05-30-2013, 06:25 PM | #51 | |
Member#: 228993
Vehicle:2015 WRX STi CWP |
http://www.clubwrx.net/forums/builds...thread-10.html
05-30-2013, 06:42 PM | #52 | |
Member#: 767
Vehicle:04 FXT 20 OB Onyx XT |
-Dennis |
05-30-2013, 06:46 PM | #53 |
Member#: 228993
05-30-2013, 09:39 PM | #54 |
Member#: 767
05-30-2013, 10:55 PM | #55 |
Member#: 228993
I've not been able to find GC anywhere. I'm assuming the preferred method is to have a case shipped via an online resource?
I've seen very little UOA results on US Castrol Edge Titanium. The fact that you say it should come back closer to a 20w suggests that you have seen UOAs on Castrol Edge. The car has been fed standard Castrol dino (not GC) for the majority of its life, receiving the bump to synthetic Castrol about 30k miles ago (75k miles). This will be my first UOA, though I should have done it much sooner. You clearly have a fantastic amount of knowledge in UOAs and oil constituents, so I ask you: is there a reason you feel that US Castrol Edge Titanium is not making the cut with my current modifications? If so, I'd like to switch NOW even before I receive my UOA results back. I've heard the bold claims regarding film strength and adhesion made by Castrol, but I'm sure (like many things), they are marketing tactics. If the above applies, to which oil SHOULD I make the switch? Thanks Dennis. - Zach EDIT: AHA! I knew you seemed familiar: http://www.bobistheoilguy.com/forums...Number=2419385 Last edited by zaxman; 05-30-2013 at 11:02 PM. |
05-30-2013, 11:07 PM | #56 |
Member#: 228993
Actually, is it true that the Castrol Syntec in the black bottle is GC?
05-31-2013, 12:19 PM | #57 |
Member#: 43950
Vehicle:07 OBXT OBP |
Sigh. I'm as guilty as others in this thread of going off topic, but let's stop here. This thread is for posting UOAs, not oil selection.
The only GC is Castrol Edge with Syntec 0w30. Castrol has changed the bottles several times in the last couple of years, but GC is the only 0w30 Castrol sells in the US. You don't really need a UOA to know Edge with Ti will come back as a 20wt. It starts out at 9.8 cSt, and the border between 20wt and 30wt is 9.3 cSt, it simply doesn't have far to go. There are a couple Edge-Ti UOAs over at BITOG though, one recently in an Ecoboost F150 that was pretty darn thin. |
05-31-2013, 01:21 PM | #58 |
Member#: 228993
Yeah, I'm terribly sorry, that's my fault. I like to keep these threads on track as well. Unfortunately for me, Oil is something of which I have very little knowledge. I'm absorbing as much as I can!
06-01-2013, 10:19 AM | #59 | |
Member#: 767
And now back to our regularly scheduled program. -Dennis |
06-02-2013, 08:59 PM | #60 |
Member#: 43950
Hey, man, I'm just trying to keep this potentially useful thread un-cluttered. I really am as guilty as the next guy...
06-03-2013, 05:01 PM | #61 |
Member#: 329252
Vehicle:2012 Subaru WRX |
Little history with my car.
I'm at 13.5k miles now. I dumped the factory fill at 1k miles. Did my first UOA of PP (posted on page 1) at 2900 miles. I'm stilll running PP but going to go for around 4k miles this time. |
06-05-2013, 02:53 AM | #62 |
Member#: 342463
SCIC
Vehicle:2004 WRX JBP |
06-05-2013, 10:51 AM | #63 |
Member#: 43950
Do you know what oil that is? Just something the previous owner/dealer put in?
Off the top of my head it looks a lot like Pennzoil conventional or Syn-blend. Possibly Pennzoil High-Mileage, though the Zn and P levels look too low for PHM. Your engine seems to be healthy. What did you put back in? |
06-05-2013, 12:10 PM | #64 |
Member#: 767
I agree. Something seems a little off for "Pennzoil synthetic" or even PYB. I don't believe any Pennzoil uses that much Mg. Valvoline maybe?
-Dennis Last edited by bluesubie; 06-05-2013 at 12:16 PM. |
06-05-2013, 02:31 PM | #65 |
Member#: 43950
Possibly Maxlife blend or Maxlife Nextgen, but none of the other Valvoline formulas have that much Moly. ML Syn is 75-100 PPM IIRC.
Edit: I should say the new SN Maxlife Synthetic is 75-100 PPM Moly, the old SM and SL formulas were ~250 PPM. Last edited by gpshumway; 06-05-2013 at 02:38 PM. |
06-05-2013, 05:36 PM | #66 | |
Member#: 342463
SCIC
06-05-2013, 11:48 PM | #67 |
Member#: 43950
Without knowing the oil, the UOA is not real useful to anybody else, but thanks for posting it any way. I'd be nice to know, it looks like a decent oil and it stayed in grade.
