01-07-2009, 07:53 PM | #1 |
Member#: 59238
SWIC
05 sti wireing diagram needed to hook up spiider deluxe controller
well after much debate i will be ordering my dccd spiider deluxe controller from spider. its really self explanitory until i get to the wireing for the stock sti cluster and link them to the deluxe controller.
emailed spiider and they said i will have to play with a multimeter to get the connections. i really dont like stabing at any kind of wire, and maybe someone here already knows. if you do please inform me as i will be installing this thing the minute it gets here. thanks in advance car is 2005 sti. installed a 07 complet tranny swap with diff
01-07-2009, 08:36 PM | #2 |
Member#: 102808
Vehicle:1995 Built EJ207 6sp 30r ***break in*** |
01-08-2009, 02:06 AM | #3 |
Member#: 127745
NWIC
Vehicle:06 WRX 30r 6 speed 99L EJ255 6 Speed |
Let me get this straight...you replaced the tranny and diff, so you are replacing the diff controller as well? Is that really necessary?
All you have to do is disconnect the wires from the stock controller, and hook the appropriate wires from the Spiider controller. The schematic posted above should tell you what you need to know. |
01-08-2009, 06:14 AM | #4 |
Member#: 13680
Vehicle:2002 WRX WRB |
I have the 04 and 06 Cluster wiring diagrams, all that needs to be done is connect the wires to the control module for most clusters. What I mean by testing with a multimeter is for you to verify that you aren't hooking up things incorrectly before you hook them up. I tend to be a bit prudent in this area.
What you do is connect the dimmer power to the cluster and then just ground the wire for each light (through the meter) to verify they light up in the order you expect and when you expect them. |
01-08-2009, 02:53 PM | #5 | |
Member#: 102808
I'm just wondering why you can't re-use the OEM controller. I know the torque splits are different... |
01-08-2009, 09:43 PM | #6 |
Member#: 59238
SWIC
01-09-2009, 08:07 AM | #7 |
Member#: 102808
Ok.
Good luck installing with the link i provided. |
01-10-2009, 08:54 AM | #8 |
Member#: 59238
SWIC
thanks for the link i will use that
05 wrx wiring diagram needed | SubeSTIle | South West Impreza Club Forum -- SWIC | 4 | 03-03-2010 12:27 PM |
What gauge wire do I need to hook up a gauge? | boosted06 | Electrical & Lighting | 1 | 10-06-2007 06:50 PM |
OT Electronics Geek: What do I need to hook up speakers to my TV? | rice h8r | Off-Topic | 21 | 05-22-2007 01:49 PM |
I need an 05 sti+ wiring diagram for the Master Controls | snowcrzy | Electrical & Lighting | 1 | 03-28-2007 12:13 AM |
What parts do I need to hook up amp?? | entropy111 | Car Audio, Video & Security | 1 | 10-01-2001 02:51 PM |
