Old 09-05-2020, 06:23 PM   #1
xbcaraudio
Member#: 76912
2002 WRX MT
WRX RALLY BLUE
Default Closed Deck Cooper Oring + MLS gasket!
Hello ! I'm just starting to puzzle and engine build know , and i would like to do it right at once !
Looking wich route to take to max out my GTX3076R.82 gen 1 with all the supporting mods !
Route # 1 Oem MLS ej257 gasket + cooper oring on top ?
Route # 2 JE PRO seal + cooper oring on top?
For both setups would you recommended 1/2 , 13mm or 14mm studs?
I know the IAG fire lock its the ultimate head gasket setup to date but I'm looking other options that proven to work
Thanks in advance to point me in the right direction!!!
xbcaraudio is offline   Reply With Quote
Old 09-05-2020, 09:01 PM   #2
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
I had 14mm studs, JE pro seal, Copper Oring for 45k miles at 38-40psi with perfect compression before my GSC valvespring broke it is definitely a set up that works
user1029 is offline   Reply With Quote
Old 09-05-2020, 10:37 PM   #3
xbcaraudio
Member#: 76912
2002 WRX MT
WRX RALLY BLUE
Great to hear that ! Without doubt it works for you !
Old 09-06-2020, 10:07 AM   #4
xbcaraudio
Member#: 76912
2002 WRX MT
WRX RALLY BLUE
Anyone that can share with us your recommendation or experience?
Thanks !
Old 09-08-2020, 02:14 PM   #5
collin2ps
Member#: 462314
I didnt go the copper oring route. However, i am using the JE/Athena fire ring gasket with 1/2 studs and have had no issues 45psi 750whp, 20 plus track passes and 2k miles of street driving.
collin2ps is offline   Reply With Quote
Old 09-08-2020, 06:23 PM   #6
xbcaraudio
Member#: 76912
2002 WRX MT
WRX RALLY BLUE
Great to know that your setup it's holding fine 45psi ! JE/Athena fire ring gasket with 1/2 studs !
A poll will be great to decide which route to take Nowadays!
Old 09-10-2020, 12:22 PM   #7
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
I'd go RCM 14mm studs, JE pro seal/Athena, Copper Oring.
Athena also makes a fire-ring style headgasket. JE supposedly sells it now.
Old 09-10-2020, 06:35 PM   #8
xbcaraudio
Member#: 76912
2002 WRX MT
WRX RALLY BLUE
Sounds like a great setup for sure!
Old 09-20-2020, 04:07 PM   #9
xbcaraudio
Member#: 76912
2002 WRX MT
WRX RALLY BLUE
Has anyone tried cooper oringed oem block with mls gaskets & std ARP 2000 to 35psi with success?
Thanks !
Old 09-20-2020, 10:20 PM   #10
user1029
Member#: 57064
2008 STi IAG built
Thanks !
ARP 2000 is the weakest, I would go at least ARP age 625 for anything above 30psi. I wouldn't go higher than 35psi even with those ARP 625 bolts because the higher boost pressures would rip the threads out. If you want higher boost pressure then you need to do IAG 14mm studs where they actually redrill new threads to accommodate the 14mm bolts
Old 09-25-2020, 11:58 AM   #11
BeastianSTI
Member#: 310506
2005 WRX STi
CGM
I'm running a GTX3576 with the JE Proseal gaskets. I didn't end up upgrading my head studs beyond the ARP2000s, so .... boost is capped to 30 PSI.
For 93 octane, my tuner limited boost to ~25 PSI, and then on e85 it's limited to 30.
I know a local shop that has had good luck running the ARP age 625s with the IAG firelock gasket. They were able to push 38-40 PSI if I recall correctly.
BeastianSTI is offline   Reply With Quote
Old 09-25-2020, 12:04 PM   #12
BeastianSTI
Member#: 310506
2005 WRX STi
CGM
I think if I had to upgrade, I'd go Firelock with 14mm heads studs. I'd have IAG do all the machine work so there'd be no issues.
I don't think it's worth it to do copper o-ringing nowadays, given the availability of the firelock setup (just a personal preference I guess).
