11-25-2019, 07:52 AM | #376 | |
Member#: 767
Vehicle:04 FXT 20 OB Onyx XT |
All of the oils you mentioned are great choices. If Shell Helix 5W-40 is the least expensive option, I’d go with that. You’re right, RL 5W-40 has a higher HTHS than you probably need.
11-27-2019, 09:32 AM | #377 | |
Member#: 317366
the helix is the expensive of those.. almost 100uss the 5 quarter The motul is the cheapest one... |
11-27-2019, 01:37 PM | #378 |
Member#: 767
Wow!
Also, the only that that helped with my consumption was switching to 10W-40. Even when using 0W-40 in winter I’ll use 10W-40 for top ups. |
11-28-2019, 08:38 PM | #379 | |
Member#: 317366
and the oil consumption was just 1/2 quart of oil..at 6000 kms interval But i don't know if run a 10/40 at ej257 turbo engine is ok here the winter we got -3 celsius and summer around 35 c of peak. thanks |
01-04-2020, 06:29 PM | #380 |
Member#: 508225
South East
Vehicle:2006 Subaru Fusia |
who do you think is producing this oil for Kirkland???
https://www.costco.com/kirkland-sign...100527865.html 10 quarts for $30 is a deal! Thats 1990s earl prices!! |
01-05-2020, 10:12 AM | #381 | |
Member#: 767
The NASIOC Oil Selection Guide
A good bargain oil that meets the same specs as the big names. Made by Warren Distribution which makes dozens of private label brands like Super Tech and Amazon Basics. They even share the same dexos license number across the same viscosities. https://www.bobistheoilguy.com/forum...f-youre-intere |
02-01-2020, 07:06 PM | #382 |
Member#: 373868
Vehicle:'04 STi WRB |
Anyone have any feedback on Motul Xcess 8100 5W40?
I picked up a jug of it and gonna be changing it next weekend to give it a try. Switching over from T6 on my built motor. |
02-03-2020, 12:17 AM | #383 | |
Member#: 289598
Vehicle:2008 impreza wrx |
I used it and had great results among the usuall oils on the nasioc list, no burning, good MGP Im now on the best oil you can buy which is Liqui Moly 10w 40. Liqui Moly 85w 90 for Trans and rear |
02-03-2020, 07:48 AM | #384 | |
Member#: 767
You’re good. APPROVALS BMW LL-01 MB-Approval 229.5 Porsche A40 Renault RN0700 under N° RN0700-10-70 Renault RN0710 under N° RN0710-10-43 VW 502 00 – 505 00 |
02-03-2020, 01:40 PM | #385 | |
Member#: 395275
RMIC
Vehicle:2012 STi SWP |
The wifes WRX seems to consume about 1 quart per 3500 miles. I've tried: Mobil 1 0w-40 Rotella T6 5w-40 Amsoil 0w-40 I may try 10w-40 to see if it helps at all. |
03-12-2020, 06:56 PM | #386 |
Member#: 373868
Just wanted to get some input from everyone on oil pressures. Whats the norm you guys are seeing?
When I ran Rotella T6 i had consistent - 80-90psi cold start - 15-17psi at warm idle - roughly ~66psi highway pressure driving at 3K RPM I just switched over to Motul Xcess 5W40 about a month ago and see - 80-90psi at cold starts. - 13-15psi warm idle - 62-64psi highway pressure at 3k RPM Nothing else on the car has change but the oil and OEM filter. Seems with Motul, PSI has dropped at warm idle and highway driving not by a significant amount but just a few PSI which makes me wonder is it thinner? What could be the cause? What's the normal oil psi you all are seeing at idle (cold and warm) as well as highway cruising? |
03-12-2020, 10:43 PM | #387 |
Member#: 767
If you’re talking about the recent version of RT6 5W-40, the kinematic viscosity of both oils @100C is the same. 14.2 cSt’s. The HTHS is actually lower on the X-cess at 3.7. I understand that the old version of RT6 is 4.0 and not sure on the newer version.
This could explain your minor difference in oil pressure. See Section 3 of the Oil Selection guide for info on viscosity. For more detailed reading on HTHS check out: https://www.bobistheoilguy.com/forum...Number=1988816 And an HTHS history lesson: https://www.bobistheoilguy.com/forum.../530501/1/hths |
03-24-2020, 08:59 PM | #388 |
Member#: 512862
Oil consumption and test of high mileage oil
Hi All,
Just posting this incase someone was wondering specifically Valvoline Full Synthetic MaxLife, a high mileage oil really works or not. Some background, I'm driving a 2009 Forester 2.5 non turbo. For several years it's been consistently consuming about 1L of oil every 4000KM driving. Mind you the car has nearly 220,000km on it. I was not the first owner of the car, I had it since 2011 eventually developed a bad head gasket which was replaced. On a side note, I noticed that many people seem feel oil consumption is something really bad, and maybe it is in some cases, but for me, as i mentioned, my foresters been consuming oil since as long as I can remember. I was shocked though when i first discovered, when I slightly missed an oil change interval that, the dipstick didn't register anything. Anyhow this is just a post for those interested. I've been using Motul Synthetic 8100 X-Clean for 9 years. And for interest sake I decided to try out the Valvoline Full Synthetic MaxLife. I found it on walmart once at a good price, like 3 x 5l for 75$ in Canada. Currently I am about 500km into this oil. And these are my observations. My mileage has increased. Before I was averaging 11.6 L/100km. And now i've been getting 10.6 L/100km. Now for the test, this is my wife's daily driver, and she doesn't know I'm experimenting, so she drives the way she usually does. I will probably post up another post at 3000km. Specifically because I will check the oil level at that point. If this oil is worse than the motul I'd want to make sure i don't run low. I'm kind of hoping this high mileage oil has some real benefits. Especially for it's occasional good prices. And if it is better than maybe I've helped others who worry about oil consumption. |
03-24-2020, 10:09 PM | #389 |
Member#: 767
I wouldn’t even bother with Full Synthetic in a 2009 Forester. I just looked up the specs on MaxLife and the viscosity of the 5W-30 Synthetic Blend is actually thicker at operating temp than the Full Synthetic.
