Welcome to the North American Subaru Impreza Owners Club Wednesday December 7, 2022
Old 01-14-2019, 07:17 PM   #4651
jkotte7
Member#: 496482
Default 2013 wrx hatch stock wheels
I just found out I need to get new tires on my stock wheels due to one of my tires being destroyed by a piece of metal. I had been talking to a few friends who said it may be a good idea to try 245/45/17 instead of the stock 235/45/17. I am completely ignorant to this subject and wanted to get some feedback so take it easy. Would I have any issues with rubbing?
jkotte7 is offline   Reply With Quote
Old 01-14-2019, 07:23 PM   #4652
rich260z
Member#: 348236
2011 STI Hatch
PBP
You can since it's such a small change in the overall diamter of the tire. Stock size is 25.4" and that new 245/45 size is 25.7". You speedo will be off by like 1-3 miles depending on how fast you're going and you *may* notice a little more lag in taking off.
Overall if you have a tire you like more in that size, go for it. Personally I would just find some cheap tires in the stock size that someone took off a brand new car.
rich260z is offline   Reply With Quote
Old 01-14-2019, 07:35 PM   #4653
jkotte7
Member#: 496482
Right on. Thanks for the help. I have a friend who runs a tire shop and he can sell me stuff at cost. I was getting close to needing new tires anyway so it's not terrible time to have something like this happen. Probably going to go with the Continental DWS06.
Old 01-15-2019, 12:44 PM   #4654
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
You could do it, but I don't see that going to 245s gains you anything. The tires will be more expensive, and there will be little difference in performance - nothing you'll be able to notice. The 235s are probably a better fit for the stock wheel width.
Old 01-15-2019, 09:42 PM   #4655
jojo69
Member#: 309196
2012 Hatch
wrb
OK, so I guess I'll post this because I want to minimize hassles of having to fix things or surprises. I know nothing is full proof.
12 wrx on 08-10 koni struts, stock springs.
Because I'm using 08-10 koni struts, car is lowered by approx. 5/8" from stock struts.
Pulled trigger on Av20 18x9.5 +38 wrapped in Genreal Gmax AS05, 265/35.
My question is how likely am I going to need to roll the rears? I have no trouble trimming rear bumper cover (if need be) as I can do that at home, but rolling rears would require an extra trip that is tough for me to do right now. I can either pre-emptively roll rears and suck it up, or try them and then roll rears.
All input appreciated and thank you Dan for the great thread.
Cheers!
jojo69 is offline   Reply With Quote
Old 01-16-2019, 12:08 PM   #4656
perex01
Member#: 293273
2014 STI
WR Blue
I need some experts to chime in. I have a 2014 STI hatch on Eibach lowering springs. The springs drop the car 1" front and rear. The springs have been on the car since day 1 and the fenders, front and rear, have been rolled. I just got some new wheels 18x9.5 +38 and had them mounted to 275/35. Much to my dismay they rub. Not horribly and usually only on hard bumps or when leaving a steep driveway while turning. Luckily, a good friend of mine is the manager of a tire shop and is going to switch them out for me at no cost. I just want to make absolutely sure that whatever tire size i switch to is going to fit.
So, with 1" drop all the way around and rolled fenders what tires size would fit best with 18x9.5 +38.
BTW I have searched the majoirty of this thread but didn't find anyone with eibach springs or anyone specifically mentioning 1" drop.
perex01 is offline   Reply With Quote
Old 03-18-2019, 05:03 PM   #4657
Brekkon
Member#: 499233
2014 WRX
Dark Gray
Hello,
I have a stock 14 WRX and do a lot of mountain driving.
I'm installing a 2" lift, but this is new territory for me.
I could use some feed back on wheels and tires.
With a 2" lift, I was think of using 16" wheels and something close to 205/65/16 tires.
