Welcome to the North American Subaru Impreza Owners Club Wednesday July 9, 2025
Old 04-06-2023, 06:07 PM   #1
C0lsanders_
Member#: 532318
2016 Impreza
Red
Default '16 hatchback hatch leak
Just discovered some sort of leak in my 2016 hatchback's hatch. As far as I can tell, it's coming in the upper, coming in to the plastic trim (this piece: https://www.ebay.com/itm/283786632157), then dripping down inside, mostly once I open the hatch. First noticed it a few weeks ago, when it seems the water ingress damaged/destroyed a dashcam I had mounted back there, so some IS getting in with the hatch closed.
Having inspected it, I can find no issues with the trim, the hatch frame, the hatch seal, the hatch hinges, etc. Wondering then if anyone else has encountered a leak back there, what might be causing it, and what a fix might be.
EDIT: Additional research shows it likely to be the third brakelight gasket. I don't think I have the tools on hand (out of town, living in a hotel), but as soon as I can open it up and look at it, I'll update here again. Still, any others with experience, please chime in.
C0lsanders_ is offline   Reply With Quote
Old 04-07-2023, 02:45 PM   #2
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green USDM 22b
do you have a sunroof?
is the rear most section of the headliner wet/water stained/damp?
Old 04-07-2023, 02:45 PM   #3
AliBenn
Member#: 487
Old 04-07-2023, 08:57 PM   #4
cueball89
Member#: 90513
It was the third brake light gasket that was also leaking for me. Added some weather stripping and tightened it down.
cueball89 is offline   Reply With Quote
Old 05-28-2023, 05:32 PM   #5
C0lsanders_
Member#: 532318
2016 Impreza
Red
Sorry for those that replied. I never got notified of them.
Anyways, I got it figured. Yes, third brakelight. Removed it, cleaned off the old seal (which was pretty bad), and put on some new gasket stuff from Autozone. That was something like a month and half ago now, have had no issues since then.
