01-18-2021, 07:35 PM | #1 |
Member#: 464237
Vehicle:2017 WRX WRB |
2017 WRX Cold Weather and Cold Start Misfire
Whenever the temp drops below 40-45 degrees out, my 17 WRX misfires for a few seconds from a cold start. Throws a p0300 random misfire code. If the the engine is warmed up, it will not happen. I tried changing the VVT valves, did not fix the issue. Since it being a temperature sensitive issue, I also tried changing brands of fuel, did not work. Not really sure where to go from here. Any help would be appreciated!
01-18-2021, 09:46 PM | #2 |
Member#: 386600
Vehicle:2015 WRX |
If you have an Accessport, take some datalogs. Look at Cylinder Roughness on each cylinder. A problem with just one cylinder might indicate an injector or ignition issue on that cylinder. Log fuel pressure as well.
Misfires are usually caused by too much fuel, not enough fuel, or poor spark. Could be related to the fuel system, spark plugs, other ignition system components, a bad MAF sensor, or a bad aftermarket tune. |
01-19-2021, 04:58 AM | #3 |
Member#: 464237
As I stated in OP, it only happens in cold weather and is a random misfire across all cylinders. What you suggest would make sense if it happened in all weather.
01-19-2021, 06:49 AM | #4 |
Member#: 481754
Vehicle:2017 STi Base Black |
What mods?
01-19-2021, 08:29 AM | #5 |
Member#: 464237
01-19-2021, 08:54 AM | #6 |
Member#: 459692
South East
Vehicle:2019 WRX STI silica black |
01-19-2021, 10:52 AM | #7 | |
Member#: 501927
This is the reason I got rid of that horrible intake I think mishimoto is the only one that keeps the stock maf location so you don’t have to use that dumb harness But I’m sure that’s his problem.. |
01-19-2021, 07:44 PM | #8 |
Member#: 418242
Vehicle:2017 WRX |
There's a recent TSB for the stock ECU that is supposed to address hard to start/cold start issues. I don't know if AP installed tunes overwrite that part of the mapping or not, or how often Cobb and others update their maps to have non-performance related ecu improvements from Subaru integrated into their base maps.
12-26-2021, 09:21 PM | #9 | |
Member#: 524408
Issue resolved
12-27-2021, 12:55 PM | #10 |
Member#: 283429
South East
Vehicle:2016 Fuji Sunfire 03 Silver |
If you are getting the P0300 code that is a random misfire not attributed to a specific cylinder. Whatever is causing the issue affects all cylinders. First thing I would try is induction/top engine service. Since the 17WRX has the FA DIT engine, carbon build-up on back of the intake valves can/will contribute to this problem.
12-28-2021, 09:15 PM | #11 |
Member#: 528090
Having the exact same problems as OP even same year car and some mods like OP has in cold weather. So far I cleaned MAF did spark plugs.added some fuel injector cleaner in and changing battery tomorrow.(due anyways)
04-05-2022, 10:37 AM | #12 |
Member#: 529540
The issue is...
Hey everyone. I hate when people don't post the answer, so here it is.
I own a FA20 DIT 2018 Forester XT. It was having "airy thuds" and sputtering happening during cold starts. Turns out this is a cylinder misfire. The reason this was happening to my vehicle is because as a direct injection engine, carbon built up in the valves over time. The intake valves need to be decarbonized every 30,000-ish miles. I've been running a Cobb tune on my Forester for the last 30,000 miles. The issue started happening to me at 60,000 miles on the vehicle. Take your car to a mechanic and tell them you want the intake valves decarbonized because cylinders are misfiring on startup. If a chemical cleaning doesn't do it, they can walnut blast the intake manifold to clear out serious carbon buildup. If the issue still persists, you will likely need to replace your fuel injectors. Last edited by NotViggs; 04-05-2022 at 12:01 PM. |
09-20-2022, 10:20 AM | #13 |
Member#: 531471
Did all the common things to fix this issue (2x valve blasting myself) and still have cold start misfire. Looked at my AP logs and other than seeing the stratified startup (retard timing, high fuel pressure) nothing else seems wrong. Nature of the beast?
09-20-2022, 11:51 PM | #14 |
Member#: 444734
FXT? You done the upper engine clean? If so it maybe the alternator causing it, there's an updated alternator to fix a P0300 problem.
