#1 |
Member#: 16980
![]() Wondering if there is a document out there ...
im looking for ECU wires to tap for an HKS Camp system... thanks |
#2 |
Member#: 24827
MWSOC
Vehicle:2008 Kia Spectra |
![]() I can look into after work on Tuesday. I have the shop manual, so maybe it'll be in there.
#3 | |
Member#: 16980
![]() Quote:
i only need : RPM Signal Speed Sensor Injection Pulse let me know ... thanks |
#4 |
Member#: 8023
Vehicle:2019 Crosstrek white |
![]() Speed sensor and tach wire can be found on connector I11 on the back of the gauges I11 is a ten pin connector , the smallest. Blue/green is the tach (c5 -toward the center) and green/black is the speed(c2 on the end) . I know they both work bcause i use both. Injector pulse i will have to look up.
#5 |
Member#: 42478
South East
Vehicle:2004 WRX STi White/Gold |
![]() I looked up those sensors on the STi ecu pinout (ECM I/O Signal) from the manual I downloaded and got this:
Plug B134: Pin 23 = I RPM Plug B135: Pin 5 = B 12v Switched (ignition) Pin 19 = U 12v Constant Pin 27 = S Speed Sensor Plug B136: Pin 3 = #4 injector Pin 4 = #3 injector Pin 5 = #2 injector Pin 6 = #1 injector Pin 22 = P (FCD) Pin 23 = P (AFR) Air/ Fuel Plug B137: Pin 1 = E Ground *There was no TPS info for our ECU I guess because we are drive by wire but this was the info on the diagram for the STi: Plug B136: Pin 18 = Main; Fully Closed = 0.6; Fully Open = 3.96 Pin 29 = Sub; Fully Closed = 1.48; Fully Open = 4.17 |
#7 | |
Member#: 16980
![]() Quote:
any one has wired a HKS CAMP can shed any light on this ? thanks for the help guys |
#8 | |
Member#: 8023
![]() Quote:
#9 |
Member#: 49506
Vehicle:2004 Impreza WRX STi Java Black |
![]() So when we're measuring Air/Fuel Ratio we should tap into the Mass Air Flow Sensor?
Is there any wire for measuring EGT's? |
#10 |
Member#: 364137
![]() just wondering if anyone has a guide for a bee*r in a 04 sti?
#11 |
Trust no one
Moderator Member#: 11170
Tri-State
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
![]() Please don't bump 10-year-old threads.
05+ JDM STI ECU Wiring Diagram | JSarv | Subaru Conversions | 0 | 10-17-2009 11:40 PM |
04 STi ECU Wiring Diagrams | turbo2ltr | Engine Management & Tuning | 3 | 06-30-2004 06:09 AM |
STi ecu wiring diagram | STiMe | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 03-25-2004 03:23 PM |
