Old 04-15-2014, 01:17 AM   #1
Clinically_ill
Member#: 356436
Default EJ20g/k ignition coil conversion/upgrade
Alright I'm having this misfire issue that I believe could be my coil pack. I'm fairly sure it is, but even if it is not I believe doing this would be an upgrade anyways.
I have the EJ20G in a Forester S/tb so it has the EJ20K block and some of the updating designs (intercooler/intake etc.) but the EJ20G heads.
It has the ignition coil right ontop the intake manifold in the middle like this.
I could simply replace the coil but it's expensive & from over-seas (shipping duties etc.)
Does anybody know of a good guide I could use to convert this to the 04+ individual coils? I was told this is a good upgrade & if I am spending the money I'd rather it be on an upgrade anyways.
Thanks guys
Clinically_ill is offline   Reply With Quote
Old 04-16-2014, 04:22 AM   #2
Clinically_ill
Member#: 356436
Nobody eh
I was looking at this write up:
http://forums.nasioc.com/forums/show....php?t=1192028
but I'm not sure if this would work for me since I have just the ignition coil with ignitor all in one which then has ignition wires going straight to the plugs... so it's spark plug diectly contacting ignition wires. It looks from this write up like the 20g has spark plug to some sort of coil already and then the ignitor is ontop?
Old 04-16-2014, 04:35 AM   #3
Clinically_ill
Member#: 356436
Alright I'm having this misfire issue that I believe could be my coil pack, but even if it is not I believe doing this would be an upgrade anyways. First off I don't care about saving money this isn't my daily.
I have the EJ20G in a Forester S/tb so it has the EJ20K block and some of the updated designs (intercooler/intake etc.) but the EJ20G heads.
ej20G coil conversion - NASIOC
but I'm not sure if this would work for me since I have just the ignition coil with ignitor all built in to one unit which then has ignition wires going straight to the plugs... so it's spark plug directly contacting ignition wires. It looks from this write up like the 20g has spark plug to some sort of coil already and then the ignitor is ontop?
Can I make mine like the new style with the individual ignitor & coil all in one per spark plug?
Old 04-17-2014, 01:53 AM   #4
colin22
Member#: 353372
1997 wrx
the coil is the same as 1998 impreza 2.5rs. I replaced mine with beck arnley 178-8202, its a direct fit.
colin22 is offline   Reply With Quote
Old 04-23-2014, 01:23 PM   #5
Clinically_ill
Member#: 356436
Oh really? Thanks man!
Old 04-24-2014, 08:51 PM   #6
V8Slayer
Member#: 111565
2007 Legacy Spec.B
324hp/313tq EVOIII 16G
Another options is upgrading to an MSD coil off a Dodge Neon. It's cheaper then an OEM unit and gets you an extra 8,000 volts. I've been running one on my EJ25d for 2 years. http://m.ebay.com/itm/111332406408?f...7CModel%3ANeon [
V8Slayer is offline   Reply With Quote
Old 04-25-2014, 02:30 PM   #7
Clinically_ill
Member#: 356436
Oh ****. I'm gonna PM you with some questions about that
Old 04-25-2014, 06:11 PM   #8
V8Slayer
Member#: 111565
2007 Legacy Spec.B
You sir have a PM
Old 04-25-2014, 11:58 PM   #9
Clinically_ill
Member#: 356436
you freakin rock! I'm in Canada too haha
Old 04-27-2014, 01:06 AM   #10
V8Slayer
Member#: 111565
2007 Legacy Spec.B
Haha no worries, glad to help! Which city are you from??
Old 04-27-2014, 11:08 AM   #11
Clinically_ill
Member#: 356436
Edmonton!
Old 09-22-2022, 12:49 AM   #12
tom_sanchez
Member#: 530480
Thumbs up Which route?
Some time passed since this but just curious which way you decide at the end!
I'm in the same dilema, as have been thinking about doing this or no! Have heard about the MSD but was looking some info about it...I think I will go with the MSD as all tutorials found lead to the ones as EJ20G ignitor while seems no one had tried the conversion on EJ20k... will look forward for your reply!
tom_sanchez is offline   Reply With Quote