Although a 10W-30 is usually more stable and should be better at curbing consumption. Sometimes HM oils work and sometimes they don’t. Like I mentioned above, I have the lowest consumption running HM 10W-40. |
03-25-2020, 10:09 PM | #390 |
Member#: 512862
I've been told that as well that heavier weight oil will slow down consumption. I haven't gone that route because the problem isn't all that bad yet. I mean again many people seem to worry that it's consuming oil at all. But in practicality if I do an oil change with a 5L package, I still have about 1L left over, if i consume 1L during the 4000km , I can just top it up with the remaining oil.
Also I read from a 5W to a 10W might change the characteristics at cold start up which keep the oil from flowing well. It does get pretty cold up here in Canada so, better not risk it, for now. Still though.. I'm interested in whether this particular product works or not since it is occasionally priced very well for a synthetic let alone a HM synthetic. As well, it might help in identifying the problem in the first place. Since HM oils claim to help rejuvinate seals, if it works maybe it's the seals. If it doesn't, then perhaps it's something else, maybe just cylinder/piston ring wear of age. And yes i saw the specs, it's definitely not as good as motul for driving hard. And it's an old car, I don't really drive it like that.. I have an STI for that purpose =) although, I also really don't drive my STI hard either. |
03-31-2020, 11:20 PM | #391 |
Member#: 511103
Vehicle:2021 WRX STI Black |
I've got a 2019 STI with just a catback exhaust. currently at 9,000 miles & I use:
-Castrol Edge Titanium Full-Synthetic 5W-30 |
04-12-2020, 09:08 PM | #392 |
Member#: 513640
***128077;***128077;bet that took along time to type
04-13-2020, 11:12 PM | #393 |
Member#: 373868
Anyone have any experience with the new Rotella T6 15w40?
09-23-2020, 05:46 AM | #394 |
Member#: 518829
Liqui Moly 10w40?
Anyone know how well Liqui Moly 10w40 would stand up to the other oils mentioned in this thread?
HTML Code:
https://pim.liqui-moly.de/pidoc/P000315/1300-SuperLeichtlauf10W-40-41.0-en.pdf Thanks! |
10-20-2020, 11:33 AM | #395 |
Member#: 417685
Vehicle:'03 V7 EJ207, 6MT Sonic Yellow |
Is it worth switching to Motul Xcess 8100 5W40 from Rotella T6? I have a 400whp JDM EJ207 that doesn't burn a drop of oil between OCI's and I'm a little hesitant to switch because the Motul is much more expensive and T6 seems to work really well. Winter is coming and temps can get as low as 0*, so maybe I should look into a 0W-40? Thoughts?
10-21-2020, 11:39 AM | #396 | ||
Member#: 767
Personally, I like the specs on Euro oils better since they meet the toughest specs in the industry. X-cess meets Porsche A40, MB 229.5, and VW502. RT6 is fine too if that's what you've been running and just want to stick with it, even though it no longer meets API gasoline specs. Last edited by bluesubie; 10-21-2020 at 11:49 AM. |
11-19-2020, 08:30 PM | #397 |
Member#: 123843
Vehicle:2016 STI LTD CWP Let LED's light your way! |
I've been using Schaeffer Supreme 9000 series full-synthetic 5w-40 for quite some time now: https://www.schaefferoil.com/documents/244-9000-td.pdf
I see that they now offer a 0w-40: https://www.schaefferoil.com/documents/316-9040-td.pdf Any feedback is appreciated regarding the 0w-40 oil. |
12-01-2020, 10:28 PM | #398 |
Member#: 520275
Vehicle:2007 Impreza WRX Wag Pearl white |
Newb Q
Today's Rotella T6 is STILL the correct specification for an '07 WRX?? Still ONE of the forums favorites? Or, at least a known adequate option? Thanks all! |
12-02-2020, 01:24 AM | #399 |
Member#: 511228
Vehicle:2017 Subaru WRX Red |
Wow, this is a ton of great information.
I've been using Mobil 1. If I'm understanding, since the Mobil 1 Extended Performance has a slightly lower HT/HS than regular Mobil 1, it's technically worse? I'd never go 10k miles let alone 15k without changing the oil... |
12-02-2020, 02:09 PM | #400 |
Member#: 520674
SCIC
Vehicle:2008 WRX STI Hatch Hyper Blue |
Castrol
You cant go wrong with Castrol 5w30 GDI Turbo Formula.
