Old 08-05-2022, 01:41 AM   #1
SecularSti
Member#: 474473
Default 09 STi - Rebuilt Factory Engine vs IAG Shortblock
Hey all. I have a one family 09 STi with 78k that’s going to be sold soon. The motor went recently and she needs a new one. I’m wanting to go with the route that will give me the greatest ROI when I go to sell it.
I had it towed to a recommended repair shop in Nashville and they are quoting me $10k for a rebuilt factory motor or $7k for a motor with 110k miles - neither situations are ideal. I’m going to call around to a couple of other shops, but the way I see it, these are my options:
1) Wait and find a lower mileage donor motor
2) Rebuild the current motor
3) Buy an IAG short block
I’m not looking to do anything else to the car besides get a good motor in it that will appeal to the most buyers. The IAG route is the way I’m leaning due to the price and the warranty. The only downside is if the heads sustained any damage, the IAG route gets more expensive. Thoughts?
Old engine can be heard here: https://forums.nasioc.com/forums/sho...3#post46716273
SecularSti is offline   Reply With Quote
Old 08-05-2022, 06:50 AM   #2
rtv900
Member#: 428511
2016 STI
so it's 13 years old with 78k on the body and you are considering plunking around 10k into it for ROI???????
What do you think it's worth even if the motor was fine?
Doesn't make any sense at all to me.
Old 08-05-2022, 08:10 AM   #3
whozatguy
Member#: 179775
03 WRX/15 FXT
14 BRZ/ 92 SVX
Have you considered selling as is? It won't sell for as much, but you also won't have to dump $10k into it that you may not get back.
whozatguy is offline   Reply With Quote
Old 08-05-2022, 09:51 AM   #4
SecularSti
Member#: 474473
09 hatches have been going for 25-30 and this one is very clean. Even if I get $20k, which is more likely, I won't get anything for it as a roller. So it makes sense to fix it correctly for an extra $3k vs an old motor with 110k on the clock.
Old 08-05-2022, 10:28 AM   #5
rtv900
Member#: 428511
2016 STI
ummm, ok, if they actually SELL for 25-30 that's one thing.
seeing a bunch of ridiculously priced listings for 25-30 is a totally different thing.
Plus, describing a car as very clean that also happens to have a ruined engine at 78k miles doesn't hold much water.
To any rational buyers that means one of two things, or both.
It was beat to hell
It was grossly ill maintained
Those are the ONLY two ways to ruin a motor at 78k miles.
Old 08-05-2022, 11:03 AM   #6
benflynn
Member#: 515308
Get it away from that shop. What blew in the engine?
benflynn is online now   Reply With Quote
Old 08-05-2022, 12:52 PM   #7
SecularSti
Member#: 474473
It was beat to hell
They do - I follow the market closely (and that’s fine if you don’t agree, I’m not here to debate that) I’d like to focus on options and see if anyone has any other recommendations than the ones I’ve listed.
Old 08-05-2022, 12:54 PM   #8
SecularSti
Member#: 474473
We're not sure, the engine hasn't been torn down, but likely low oil. The engine was only driven home after the sound in the link occurred and has always burned about half a quart between changes. I checked the oil when I got home and it was lower than expected.
I agree, the shop does not sound like the best option. I'll likely go with an IAG block.
Old 08-05-2022, 01:24 PM   #9
benflynn
Member#: 515308
If your just going to sell it get a 1500$ oem short block, 300$ oem gasket/seal set, timing kit and normal head service.
Old 08-08-2022, 08:55 PM   #10
SecularSti
Member#: 474473
Good call Ben, this is the route I’ll go! I hadn’t been able to find a decently priced short block but I found one for $2300. Where did you see one for $1500?
Old 08-08-2022, 09:33 PM   #11
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Oem, $1,500
Old 08-09-2022, 01:24 PM   #12
SecularSti
Member#: 474473
Originally Posted by KillerBMotorsport View Post
Oem, $1,500
You sell them for $1500? I can’t find them for less than $2200
