Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 09-10-2022, 05:51 PM   #1
subizzo02
Member#: 142591
2002 Imprezza WRX
Default Weird driveline noise 04 wrx MT
I just got back into a wrx since I sold my 02 Bugeye 15 years ago. Picked up a 2004 with 157k for 5k. Had an oil leak at the crank seal which I fixed already.
Also replaced the front axles and a wheel bearing.
Im getting a driveline noise that starts being noticeable at 2nd gear and gets louder as gears go up.
It doesnt go with the rpms and happens while the car is moving, and if I press the clutch while in motion it fades away. It sounds like its coming from the transmission, mainly the tail end of the transmission.
Any idea what it can be? Im going to upload a video as soon as I get a chance.
Thanks in advance.
subizzo02 is offline   Reply With Quote
Old 09-10-2022, 05:59 PM   #2
subizzo02
Member#: 142591
2002 Imprezza WRX
Default Video of sound.
He's a video of the sound.
You can hear it in the first few seconds of the video.
Old 09-11-2022, 04:15 PM   #3
subizzo02
Member#: 142591
2002 Imprezza WRX
Bumpp
Old 09-12-2022, 11:04 AM   #4
cboggess
Member#: 30804
87 Yugo
Red
Carrier bearing or u-joint on the driveshaft would be the first things I would check.
cboggess is offline   Reply With Quote
Old 10-12-2022, 08:49 PM   #5
charmony
Member#: 413356
Could that be ball joint? Having similar issue
charmony is offline   Reply With Quote
Old 10-13-2022, 02:31 PM   #6
subizzo02
Member#: 142591
2002 Imprezza WRX
So it turned out to be my center differential. the retaining shims/ring that holds it together was off and broken. yet diff was still together. The 2 output shaft gears had chipped and broken teeth too. The bearings on the output shaft were also ****.
