Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 12-26-2014, 06:19 PM   #1
Prime Motoring
Member#: 377106
2015 WRX
Default Prime Motoring's 1000whp RB26 + AWD FRS (Now with Install Pics too!)
This is a project of ours we have kept under wraps since the beginning of October. I loved the way the car turned out. Forward facing kit was super fast to spool, 420whp, lightweight and fun. I was planning on building the FA20 for 700+ and doing a T56 swap but my mind kept swaying.
I hated the uncertainty of the FA20 motor beyond 500hp and also HATED my trans options because I really like the way the stock 6speed shifted and the way the car drove. But I wanted more....way more. So 2jz was decided upon.
The original intentions of this build was for a 1000whp+ 2jz FRS intended for roll racing. My goal was to take the car to Texas 2k15 or Texas Invitational next year and compete, not keep up but compete with fast cars. I knew it would not hang with the lambos and gtr's down there but the ability to scare some other big toys would be great and fun. I purchased the mount kit for the 2jz, the 2jz itself, the v160 etc etc etc.
Until plans changed drastically. Having acquired a fully built 900+whp RB26 and drivetrain someone laughed at the idea of swapping the entire drivetrain including the Attessa AWD system from the Skyline to the FRS. We said "what the hell" lets test fit it in there and see what happens.
Well it fit, and fit surprisingly well. We were in business. I apologize for the crappy pics before hand because this was not intended to be a documented build but as we have gone along, I have noticed more and more people mention the RB thing so I felt pressured to post because we are MUCH further along than the pictures entail.
Test fitment:
This motor is already built to handle 900+ and we fully intend to make over 1000 horsepower. Garrett GT4294r would take care of pushing air. Knowing we would need just a bit more to get to our goals though, the turbo was sent to Forced Performance to be upgraded to their HTA4505 and 76mm Billet Wheel.
Here it is compared to my 6766 and HTA3586 before it was sent out.
HKS GT II 60mm Wastegate came in to help regulate the 40+psi we are planning on running effectively
Prime Motoring is offline   Reply With Quote
Old 12-26-2014, 06:20 PM   #2
Prime Motoring
Member#: 377106
2015 WRX
Axles were made and mocked up before being sent to DSS to get beefed up. Waiting on those to return now. Should have more updates after Christmas.
Before everyone asks how we got the four wheel drive to work. Let me just say it involved A LOT of cutting and welding. The center diff and propshaft require a nice piece of passenger side floor to be trimmed. Subframe had to be boxed out and modified to make the axles clear with enough room to allow them to move when cornering. Custom coilovers were made along with hubs and wheel bearings.
Here you will see the Axles Mounted:
Again sorry for crappy pics. Once everything is back from DSS and also parts from ceramic/powdercoating I will sure to update with better pics.
Everything comes out and cutting/fabbing begins on motor, trans and rear diff mounts. With a custom adapter we were able to make the rear skyline differential bolt right up to the stock rear subframe.
The Axle Exchange in locally in Fairfield NJ made me a custom aluminum driveshaft capable of holding over 1200hp.
Old 12-26-2014, 06:20 PM   #3
Prime Motoring
Member#: 377106
2015 WRX
We are not using any premade harnesses. We will be completely custom wiring the entire vehicle for the RB26 with AEM V2 ECU. This is from last month though. The new harness is finished and waiting for the motor to be put back in before getting wired up and integrated with the chassis harness.
In terms of the engine bay, we decided to keep everything super clean and simple. No fusebox, brake booster and make sure as much wiring as possible is tucked away.
Also I do not like the fully shaven look of the engine bay but we did fill in some holes and smooth out some things. OEM+ if you will.
That is all I have currently for you guys. Like i mentioned before, these pictures really do not do justice on how far along we actually are with the car and currently just waiting for the axles to be back from DSS as well as all the engine parts to be back from powder/ceramic to assemble accesories back together and show you the complete motor inside the car.
Once that is finished, it is up to fab work. The exhaust manifold is already made but I did not grab a pic before I sent it to powder so again, once I have that back youll be able to see the turbo mounted and how it sits in the engine bay.
Exhaust and wastegate dump will be routed through the driver side fender FYI. More update to follow after the Christmas holiday.
Happy Holidays to you all.
Old 12-26-2014, 06:21 PM   #4
Prime Motoring
Member#: 377106
2015 WRX
this also just happened
15x8 5x100 5.5" Backspacing
27x10.5/15 Hoosier Quick Time Pro Slicks for the track
26x11.5/15 Mickey ET Street's for the Street
Will be powdercoated lollipop red like my old RPF1's.
Old 12-27-2014, 08:54 AM   #5
reide181
Member#: 276915
2011 WRX Limited
Satin White Pearl
Subbed! Can't wait to see what happens
reide181 is offline   Reply With Quote
Old 12-27-2014, 01:16 PM   #6
SnakeEyez
Member#: 172752
Awesome!
