Old 03-15-2010, 10:17 PM   #1
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
Default normal operating temp ??
Ok
i have a darton sleeved 2.5l ej257 block. i notice that when i am stopped at a long light or slow traffic i see my temp gauge start to jump. so i plugged in my ap and did the live data to see the coolant temp. The highest its gone is 208 and the fans turn on and cool it down but at 207-208 the needle on the gauge is 3/4 the way up. i am trying to figure out if it my gauge cluster or what the deal is. When i drive on thre freeway or drive it hard the temp gauge never moves. any imput would help
edit. also running a mishimoto radiator with anti freeze mixed with water and water wetter
blkwagon is offline   Reply With Quote
Old 03-16-2010, 12:57 AM   #2
801_STi
Member#: 200756
07 yellow clearbra
swp sti "Pearl"
thats pretty high..
not like OMGMYCARSGONNABLOW but its up there.
normal is like 180-190 range. depending on whats done to the car etc etc.
801_STi is offline   Reply With Quote
Old 03-16-2010, 01:17 AM   #3
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
well the fans dont kick on until 205-207 from what ive notice....im not losing any coolant...i tested a 07 sti with a ap and when it idles temps reach 207 the fans kick on and it cools down but the temp needle never moved
Old 03-16-2010, 01:42 AM   #4
Gixxer1K
Member#: 81631
I installed a Crucial thermostat and it seems to make allow me to idle longer before the temp starts its climb and also cool back down a lot quicker once I start moving
208 stopped isn't abnormal, I'd be more worried if it was 208 while you are moving above 40 mph on a cool day
Gixxer1K is offline   Reply With Quote
Old 03-16-2010, 04:24 AM   #5
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
You can set the fans to turn on earlier...
What fans are you running? Stock fans?
If you have aftermarket fans there is a low and high speed on the factory fans.
Old 03-16-2010, 05:18 AM   #6
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
187~189 considered normal..
just get after market aluminum radiator.
Old 03-16-2010, 11:31 AM   #7
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
I am using stock fans. And also already running an aftermarket radiator. This could be me over paranoid but I wanna get it right before summer hit.
Old 03-16-2010, 11:36 AM   #8
jays05
Member#: 78165
05 STI 35r + e85
Try a crucial 160d thermostat. Also with Romraider you can make the fans kick in earlier. I changed mine to kick the fans in 10f earlier than stock.
jays05 is offline   Reply With Quote
Old 03-16-2010, 11:43 AM   #9
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
So can I use rom raider to adjust the fans with out screwing up my tune?
Old 03-16-2010, 11:50 AM   #10
jays05
Member#: 78165
05 STI 35r + e85
As long as you're not making them kick in at like 140f... I think you are fine to make them kick in 10-20 degrees earlier.
Mine looks like this. I just took 10 degrees off across the board.
Old 03-16-2010, 12:04 PM   #11
blkwagon
Member#: 102857
RHD sedan sti swap
high on meth
Cool. I give it a shot. Thanks
Old 05-13-2010, 12:31 AM   #12
emsmap
Member#: 159334
AP3,PPG, BW S256
Hey guys. I just replaced my radiator with an Mishimoto with stock fans. I also replaced my thermostat. My water pump has only 20,000 miles on it. I made sure there is no air in the system also. When I am cruising, I am hitting 210 degrees without giving it boost or anything. I am stumped on what it could be. I have tryed everything I can think of. I got in my UTEC just to make sure my gauge wasn't fooling me and sure enough, I am running 210F while cruising normal. Checked headgaskets and they are fine also. My car is a 2002 WRX making 300whp
emsmap is offline   Reply With Quote
Old 09-15-2020, 10:02 PM   #13
jcwike
Member#: 451930
2015 WRX STI
Lapis Blue
I am having this exact issue also, I was having heat problems now I am on a closed deck block. I would hit 220° on the regular and if I hit a red light it would hit 230° and I would have to stop to let the car cool as it would barely run. I installed a mishimoto triple row radiator and I have not gotten over 215°. Wanting the car to run cooler I installed mishimoto fans, liquid chill coolant, upgraded thermostat that is 5-10° cooler, and killer bee elbow at the thermostat housing and my coolant temps cruise at 198-208 and if I get into it it quickly comes back down to that range. What do I need to get this under 190?
