Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 04-24-2021, 07:45 PM   #1
wrxmarissa
Member#: 523854
Default 03 WRX Wagon
I bought a WRX a few days ago and it was making a metal on metal noise which was solved after replacing the brakes and rotors. But when I replaced them I saw that the front axel on the drivers side needed replacing which I suspected to be the cause of a thunking sound. After replacing the axel, the thunking was still there. Does anyone have any ideas as to what this may be or how to fix it?
wrxmarissa is offline   Reply With Quote
Old 04-24-2021, 07:49 PM   #2
murrdogg24
Member#: 50586
64 Impala
Did you check the wheel bearings?
murrdogg24 is offline   Reply With Quote
Old 04-24-2021, 08:15 PM   #3
wrxmarissa
Member#: 523854
yes. they were fine
Old 04-25-2021, 04:48 AM   #4
MortonCharbo
Member#: 487057
2002 WRX Wagon
Tie rods, ball joints, sway bar bushings and end links, are the sway bar mounts tight? Strut top hats?
Those things have all clunked at one point or another on my 02 wagon.
Any more description on the type of clunk, or the conditions under which the clunk happens?
MortonCharbo is offline   Reply With Quote
Old 04-26-2021, 01:18 AM   #5
wrxmarissa
Member#: 523854
It almost sounds like the brakes are constantly rubbing, so I did describe the noise incorrectly to begin with. There were three different noises that were very similar to begin with. One was fixed by replacing brakes and rotors. And one by replacing the front drivers side axel, but the other is a loss. It’s any time the car is in motion.
Old 04-26-2021, 01:20 AM   #6
MortonCharbo
Member#: 487057
2002 WRX Wagon
Make sure the dust shield isn't rubbing on the rotor. It could be something that simple. You can simply grab it and pull it back a little. Just be careful not to slice your hand open.
Old 04-26-2021, 08:22 AM   #7
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Ball joints and the pinch bolt that holds them can cause a clunking sound. OEM end links are a known weak point even when new. A blown damper will clunk as well. Lower control arm bushings, especially the inner front, can clunk when too worn. Since most people don't do all the regular maintenance, your best bet is to start replacing all that stuff (and more) given the age of the car.
snow_bound26 is offline   Reply With Quote
Old 05-07-2021, 02:43 AM   #8
Fast510
Member#: 523915
Did you have your rotors turned? I've had brand new rotors that were out of true...
Fast510 is offline   Reply With Quote
