06-21-2005, 08:05 PM | #1 |
Member#: 25478
SCIC
Vehicle:2003 WRX Sport Wagon PSM |
Motor Mount Bolt Location
I'll be doing an UP install very soon - can someone tell me where the passenger side motor mount bolt is located? I've searched to no avail....
A picture would help even more...TIA!
06-21-2005, 08:09 PM | #2 |
Member#: 89385
Vehicle:many most all WRB/blk/blk/blk/slvr/wht |
There is a motor mount crossmember that spans the width of car btwn frame rails. It is a stamped steel, shaped plate. In a channel on either side of car is a 14mm bolt. Thats all there is holding your motor in! (Well, except it is bolted to tranny)
06-21-2005, 08:10 PM | #3 |
Gone... But not forgotten
Member#: 16772
AKIC
Vehicle:2003 R6 i miss my rex.... |
sorry i dont have a pic, but if u start at the uppipe and walk back about 6 or so inches its right there, its kinda up in there a little but not to hard to notice
sorry thats the best i can explain |
06-21-2005, 08:12 PM | #4 |
Member#: 25478
SCIC
thanks all. doesn't sound like it's too hard to find....
06-21-2005, 08:32 PM | #5 |
Member#: 40307
South East
Vehicle:2004 WRX Sport Wagon WRB |
06-22-2005, 02:47 AM | #6 |
Member#: 25478
SCIC
spacenut - just what i was looking for. thanks!
09-06-2020, 09:32 PM | #7 |
Member#: 516808
Vehicle:2005 Impreza wrx Silver |
here it is 2020 now looking for this same thing. thanks for the picture
09-07-2020, 08:27 AM | #8 |
Member#: 132
Vehicle:GDA- D, GDA-A, VAG-A GDA-A - ShinjiTuned |
Be careful on the engine mount nuts, especially if you are anywhere close to the rust belt. They will be corroded and stuck on there tight. You can round those nuts quick. A 6 point socket helps.
Personally, I think it's less frustrating and just as easy to take the turbo off and pull the up pipe out from the top, especially if it still has that rotten heatshield on that bolts to the back of it. The bolts are usually two round nubs of rust at this point that you will not be removing. Again, this is coming from a north east guy. Enjoy! |
09-07-2020, 09:58 AM | #9 |
Member#: 21145
Vehicle:2002 Enemy of Aku |
Exactly what car are you working on?
Please fill in your profile as it helps everyone help you. Now that you already have the uppipe out, read my response in your post in the newbies section on the same subject. I'll say it again here: You do not need to raise the engine to remove an uppipe. It is a matter of wiggling the uppipe the right way to pull it out from the bottom. |
Similar Threads | ||||
motor mounts 07 STI to 06 STI | renosubby | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 15 | 06-04-2010 06:05 PM |
Engine Mount Bolt location!!!??? | DWUsSubaru | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 04-29-2010 04:02 AM |
Pitch of thread on motor mount bolts | InfamousDX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 10-02-2006 04:40 PM |
What's the torque spec for motor mount bolts? | porque | Newbies & FAQs | 6 | 07-12-2005 02:50 AM |
Help with stripped motor mount bolt | Ghomer1 | Normally Aspirated Powertrain | 15 | 12-28-2002 02:04 PM |
