Welcome to the North American Subaru Impreza Owners Club Friday July 30, 2021
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Old 08-19-2013, 07:55 AM   #126
KillerBMotorsport
Vendor Sales Rating: (43)
Member#: 198281
2005 WRX/STi
WRB of course
PM us if you want your pan powder coated. Typically only used with show cars and track cars trying to bend the rules It costs $35 and adds 4-5 days to the order.
There is no benefit to powder coating except the appearance.
__________________
vs.
FA20 WRX Ultimate Oil Pickup, Now Available! Improving Pressure Consistency and AVCS Synchronization
Old 10-07-2013, 09:22 AM   #127
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
No wait on these, many in stock
__________________
vs.
Old 11-11-2013, 09:15 AM   #128
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Welding High Performance Suby pans...
__________________
vs.
Old 12-02-2013, 09:28 AM   #129
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Happy Cyber Monday!
__________________
vs.
Old 12-09-2013, 09:33 AM   #130
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
In Stock!
__________________
vs.
Old 12-26-2013, 08:52 AM   #131
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks for the X-Mas orders!!
__________________
vs.
Old 02-10-2014, 09:32 AM   #132
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Almost in stock
__________________
vs.
Old 05-05-2014, 07:59 PM   #133
principe
Member#: 111052
06 STI
WR Blue
pm I want all 3 parts
Oil Pick up
oil wafle
Oil Pan
thank you
principe is offline   Reply With Quote
Old 05-09-2014, 04:34 PM   #134
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
__________________
vs.
Old 05-22-2016, 03:15 PM   #135
NSFW
Member Sales Rating: (1)
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
I bought one of these a while back, and now I'm getting ready to put in the oil temperature sender. How clean/dry do the threads need to be when I put the 1/2 NPT adapter back in?
I mean, are we talking "remove pan, degrease, brake cleaner..." or is it enough to wipe the threads with a paper towel after draining the oil?
Thanks!
EDIT: I have Teflon tape and will be using it unless there's some reason not to.
Old 05-22-2016, 03:42 PM   #136
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks!
Oily is fine, but you'll want to remove as much debris as you can. Usually with a small pick you can get old Teflon tape out pretty easy. Or you can shove a wire brush in the hole and spin it out counter-clockwise to remove any bits leftover. Not worth pulling the pan IMO.
__________________
vs.
Old 05-22-2016, 05:30 PM   #137
NSFW
Member#: 140444
05 Stage Free LGT
Thanks!
Can't beat speedy service on a Sunday.
Old 05-04-2017, 01:39 PM   #138
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
__________________
vs.
Old 11-07-2017, 07:37 PM   #139
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
So the cast pan has been up and rolling for a while now. The feedback has been great, which has been good to hear.
We are still going to be taking order for the fabricated oil pans, but they are made to order only. Let me know if you have any questions
__________________
vs.
Old 06-03-2021, 08:35 AM   #140
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
To all of you who have purchased our new Super G Pan and High Flow Pickup.
We are interested in your feedback and data. We would love to get some plots that include telemetry, oil pressure, oil temperature, and crankcase pressure.
We have sold a lot of these pans and our customers have been generous with feedback, but more is always better.
  • 3D CAD Designed and Tested for Extreme Performance
  • Oil Containment Baffle Prevents Oil Starvation
  • Crankcase Breather Vent Eliminates Liquid Oil Egress from Crankcase Breather
  • Precision Cast Double Heat Treated Aluminum Alloy for Maximum Toughness
  • Up to 40% Increase in Capacity.
  • Works best with Killer B High Flow Oil Pickup and Windage Tray
  • Fits most Equal Length Headers, Including Killer B Headers
  • (1) M20 OEM Port and (1) 1/2NPT Port
  • Materials, Design, and Manufactured in the USA
  • Track Tested and Proven
Designed for High G track use. The best option to protect your Subaru.
Learn More
__________________
vs.
Old 06-08-2021, 05:00 PM   #141
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Have questions? Get answers
Fun fact, we use a proprietary casting process that allows thinner walls with no draft required. A benefit of using this process technology is that it allows pan geometry that can hold more oil. More oil means more 'residence time' (the time oil spends in the sump before it gets sucked back into the engine). Any increase is residence time will decrease aeration. Improved oil residence time has been shown to de-aerate oil better than 'de-aeration baffles'. Improvements in de-aeration increase oil pressure, reduce heat, and improve overall lubrication system function.
__________________
vs.
Lightly used Killer B Performance Oil Pan and New Pickup $450 KillerBMotorsport Engine/Power/Exhaust 3 10-27-2010 08:23 AM
FS apexi turbo timer , blue injectors , TMIC , oil pan , fuel pump more MAKE OFFER!! calweezy SCIC Private Classifieds 27 10-10-2009 04:30 PM
FS-Cosworth Hi/Capacity Oil Pan Kit, Cos. Rod/Main Bearings, BC Valves/Spring/Ret blackacres Engine/Power/Exhaust 22 02-14-2009 03:16 AM
High Capacity Oil pan for EJ25? Ultimate Racing Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-03-2006 12:06 AM
Is version 5 oil pan same as US WRX pan ? zaidallas Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-27-2002 02:58 PM
