09-13-2010, 03:45 PM | #1 |
Member#: 188614
SCIC
Vehicle:2004 WRB WRX wagon VF-37 twin scroll on E85! |
ECU's interchangeable?
I need a new ECU for my 04 wrx and I found another ecu from a 04 wrx can they be switched around even if the numbers don't exactly match?
Thanks Mike
09-13-2010, 03:50 PM | #2 |
Member#: 111318
NWIC
I had the same question for an 02 wrx and that ecu worked just fine. I was told the numbers didn't match because they were from different manufacturing dates and not because it was from a different year vehicle.
09-13-2010, 04:00 PM | #3 |
Member#: 217248
Vehicle:2009 STI Black |
I have an 04 computer in my 2005 car. It should work fine. Granted mine is a different year computer, I don't see why a 2004 computer wouldn't work in your 2004 car.
09-13-2010, 04:03 PM | #4 |
Member#: 225361
Vehicle:2006 wrx sti beige |
Just make sure you don't end up getting a stolen ECU.
09-13-2010, 04:33 PM | #5 |
Member#: 204578
You can use any 02-05 ECU on any 02-05 WRX (provided the same transmission).
HOWEVER, For example, 03 added a sensor the 02 didn't have. So an 03 ECU in an 02 with throw a CEL. Same goes for the 05. Thus, an 05 ECU in an older car with run fine, but throw a CEL. To be safe, run an ECU from your year, OR OLDER. Hoever, 04 ECU in an 04 or 03 will work. |
09-13-2010, 04:56 PM | #6 |
Member#: 151045
Going along with the above post...
The ECU pinouts are available online. As an example a small piece of wire will jump out the 'PCV Diagnostic Sensor' that is in some +04 year models and defeat the associated CEL code. OP--if you get that this point where to do swap ECU's just post up the code and an easy solution can be found. |
09-13-2010, 04:58 PM | #7 |
Member#: 42376
RMIC
Vehicle:2006 92x Aero |
I ran an '02 ecu in my '04 for a couple years. Worked great.
09-13-2010, 05:08 PM | #8 |
Member#: 152984
SCIC
Vehicle:2004 jewbaru jewbuilt, polish tuned |
i would rather get a 32bit sti ecu and have it protuned
09-13-2010, 05:10 PM | #9 |
Member#: 151045
09-13-2010, 05:13 PM | #10 |
Member#: 42376
RMIC
09-14-2010, 12:21 AM | #11 |
Member#: 188614
SCIC
sweet thanks guys!
mike |
09-12-2022, 02:41 PM | #12 |
Member#: 530777
2016 wrx
Hey you guys I have 2016 wrx cvt and was going to swap the ecu cluster unit and key but I can't find one for my year. Would a 2017 ecu work
09-12-2022, 05:19 PM | #13 |
Member#: 531336
Is there anyway to get rid of the ECU throwing a CEL?
10-08-2022, 09:53 PM | #14 |
Member#: 181617
Vehicle:2004 wrx Dom3/IAG built hybrid |
04-05 STI ECU's, Interchangeable? | JustinsWRX | Engine Management & Tuning | 4 | 04-06-2007 03:12 PM |
Stock ECU's Interchangeable? | wayfastwhitey | Engine Management & Tuning | 2 | 10-01-2005 06:37 AM |
2002, 2003, 2004 ECU's interchangeable? | badkid | Engine Management & Tuning | 1 | 09-05-2003 07:36 AM |
Jprova ECU's from Japan | Mako | Normally Aspirated Powertrain | 0 | 04-13-2001 05:36 PM |
