Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 05-26-2021, 02:43 PM   #1
Boxer1687
Member#: 369969
1998 Impreza Outback
Default ABS light turns on and off
1998 Impreza OBS 5 speed manual
2.2
252k
Minor mods
-maxspeedingrods (or however you spell it)
-Alloy 15” Subaru rims( came with steelies)
- replaced driver side axle 240k.
ABS light comes on and off. Not flashing.
When I turn on the car ABS light is on but not all the time I turn it on.
When it’s on I’ll turn off the car and turn it back on then problem temporarily solved.
Usually when a ABS sensor is in need doesn’t it stay on?
My next step is to physically check it this coming weekend.
Besides that is there anything else I can do if I don’t find anything wrong with the sensors?
Boxer1687 is offline   Reply With Quote
Old 06-25-2021, 06:35 PM   #2
Boxer1687
Member#: 369969
If anyone is reading this found the issue..
The issue was right front ABS sensor.
The wire had a mild cut and it was copper exposed. I cut it to re do the wires but corrosion was found all over the wire. Ordered a new one it’s on its way now.
Problem; cut wire exposed un-insulated, corrosion.
Old 06-26-2021, 03:51 AM   #3
Vancouver98STi
Member#: 459287
1998 JDM Impreza STi
V4 GF8 White
Thumbs up
This could prove to be helpful info for someone some day. Thanks for posting the resolution.
Vancouver98STi is offline   Reply With Quote
Old 07-06-2021, 07:26 PM   #4
Boxer1687
Member#: 369969
No problem. I do what I can to help!
