04-11-2010, 08:59 PM | #1 |
Member#: 180514
Vehicle:2004 Sti WRB |
Primary wastegate duty cycle too high
I have an 02wrx and it's flashed to xpt stg2 race with supporting mods :
3" TurboXS TBE Catless up pipe Injen CAI Perrin inlet Perrin LW crank pulley CSS TMIC Walbro 255 Gm Bcs I logged my car today but i don't have the file in this computer so i can't post it. The car has boost issues and it can't build up the pressure in the system. It gets stuck at 10 psi till 4.5k rpm and starts raising from there. I noticed my duty cycle is around %70 till 4.5k and goes down to %65 after. Is that normal ? If it's not what could be causing this ? Thanks... 2nd gear pull http://www.mediafire.com/?hwdyndlyq02
04-12-2010, 07:06 PM | #2 |
Member#: 180514
bump, no one ?
04-12-2010, 10:10 PM | #3 |
Member#: 232940
boost control duty cycles vary widely with different setups
04-13-2010, 11:11 AM | #4 |
Member#: 180514
yes, but i know it shouldn't be this much compared to other peoples logs with same map.
04-13-2010, 03:43 PM | #5 |
Member#: 70395
Why not submit this to XPT? Not sure why everyone comes here first. What EM are you using?
04-13-2010, 03:51 PM | #6 |
Member#: 180514
Don't worry I already did.
Not sure why there are so many useless comment making users here. |
04-13-2010, 05:41 PM | #7 |
Member#: 70395
04-16-2010, 07:33 AM | #8 |
Member#: 135382
South East
Vehicle:2014 Gtr Midnight purple |
check for boost leaks.. have u adjusted the wastegate arm on ur turbo?, also check for uppipe to turbo gasket leaks or header leaks. they make ur car laggy and then at the end of the rpm is when u finally see a boost spike.. the problem is a leak not the map.. i've flashed many maps and they are right on spot on boost with no boost leaks or exhaust leaks, if no leaks then check ur turbo shaft play..
04-17-2010, 11:32 PM | #9 |
Member#: 180514
Disaster i think you are right.
I tried running the vacuum lines straight between the wastegate and turbo (no bcs) Still did the same thing, which tells me i have a leak in the hotside. I did seafoam in my last oil change and didnt see any smoke coming out of the exhaust pipes so i thought i didnt have a leak. What is the best way to spot an exhaust leak ? Thx, |
04-17-2010, 11:33 PM | #10 |
Member#: 180514
04-21-2010, 12:20 AM | #11 | |
Member#: 135382
South East
Also when u get an exhaust leak before the turbo.. they are loud..lol. u can hear the nasty tone they got.. u can try peeking around and see if ur uppipe to turbo connection has some carbon build up on it.. but the most common leak is the header to uppipe.. right by the 02 sensor.. If u dont find leaks.. then make sure u do a boost leak test. also check ur BOV. my old hks was leaking.. and i had the same problem ur seeing.... Checking the bov was easy i just put my hand by it.. and revved the engine, and if it leaks. u can feel the air coming out while u rev.. and ur using a CAI on a stg 2?.. i dont remember they having a map for a CAI on a 02 wrx..lol |
05-22-2023, 03:45 AM | #12 | |
Member#: 534345
Make sure to perform a boost leak test if you don't detect any leaks. additionally verify your BOV. I had the same issue as you did with my old hks leaking. It was simple to check the BOV; all I had to do was place my palm near it, rev the engine, and look for leaks. You can feel air escaping as you rev. and you're employing a CAI on a STG 2?I don't recall seeing a CAI map for a 02 Wrx, lol. |
prodrive 3-port BCS High wastegate duty cycle | scoobystas | Open Source Reflashes | 2 | 01-30-2010 03:54 PM |
wastegate duty cycle | imprezzing | UTEC | 2 | 05-27-2006 12:03 AM |
wastegate duty cycle zero, AFR high? | Vampyr | Engine Management & Tuning | 4 | 04-16-2006 06:18 PM |
Wastegate duty cycles and spiking | Tea cups | Engine Management & Tuning | 89 | 04-07-2006 02:33 PM |
Lowered wastegate duty cycle, better boost response | Russ77 | Engine Management & Tuning | 1 | 10-14-2004 11:38 PM |