jcwike is offline   Reply With Quote
Old 09-16-2020, 09:35 AM   #14
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Guys, if your car is over heating at a light or light/normal driving, installing a aftermarket rad will not do dick. The issue is not with the rad. List of issues:
1)air bubble in your lines
2)Bad thermostat
3)Bad sensor
4)Low or old coolant
5)Head gasket
6)Wrong rad cap or mixed up with the 2
Old 09-16-2020, 10:44 AM   #15
Jedi03
Member#: 491095
2009 STi Blue
normally operating temp should be between 195 and 220...most vehicles dont turn on fans til 220, this is best temperature for complete combustion and emissions...the lower temp thermostats will jsut allow for more water flow at lower temperatures...the guage showing that high would likely be a bad temp sensor...in a few vehicles i have seen resistance issues and an in line resistor has corrected it...
Jedi03 is offline   Reply With Quote
Old 09-22-2020, 04:21 PM   #16
mobysti
Member#: 518562
Ok
Have a built ej with a mishimoto radiator and it sits around 200. Perhaps a bit high but it runs great.
mobysti is offline   Reply With Quote
Old 09-22-2020, 07:29 PM   #17
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Make sure you're using an OEM water pump or something that works. We've had the impeller wheel come off the pulley on a Gates one. We went to OEM waterpumps after that.
Old 09-25-2020, 12:02 PM   #18
subaru_gc8
Member#: 29292
2004 WRX wagon
dont hink you can use both the cobb and opensource at the same time
Old 09-25-2020, 12:07 PM   #19
BeastianSTI
Member#: 310506
2005 WRX STi
CGM
Yeah, that's right; also ... since Cobb made changes to their licensing and deprecated ATR, your tuner would need to make the change.
Closed deck block here. I don't think my tuner has the fans kicking on until 205. I'd say if you see anything over 220+ then it's cause for concern.
BeastianSTI is offline   Reply With Quote
Old 09-28-2020, 08:22 PM   #20
jcwike
Member#: 451930
2015 WRX STI
Lapis Blue
2)Bad thermostat
3)Bad sensor
5)Head gasket
Okay, update... I installed an aftermarket tbw performance skid plate and cut my bumper for air flow through the front end. I think the huge ets was adding more heat to the cores behind it and not getting enough air flow, my temps are now in normal range and the car cools back down to operating temp quickly. I just replaced thermostat, have new coolant, and no air in the system from what I can tell.
Old 02-10-2022, 08:38 AM   #21
02wagster
Member#: 528680
I have a mishimoto perf radiator and thermo im running at 160-175 is that too cold
02wagster is offline   Reply With Quote
Old 02-10-2022, 10:18 AM   #22
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Sparkly
Yes. The car can run richer than needed at lower temps (below 160). Run a normal thermostat.
The normal operating temp of most Subarus is between about 175-207. Anywhere in there and you're fine. Bad things don't really happen until you go over about 240 degrees of coolant temp
Old 02-17-2022, 06:42 AM   #23
Guston7
Member#: 494898
Default Yes
I agree with Subydude, that is too cold. I hear a lot of people wanting their engine to run cooler. Some think the lower the temp, the better. You obviously are not one of them since you asked the question. Modern (syn)oil and engines from what I gather are working optimally at around 200 degrees.
Guston7 is offline   Reply With Quote
Old 03-28-2022, 12:08 AM   #24
ThatSubaruSTI
Member#: 529423
Ok
Mine is around 180-190 and my tuner set fans to be kicked on at 195 range.
ThatSubaruSTI is offline   Reply With Quote
Normal Operating TEmp jt0thevizzle Newbies & FAQs 8 11-26-2008 10:17 AM
normal operating oil press & temp??? Drink Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-14-2006 05:21 PM
Normal operating temps for a processor? shemoves Off-Topic 8 06-09-2006 03:48 PM
What's normal operating temp? Egan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-09-2003 02:22 AM
Normal Operating Temperature? freq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-06-2002 02:29 PM
