Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 08-07-2015, 12:34 PM   #51
Bryan82
Member#: 346731
2015 WRX
Ice Silver
Compression test while you're in there then. If that's good, guess I would suspect gummed up injector.
Bryan82 is offline   Reply With Quote
Old 08-08-2015, 07:52 PM   #52
2015WRX
Member#: 389290
2005 WRX STi
#Sabo1886 What symptoms did your pump have when it started to go?
2015WRX is offline   Reply With Quote
Old 08-08-2015, 07:53 PM   #53
2015WRX
Member#: 389290
2005 WRX STi
Originally Posted by Sabo1886 View Post
Hi guys, I'm on my second HPFP using E85 and I know many of you have had pump failures do to lack of lubrication of factory pump and a 30% increase of pump. Does anyone know if any manufacture is working on making an E85 compatible high pressure fuel pump? I was one of the first E85 WRX back in June of 2014 and two pumps in one year total. If anyone has any solutions please let me know!
Old 08-12-2015, 07:00 AM   #54
Nisstrust
Member#: 255202
Any help with an adjustable fuel pressure regulator for those maxing the hpfp side of the fuel equation?
Nisstrust is offline   Reply With Quote
Old 08-13-2015, 01:02 AM   #55
arghx7
Member#: 232940
It sounds like you are thinking about a port fuel injection system with the normal 4-6 bar fuel pressure. Direct injection high pressure fuel pumps have an adjustable fuel pressure regulator built into them (the spill valve or whatever term you want to use). The ECU controls that.
arghx7 is offline   Reply With Quote
Old 08-13-2015, 01:21 PM   #56
2015WRX
Member#: 389290
2005 WRX STi
Default E85 DI high pressure fuel pump
Originally Posted by Bryan82 View Post
Have you pulled the plug to look at it?
Problems solved. Had zero to due with e85. Apparently when you install your TGV's there isn't supposed to be wires pinched fix wasn't cheap with labor but it's all good now.
Old 10-03-2015, 10:41 PM   #57
2015WRX
Member#: 389290
2005 WRX STi
Bump for any more info on this important info. I keep hearing that Clark's cars aren't having problems. I'm wondering if he was able to figure oh the tuning parameters while others are struggling. I'm still having partial surging at times. Pressure rockets up over 2500psi and then the pump goes crazy. About to throw in the towel on E.
Old 10-04-2015, 11:08 AM   #58
anjuna
Member#: 401977
IDFK Wat
bish whet
Are you using the fuel lubricant?
anjuna is offline   Reply With Quote
Old 10-04-2015, 12:02 PM   #59
WRXINTX
Member#: 96712
Has anyone contacted APR (huge vw high performance parts supplier) about upgrade parts for the Subaru DIT pump?
APR has a good rep in the VW community and they sell upgraded pumps and kits for all kinds of HPFP.
WRXINTX is offline   Reply With Quote
Old 10-04-2015, 09:58 PM   #60
2015WRX
Member#: 389290
2005 WRX STi
Yes, Lucas ethanol treatment. My suspicions are content related. It's tested on a few occasions around E90. I'm debating if a E50 or 30 mix would be easier on the pump internals. From my understanding the system would not need to worry about increases in demand, yet offer the knock abilities of E.
Old 10-04-2015, 10:00 PM   #61
anjuna
Member#: 401977
IDFK Wat
bish whet
Oh see I'm not using the e treatment one. I'm using the one that specifically says conditioner and fuel lubricant. It's cheaper, thicker, and I haven't had issues.
Old 10-04-2015, 11:16 PM   #62
Harey
Member#: 270569
'15 Foz XT & GT86
Yes obviously the less % of ethanol in the fuel the less amount of fuel that is required.
Anything over ~E35 will give you the same power/knock benefits. Above that is really just whatever is easier. E42.5 seems pretty popular as you add even amounts of 93 and E85 each time you fill up.
