08-09-2022, 12:49 PM | #1 |
Member#: 510671
SCIC
Vehicle:2006 WRX Gray |
Used pistons in ej205
I dropped one of my pistons in my ej205 and it got dented. Can I re-use a set of used pistons from another shortblock if I use new piston rings ? Both are standard bore size. Or does the piston itself somehow wear to match the block. Both block never had any compression issues and have good cylinder walls. I have re-honed the block I intend to use.
08-09-2022, 03:18 PM | #2 |
Member#: 491095
SWIC
Vehicle:2009 STi Blue Blue |
you can use a used piston, just measure the bore to verify how much gap there is. new rings will be a good idea. Is it a cast factory piston that got dented or a forged?
08-12-2022, 10:44 PM | #3 | |
Member#: 510671
SCIC
It is a cast factory piston that took the small dent. I can sand away the dent and it will not interfere with the cylinder wall in any way |
08-13-2022, 10:19 AM | #4 | |
Member#: 77809
Vehicle:2004 STi Aspen White |
Honestly, though, if it were me I'd go buy a new piston. It's cheap insurance. Are you sure you didn't do any other damage? |