Post one with the Motul when you change it. Are you going to run it long enough to make doing a TBN worthwhile? Last edited by gpshumway; 06-06-2013 at 02:41 PM. Reason: ? key broken? |
06-06-2013, 11:50 AM | #68 |
Member#: 767
06-06-2013, 01:10 PM | #69 |
Member#: 316364
Vehicle:2012 WRX |
This was the first UOA I did, which was on my second oil change. I swapped out the Castrol Edge 5w30 synth for AMSOIL's 5w30 Euro blend:
http://www.amsoil.com/shop/by-produc...tic-motor-oil/ Here's the first UOA: When I did my next oil change I grabbed another UOA. However, it completely slipped my mind that I needed to have the little white vial right next to me when I started to drain, so I ended up getting my sample from pouring oil into the vial from my oil collection pan. Ultimately, I believe this affected the results of the sample. I refilled this with another 5L of AMSOIL 5w30 Euro: I recently did another oil change, but haven't had the chance to send in my sample. I replaced the 5w30 with AMSOIL's 5w40 FULL SAPS Euro, which is currently in my car now: http://www.amsoil.com/shop/by-produc...motor-oil-efm/ I should also mention that I use the OEM blue Subaru filters. I change them and the crush washer each oil change. Last edited by 1wrxtra; 06-06-2013 at 10:25 PM. |
06-06-2013, 02:52 PM | #70 |
Member#: 43950
The Subaru syn seems to have done pretty well. It stayed in grade better than previous UOAs we've seen. Too bad you didn't get the TBN. I'm sure it's fine at 5,200 mi, but TbN has been a bit weak in other Subaru syn UOAs, so more data would be good.
It's hard to know how much taking the sample from the drain pan affected the UOA results, it looks pretty darn good though. 11.44 cSt is nominally only 6% shear from the 12.2 cSt the oil starts at. This stuff is near as makes no difference 40wt. The Iron is a bit high, but without more data it's certainly nothing to worry about in a young engine. It would be really nice to see a TBN with one of these low-SAPS oils in a gasoline engine, most I've seen are from Diesels. Do you have time to tell Blackstone to run one? I realize it's $10, but do it for the team! :0 |
06-06-2013, 03:18 PM | #71 |
Member#: 316364
Vehicle:2012 WRX |
I haven't sent my latest sample in yet- I'll call them up and ask if they can run it on the 5w30 Euro I'm going to be sending them. I usually pre-pay online prior to sending in the sample.
06-06-2013, 07:03 PM | #72 |
Member#: 767
Nice to see a 2012 owner not afraid to run robust oil. The viscosity on the Amsoil Euro 5W-30 is robust, but of course, the additive pack isn't since it's low SAPS. Or rather, the add pack that shows up on a $30 doesn't look robust. The full SAPS 5W-40 is robust all around!
The zinc in your Subaru uoa is too high though. It exceeds Energy/Resource Conserving specs. Unless you put in a zinc additive, the zinc reading may be incorrect. Might want to ask Blackstone to retest. The first one is Subaru oil, correct? Also, calcium is too low and magnesium is way too high. -Dennis |
06-06-2013, 07:27 PM | #73 | |
Member#: 43950
VW gasoline cars have a factory recommended 10,000 mi OCI on 504/507 oil, including the DI turbo 2.0t, and if you look at the Lubrizol relative performance tool, 504/507 not only blows away GF-5 for wear protection requirements, it even beats ACEA A3/B4-10. These reasons lead me to try very hard to resist judging oils based on additive levels in UOA/VOA, and let the performance specs be my guide. Also, sulfur and phosphorus compounds (Sulfated ash, Moly and ZDDP/ZDP) have been shown to be a substantial contributors to valve/intake deposits so I'm coming around to actually preferring Low-SAPS oils. If I could get Fuchs Titan GT1 for my Honda at a reasonable price, I'd give it a run in an instant... I might try Eneos Sustina 0w50 in the WRX just for fun. |
06-06-2013, 10:25 PM | #74 | |
Member#: 316364
Vehicle:2012 WRX |
I have not included any additives in my oil at any time. The first UOA was actually with Castrol Edge. I had the first oil change done at the dealership and just figured it was with Subaru synth. My bad. The UOA should say Castrol though, I'm pretty sure I wrote that down on the slip. |
06-06-2013, 11:23 PM | #75 | |
Member#: 767
http://www.pqiamerica.com/March2013P...roledgesyn.htm -Dennis |
