Old 01-25-2018, 07:21 PM   #2351
dambikeracer
Member#: 480332
2008 STI
GREY
Originally Posted by Kami Speed View Post
To be more safe I would go with a 265/35 if running a x10.0 inch wheel. The issue I see with an 18x10.0 +40 with lowering springs will be the inside clearance with the tire hitting the springs. I would suggest 18x9.5 +40ish with a 265 tire or you can go 275.
So I bought a set of 18x9.5 +35 and a really want to run a 275 tire. I rolled my fenders in the rear and can do the front if I need to. I plan on getting tires at the end of the month but would really hate to run into other issues. I going to buy the Firestone Firehawk Indy 500's which run narrow from what I've found. I'm on stock suspension and I have not found anyone running 275's on stock suspension. I plan on doing springs with better struts or coilovers but not sure when I am going to do them.
dambikeracer is offline   Reply With Quote
Old 07-31-2018, 03:58 PM   #2352
gtfaded
Member#: 142322
2002 wrx
wrb
Default The Offset Information Thread
Thread
Last edited by gtfaded; 08-08-2018 at 09:54 AM. Reason: Finally read entire thread
gtfaded is offline   Reply With Quote
Old 07-31-2018, 04:08 PM   #2353
nemos_black_wrx
Member#: 372679
2012 impreza
DGM/plylon orange stains
SO if I was looking at 17x7 enkei in a 40 offset that wouldn't work. what about another wheel that's 17x7 +45 would that work ?
nemos_black_wrx is offline   Reply With Quote
Old 11-20-2018, 07:21 PM   #2354
Shadeslayer
Member#: 494307
2018 Wrx
Red
Default 2018 wrx steel wheels
I'm looking to get a set of wheels/tires for my 2018 wrx. The stock wheels are 18" 245/40r18 dunlops and I'm looking to get 17" steel wheels. Looking to get 215/50r17 blizzak ws-80s on tire rack and they recommend a 42mm offset 17x7 steel wheel. Would this offset actually fit my car right? I am new to the car scene and just want to get a steel wheel that fits right, not just fits.
Shadeslayer is offline   Reply With Quote
Old 01-10-2019, 02:39 PM   #2355
wrxsti2013
Member#: 376058
2013 sti
Dark Gray Metallic
I'm running Volk Racing 18x10 +35 with 265 35 18 on 2014 hatchback with Ohlins, all I did was roll the fenders....perfect look and clearance.
wrxsti2013 is offline   Reply With Quote
Old 08-27-2019, 03:44 PM   #2356
domin8469
Member#: 505492
2006 WRX Limited
Dark Grey Metallic
My car came with some bigger rims/tires. I don't know want to spend xtra money replacing them but they rub on my splash guards in front. Can I use a spacer? If so what size/kind?
domin8469 is offline   Reply With Quote
Old 08-30-2019, 07:02 AM   #2357
Oh2bugeye
Member#: 451075
2017 Wrx
WWBP
I have a 2017 wrx with 18x8.5 wheels and I’m looking to purchase wheels. What is the lowest offset I can go with out having to roll fenders? I don’t know if it matter but I’m on air suspension.
Oh2bugeye is offline   Reply With Quote
Old 08-30-2019, 11:39 AM   #2358
MountainMan10
Member#: 501522
2019 WRX STI
Pearl White
I have seen posts going down as low as 35 or 38 without rolling, but usually these come with some caveats like, it doesn't rub unless I hit a big bump or have passengers.
40 is supposed to be safe, but due to differences in cars, a small percentage of cars may have issues.
45 should be completely safe.
MountainMan10 is offline   Reply With Quote
Old 10-15-2019, 08:20 PM   #2359
Jacon
Member#: 506924
removed, figured it out
Jacon is offline   Reply With Quote
Old 01-17-2021, 09:41 PM   #2360
LakixPompa
Member#: 521740
Default 2004 WRX Stock Suspension Fitment Help
Hey there, I have 18x8.5 rims with a +35 offset. What is the best performance setup so that there is no rubbing and etc. The meatier the better. I'm thinking about 235/45/18 but I'm not sure. Please help
LakixPompa is offline   Reply With Quote
Old 02-06-2021, 02:42 AM   #2361
Wild_Bill
Member#: 509126
2002 Rs
Default 2002 RS rims on 2010 Forester
Hi we have a 2010 subaru Forester and also have a 2002 Impreza RS. We have 2010 17" WRX rims for the RS so have the factory 16" mags spare. From what I can work out the RS has 55mm offset and the Forester has 48mm offset. Would there be issues fitting the 55mm offset rims to the Forester?
Wild_Bill is offline   Reply With Quote
Old 03-13-2023, 09:57 PM   #2362
gt1brembos
Member#: 533524
Hello, I have a set of prodrive gt1s on my 04 WRX and will be upgrading to brembos this summer, wondering if a 5mm spacer will be enough?
I'm not sure if I have the +48 or +53 offset. If I have the +53, would 5mm suffice since the +48 clears?
Thanks!
gt1brembos is offline   Reply With Quote
Can we correct "The Offset Information Thread"? Portly Tire & Wheel 20 12-14-2015 06:51 PM
So I read the Offset thread... Dracon Tire & Wheel 6 11-18-2012 04:39 AM
The Hella Flush Information Thread Impreza2.5i-Kid Tire & Wheel 16 08-23-2010 08:33 AM
The end all 6 speed swap information thread DS1 Transmission (AT/MT) & Driveline 156 11-14-2009 08:21 PM
The Header Information Thread imposter Normally Aspirated Powertrain 315 04-25-2003 02:59 PM