1. Will a 16" wheel interfere with the brake system?
2. Will a thinner tire compensate for being taller?
3. Am I completely off base with this?
Many Thanks
Brekkon is offline   Reply With Quote
Old 03-18-2019, 05:43 PM   #4658
rich260z
Member#: 348236
2011 STI Hatch
PBP
Originally Posted by Brekkon View Post
Hello,
Many Thanks
So if you're lifting it, you will get the ground learence, but the limiting factor for tire diameter is the wheel arches. The tire you listed is a 27" diameter tire, which is pretty large and will not clear. Unfortunatly this is one of the smallest offroad tire diameters you can get.
As for the wheels, you can use 16" or even 15", they clear stock brakes and also Subaru 4/2 pot calipers since that's what I had. Method makes a few good rally wheels, and a 205/75/15 (27" diameter) will be the same diameter. It would be better if you can find a 205/70/15 (26.3" diameter).
Here is my car with a set of 16" steelies with 215/60/16 tires and they fit perfectly. The do not make these tires anymore so I got one of the last sets.
Here is a pic with 205/75/15 on method wheels. They did not fit and would hut when turning.
I had coilovers at 1/2" under stock height in both these pics.
You're biggest limiting factor is diameter. Forget about thinness of the tire for now. 27" will fit if you modify the front bumper to clear during turns, but ideally you want a 26" to 26.3" diameter to fit with no issues.
Old 03-18-2019, 06:30 PM   #4659
Brekkon
Member#: 499233
2014 WRX
Dark Gray
SWEET! I want 15", but I was under the impression they wouldn't clear the brakes.
Method 502 VT-Spec wheels look good, with General Grabber tires maybe.
Thanks for the info, especially the tire diameter. I must have done the math wrong.
EDIT: 501 VT-Spec, not 502. Wrong offset
Old 04-16-2019, 10:44 PM   #4660
Scubaru2309
Member#: 500474
Have a 2011 sti getting some 189 +40 wheels and stock tire size 245, 40 I believe will theese fit I know itll be a stretch but just wondering ?
Scubaru2309 is offline   Reply With Quote
Old 04-16-2019, 11:25 PM   #4661
rich260z
Member#: 348236
2011 STI Hatch
PBP
Yeah you'll be fine. What suspension are you on? You could move up to 265/35/18's if you roll your fenders
Old 04-16-2019, 11:48 PM   #4662
Scubaru2309
Member#: 500474
Stock and really? Thought 245/35 and 255/35 were my only options, might indulge though, not a fan of the stretch, was thinking of getting them rolled but honestly not nothing of the process or the cost
Old 04-20-2019, 03:51 AM   #4663
_ericpreciado
Member#: 423860
2013 Subaru STI
Tangerine orange pearl
Default New wheels !
Just got a set of Gram lights 57Drs in 18x9.5 +38. They're currently wrapped in dunlop direzzas z2 and they look awful with the stock height! Waiting on my federals evoluzion St-1 in 265/35/18 and my suspension. Will be installing 2016 wrx Sti struts with rce yellows on them, supposedly the 15+ struts are an inch shorter so it should be a nice upgrade!
_ericpreciado is offline   Reply With Quote
Old 04-20-2019, 04:06 AM   #4664
_ericpreciado
Member#: 423860
2013 Subaru STI
Default Some shots on the stock height! ignore the curb rash that will be fixed lol
Old 04-21-2019, 08:54 PM   #4665
ahdez
Member#: 453214
2013 WRX Hatch
anybody on 18x9 +38 ??
any picutres??
ahdez is offline   Reply With Quote
Old 04-23-2019, 10:16 PM   #4666
Scubaru2309
Member#: 500474
On stock suspension and stock 2011 sti tire size I know itll be a stretch but will 189 +40 fit ?
Old 04-28-2019, 04:41 PM   #4667
Szarek333
Member#: 468445
2010 Wrx premium
Anyone on 18x9 +25 with a 2013 wrx?
Looking at cosmis racing XT-005Rs and am curious about how much work I'm going to have to do to get a decent fitment. I emailed cosmis racing and all they said is that they will work. Just looking for a second opinion from someone who knows more about wheels than myself.
Szarek333 is offline   Reply With Quote
Old 04-30-2019, 02:20 AM   #4668
RaEscobar
Member#: 495196
Originally Posted by QwaktastiK View Post
I just want to have my math double checked to make sure it's correct.
