocking, which was strange since I wasnt home so who could it be!? Sure enough I "pop the hood" (ff line) and bam I found where that knocking was coming from, the rest of the day all I can think of was my baby was hurt "I tried so hard but in the end it didnt even matter" my block was done***128557;***128557; got it towed home when I got off, checked the oil and found out who was knocking inside my block, it was tinker bell!!! How do I know this? Well she left all kinds of fairy dust in my oil***128548;. Well now my car is at the shop waiting on this IAG stage 3 block to come in so we can get it back on the road. This car has been nothing but headaches ***128557;***128557;***128148; Last edited by Suubroo; 11-12-2018 at 06:20 AM. Reason: Spell check |
11-12-2018, 11:46 AM | #1782 | |
Member#: 116557
NESIC
Vehicle:2016 WRX 6MT Ice Silver Metalic |
Sounds like you beat on the car and you're expecting a LOT more hp and tq from a STOCK motor. Plus perhaps questionable oil choices too.
11-12-2018, 12:26 PM | #1783 |
Member#: 391748
NESIC
Vehicle:2015 WRX CWP (sold) 2019 STi CWP |
11-12-2018, 12:56 PM | #1784 |
Member#: 492861
Vehicle:18 WRX Stg 2 tuned Silver |
I would disagree with the "questionable oil choices."
11-12-2018, 12:56 PM | #1785 |
Member#: 492861
Delete, double post
11-12-2018, 03:19 PM | #1786 |
Member#: 460907
RMIC
Vehicle:2020 Golf GTI |
So if the car has been nothing but headaches with an OEM block is the plan to give yourself an aneurysm going the IAG stage 3 route?
11-12-2018, 03:37 PM | #1787 |
Member#: 459394
Vehicle:2015 WRX Crystal White |
Every time this thread gets bumped, I open it with a little anxiety. Then I read what happened and I instantly feel better.
11-12-2018, 03:40 PM | #1788 |
Member#: 419593
11-12-2018, 04:12 PM | #1789 |
Member#: 391748
NESIC
11-12-2018, 04:36 PM | #1790 |
Member#: 476596
Vehicle:2015 WRX |
I would recommend you invest in a quality air oil separator while getting the new engine. There is a lot more blow by with flex fuels which could be dumping oil into your intake ultimately lowering your octane and causing pre-detonation.
11-27-2018, 08:02 PM | #1791 |
Member#: 494553
Hi! Been lurking for a while, this is my first post....
Model/Year : 2015 WRX Limited 6 speed Mileage : 49,xxx EM : OEM Mods : Stock Fuel : 93 Sunoco Oil : Valvoline 5w30 that for turbo motors stuff Circumstances : In 2nd gear, made a bending left turn into a street at about 2500-3000 rpms, easily accelerated maybe 15% throttle and poof, instant death, dash got really blinky and that was that. Couldn't find anything that night but there was a puddle of oil underneath. Sounded catastrophic. Actual engine failure : Dealer says con rod snapped but hadn't disassembled motor yet. Already telling me I'll most likely be getting a new long block. Bought the car like 2 months ago. Had some part that controlled the variable valve system replaced a week in.... was burning up oil. Then a month ago the dash lights were going nuts and when i gave it throttle it went on the fritz. Subaru dealer found a spark plug electrode had broken or burnt off. They replaced the plugs. Now this. We've (Wife and I) wanted a bug eye back in the day. Due to kids and life just now got around to buying a used 2015. My wife wanted the car and the salesman wouldn't stop telling us how his friend owned it and took really good care of it... it was clean.... Last edited by Cdroid; 11-27-2018 at 08:10 PM. |
11-27-2018, 10:57 PM | #1792 |
Member#: 494535
BAIC
Vehicle:2016 WRX Pearl White |
Engine failure at 24000 miles
While accelerating onto the freeway at 40 mph I blow a rod on my stock 2016 WRX. The rod was sticking out of the top of my engine. I am now learning that this is becoming a common thing for the 15-18 year models. I was completely shocked that something like that happened to a car that was only two years old. Has anyone heard anything about the lawsuits that have been popping up?
11-28-2018, 08:02 AM | #1793 |
Member#: 424692
Vehicle:2015 WRX WRB |
An old friend of mine who was a tech for his whole life for different manufactures always told me this: "a used subaru (or evo, or any "sports car" for that matter) is an abused subaru"
I really wanted a bug/blob eye wrx as my first car and he talked me out of it. Bought my 2015 brand new and its been reliable for me so far (76,000 miles with 70,000 of it tuned). Who knows what mods/maintenance/abuse previous owner(s) did to the car. And always remember, a salesman will tell you anything to make a sale. Sorry to hear about the issues and now a blown motor. I hope you can get it all fixed and replaced under warranty. Then you'll know you have a fresh motor and you can maintain and drive it the way you want. Last edited by alapilusa; 11-28-2018 at 08:03 AM. Reason: added current mileage |
11-28-2018, 03:52 PM | #1794 | |
Member#: 494553
Say SOA replaces my motor, is there a new type of warranty with said motor? |
11-28-2018, 05:07 PM | #1795 |
Member#: 393629
W. Canada
11-28-2018, 05:42 PM | #1796 |
Member#: 494553
11-28-2018, 07:39 PM | #1797 |
Member#: 494535
BAIC
Since my motor was rebuilt and not replaced, Subaru told me it was just a contiuation of my existing factory warranty.
11-29-2018, 02:45 PM | #1798 |
Member#: 481524
It seems to me...and I'm completely and utterly a noob in the subject of mods...that once someone starts pushing 300 whp and above, they're beating the crap out of their engine. From what I've read, the connecting rods can't handle much more than 100-115 per. Correct me if I'm wrong.
11-29-2018, 03:25 PM | #1799 |
Member#: 481524
Update on mine...
I have a 2015 WRX Base
Roughly 33,500 miles, give a little (possibly in the 33,600 range). Try to get oil changed every 3,000 miles, though I'm a bit late on that, currently. Low mileage, relatively speaking, because I usually choose to live close to where I work. I can honestly say I haven't experienced any issues, yet (knock on wood). I am also considering doing some initial, low-risk mods. Should I go through with this, or wait until the warranty passes? Or is it worth it, in general? I keep seeing these posts about bearings/connecting rods failing, and it seems to be a building theme (or maybe I'm just paranoid). I'm considering doing the Cobb AP plus their intake for the Stage 1 setup. Then maybe doing the Grimmspeed top-mounted intercooler. |
11-29-2018, 03:35 PM | #1800 | |
Member#: 494553