Harey is offline   Reply With Quote
Old 02-18-2016, 06:54 PM   #63
outbackwrxxx
Member#: 378862
2015 WRX
Ice silver
Sorry to revive an old thread but what are the symptoms of a failing HPFP? my car is bucking real bad when cruising and fuel pressure is dropping below 40psi. no knock at all, everything else looks fine. Dealer isn't helping this time so im on my own :/
outbackwrxxx is offline   Reply With Quote
Old 02-18-2016, 06:58 PM   #64
2015WRX
Member#: 389290
2005 WRX STi
If you haven't run pump gas thru it in a while do so. What is your high pressure actual reading? You can compare that to the target. I had many issues on full E. A blend is best if you ask me. 50 percent worked flawlessly.
Old 02-18-2016, 07:00 PM   #65
2015WRX
Member#: 389290
2005 WRX STi
If the pump gas doesn't fix it you'll likely need a new HPFP. If your falling to 40psi your not HPFP is fried. My car had a couple of episodes but cleared up after some tune adjustments.
Old 02-18-2016, 07:13 PM   #66
outbackwrxxx
Member#: 378862
2015 WRX
Ice silver
ive been running e85 for close to 10,000 miles without running ANY 93. i will definitely fill up with 93 when im empty.
Old 02-18-2016, 10:21 PM   #67
2015WRX
Member#: 389290
2005 WRX STi
Get that fuel out of there asap. Some guy had a similar problem on the forums. That's far to long to run E in the car. It's better to cycle gas thru at least every 5 tanks or so. E is an excellent fuel but some fuel starts to gum up. This isn't a new issue with E and DIT cars. Better to play it safe.
Old 02-18-2016, 10:44 PM   #68
boxterWRX
Member#: 416278
I ran 8k then had problems on a clark tune it's a dw65 too so your saying if I run back to e85 I should be good again just cycle?
boxterWRX is offline   Reply With Quote
Old 02-19-2016, 04:04 AM   #69
jerryscherry
Member#: 381213
2015 WRX - BASE -CWP
Crystal White Pearl
darn i was so set on the e85 route. didn't know full e85 caused problems with the pumps.
jerryscherry is offline   Reply With Quote
Old 02-19-2016, 10:19 AM   #70
2015WRX
Member#: 389290
2005 WRX STi
If you run E85 to long it can cause a sticky substance on the injectors and fuel pump. This is a common problem running ethanol for some reason. There are theories out there about why it's happening but it's prevalent in the mazdaspeed3 community.
Old 02-19-2016, 01:28 PM   #71
arghx7
Member#: 232940
Saab did a study on E85 deposits back in the day, as they were leaders in flex fuel during the mid 2000s. Basically you have to cycle regular E0/E10 in there after a while to clear the crap up. There isn't any other way to get rid of it.
Old 02-19-2016, 02:07 PM   #72
jerryscherry
Member#: 381213
Crystal White Pearl
so basically gotta cycle some 91 in there once in a while. I plan to get cobb's flex fuel kit for the 15+wrx when it comes out, although im concerned about the HPFP seizing up after reading through this thread.
Old 02-21-2016, 12:19 PM   #73
ManuelG
Member#: 401785
2015 WRX w/2JZ
Is anyone on Clark's tune having any problems? Seems like no one who's tuned by Clark is. I've been running straight E85 with the Lucas conditioner for 14,000 miles with no problems on his tune.
ManuelG is offline   Reply With Quote
Old 02-21-2016, 01:33 PM   #74
boxterWRX
Member#: 416278
I was on a clark tune but I'm also Catless fmic and cai so that might be a factor I used Lucas ethanol treatment on every tank lasted about 8k gonna try the switch back
Old 03-09-2016, 12:14 PM   #75
outbackwrxxx
Member#: 378862
2015 WRX
Ice silver
Turns out my fuel pump sock got blown off somehow
all is well now. I took your advice and refilled with a full tank of 93 to just clean everything out. How to i go about switching back to e85? Would it be ok to run it low, fillup with e85 then let it idle on the 93 map to pump out fuel in the lines? or is it a must that i manually drain the tank fully?