I'm comparing my current summer setup to a possible winter setup I'm planning:
^Summer Setup:
Wheels: 18x10 +35
Tires: 265/35/18
Possible Winter Setup:
Wheels: 18x9.5 +28
Tires: 245/40/18
By my calculations, the winter setup will have 0.75mm more poke of the wheel face (virtually the same)
and 3mm more clearance of the tire.
This is fitment I want. I got a good offer on TE37 18x10 +30. Is the +5 offset make a huge different? Anyone on here have the same spec wheels that can show me pics on their set up? I know it is going to poke but how much is it going to poke.
RaEscobar is offline   Reply With Quote
Old 04-30-2019, 04:07 AM   #4669
RockandRollGuy
Member#: 499636
2014 Impreza WRX STi
Peral White
Hello everyone,
I am finally at the point where I need to get new wheels and tires. After much research I finally found a set I like. The only thing I couldn't find is if the wheels below will clear the STi brakes. Does anyone have enough expereicne with these wheels that could help answer this question? I would prefer to not run spacers and I am not above rolling fenders. Thanks
year: 2014
model: STi (hatch)
wheel model: Weds SA-72R
wheel size/offset: 18x9.5 +38 (Also come in +45, but I think that's too high of an offset)
tire brand/model: Michelin PSS
tire size: 255/35/18
suspension: Whiteline Front/Rear 22mm Swaybars (eventually will run Fortune Auto Coils)
fender mods: None (Will roll if needed)
spacers: No
https://www.vividracing.com/weds-hyp...151394177.html
RockandRollGuy is offline   Reply With Quote
Old 05-06-2019, 02:23 PM   #4670
Cpearson15
Member#: 501231
Default 2011 WRX stock suspension
New to the Subaru world I have a 2011 WRX
stock suspension don't plan on changing it yet. Looking at running some 18x9.5 with 265/35 +35 offset what mods will need to be done ?? +35 is the only way the wheels come I'm looking at.
Cpearson15 is offline   Reply With Quote
Old 05-06-2019, 02:40 PM   #4671
hmgqo
Member#: 501230
Default wheel information
I am not sure this is fit.
I bought ESR SR 01 wheel (it mostly fit in Japanese cars).
unleashed wheel offered the best deal in any other websites.
I would recommend visit there and check it what you want wheel.
Additional information.
my car is Acura RSX.
https://www.unleashedwheels.com/esr-sr01.html
hmgqo is offline   Reply With Quote
Old 07-10-2019, 10:45 AM   #4672
SubeN'Siren
Member#: 151171
02 Subaru WRX
Default 17x8 +53 sti wheels on 2012 sti hatch
I picked up some 17x8 +53 Sti wheels to use on my 2012 Sti, stock ride height.
What size summer tires would be recommended?
I'm thinking 235/45, the overall diamater is a little shorter, I'd rather be a little tall than short, but it would do, just looking for suggestions.
The 225's on my wrx (177.5 wheels) have plenty of grip for me, on that car, so a 235 should be good on the Sti I would think.
SubeN'Siren is offline   Reply With Quote
Old 07-10-2019, 11:50 AM   #4673
rich260z
Member#: 348236
2011 STI Hatch
PBP
You can can a 245/45/17. That is the same rolling diameter as what the STI came with stock on 18's.
Old 07-10-2019, 11:58 AM   #4674
SubeN'Siren
Member#: 151171
02 Subaru WRX
Actually looking further into it, a 245/45/17 pilot sport looks to have about the same dimensions as the tires as recommended for the stock 18x8.5. (245/45/17) I am leaning towards that...
Comments?
Old 07-10-2019, 11:59 AM   #4675
rich260z
Member#: 348236
2011 STI Hatch
PBP
Comments?
Yes, see my comment above. The half inch difference won't matter much. I've run a 265 on a 8.5" wheel (not recommended, was because of class rules)
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 01:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 10:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 05:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 02:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 03:20 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