SnakeEyez is offline   Reply With Quote
Old 12-27-2014, 01:37 PM   #7
Rogue_P
Member#: 371737
2003 **** Your
Fake Parts
Sub'd. This will be epic lol
Rogue_P is offline   Reply With Quote
Old 12-27-2014, 03:03 PM   #8
taco15
Member#: 297764
2006 WRX
funny. i have one of your turbo comparison pics as my screen saver. glad to see where it originated from and what car it will be pushing.
thanks sir! Subscribed and anxiously waiting for updates
taco15 is offline   Reply With Quote
Old 12-30-2014, 11:40 AM   #9
Prime Motoring
Member#: 377106
2015 WRX
Got some pics of some of the parts that were ceramic/powder coated. If you need any powder coating work that is fairly priced, done in a timely manner and with incredible attention to detail, please contact my buddy Rob at Koloskibuilt. Follow him on Instagram @koloskibuilt to see some of his work.
Some of the parts sand blasted
In the oven. Dont mind the Perrin EL headers, those are for my WRX lol
Tial housing done in Cerakote
Sick pic of the HKS GTII finished in Cerakote. The top housing will be done in Lollipop Red
Motor mounts and brackets finished in a nice semi gloss black
Almost forgot the manifold! HKS T51r V-Band Manifold modified to fit the FRS bay and wastegate relocated to clear steering column.
Old 01-05-2015, 02:11 PM   #10
Prime Motoring
Member#: 377106
2015 WRX
Rob from KB Motorsports texted me some pics of some of the parts he powder coated in Lollipop Red. Absolutely loving the way it all came out. Now cant wait to install everything!
Sand blasted and ready for powder
Belaks split and blasted as well. Super excited for these:drool:
Chrome basecoat applied
Old 01-06-2015, 10:48 AM   #11
Prime Motoring
Member#: 377106
2015 WRX
Intake manifold done in wrinkle black. Dont mind the intake, for my WRX lol
https://www.facebook.com/KoloskiBuilt
Old 01-07-2015, 11:29 PM   #12
Prime Motoring
Member#: 377106
2015 WRX
I think you guys will appreciate these pics
Old 01-09-2015, 12:26 PM   #13
Prime Motoring
Member#: 377106
2015 WRX
a few more pro pics for you guys
Old 01-13-2015, 04:56 PM   #14
RJSMITH
Member#: 347474
0219 Bug,bug,coup,va
mbp,sr,wrb
now thats a brz subaru and nissan should have teamed up
RJSMITH is offline   Reply With Quote
Old 01-14-2015, 11:09 AM   #15
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Sub'd.
OppositeLock is offline   Reply With Quote
Old 01-15-2015, 10:35 AM   #16
SportyScooby
Member#: 345991
2006 WRX
Beauty!
SportyScooby is offline   Reply With Quote
Old 01-28-2015, 12:59 PM   #17
Prime Motoring
Member#: 377106
2015 WRX
Small updates for you guys.
Axles from Driveshaft Shop are in and mounted, luckily everything fits perfectly other than a little trimming on the subframe needed on our end, everything bolts up and lengths are good.
Just need the ETS-Pro Center Differential Torque Split Controller to be able to control the Atessa system properly and we are ready to rock and roll regarding the 4wd system.
Sorry for the potato pics
Here you will see how the motor sits. From this angle it looks like it wont clear the hood but with a small bit of notching it closes just fine. Only thing is the turbo might be too big and sit too high, I wont know until the manifold is finished, had to get it modified for wastegate fitment.
Love that it is starting to look like a car somewhat. Only now I need a white hood and bumper that are not cut up. That is from the last forward facing setup on the car. Anyone with a whiteout bumper or hood looking to sell, please PM me!
Also before i was planning on running 15x8 Belak's with 275/60/15 Mickey Thompson ET Street Radials. Well that has changed and I got bigger lips to make them 15x10 and will be running a 295/55/15 all around. They stuck out slightly with the stock fenders so it was time for some fenders.
Time to put the "rocket" in this bunny
Old 01-29-2015, 03:32 PM   #18
SDoBB
Member#: 335853
2013 WRX 5 Door
CBS
Holy ****. Did you ever consider trying to put an oem AWD system in there? I know there's limited space but I wonder if it could be done.
SDoBB is offline   Reply With Quote
Old 01-30-2015, 07:29 AM   #19
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Originally Posted by SDoBB View Post
Holy ****. Did you ever consider trying to put an oem AWD system in there? .
it is using oem awd
Old 01-30-2015, 08:46 AM   #20
Blingstrom
Member#: 322188
05 STi/06 FXT
CGM/RBP
Keep up the great work. This is amazing.
Blingstrom is offline   Reply With Quote
Old 01-30-2015, 12:12 PM   #21
SDoBB
Member#: 335853
2013 WRX 5 Door
CBS
Originally Posted by Paul View Post
it is using oem awd
Haha ok you got me there, but I obviously meant OEM Subaru.
Old 01-30-2015, 01:38 PM   #22
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
holy ****
kevinh211 is offline   Reply With Quote
Old 01-30-2015, 07:05 PM   #23
erickhun
Member#: 390126
2000 RSTI
BRP
Damn! This build is gonna be legendary! Cant wait to see it finished!
erickhun is offline   Reply With Quote
Old 01-31-2015, 10:13 AM   #24
Prime Motoring
Member#: 377106
2015 WRX
Started the wiring process
New splitfire coilpacks and new coil pack harness
Fresh Cam Angle Sensor
New Wilwood Pedal + Master Cylinder Assembly
Old 02-02-2015, 08:41 PM   #25
thatbluewrxkid
Member#: 412506
pretty sweet build man, been reading about this on my phone all day.
thatbluewrxkid is offline   Reply With Quote
