09-19-2020, 06:23 PM | #1 |
Member#: 337634
Vehicle:2013 WRX Sedan 308/339 -Tuned by Agile |
Does anyone know how to turn off the Auto Start Stop feature?
I'm trying to help my mother out. She bought a brand new 2020 Subaru Outback and the center section by the radio is like one gigantic iPad. Everything is electronic with no knobs at all which isn't my style, but hey, it's not my car.
Anyways, I know how to switch over to one of the 3 bottom settings from the car, home, and personal settings. In the car settings, one of them I can turn off the Auto Start Stop feature which my mother hates, and i've driven the car before and I find it annoying as well, but then again my WRX was a stick, so that would never work on a car like that. Whenever I turn off the feature it stays off, but when I go to the local grocery store for example and lock it up and get back in and start it up and then come to a stop it automatically turns itself back on. I thought if I linked my mother's iPhone to the car and then re-applied my settings it would stick since the key fob is linked to the driver profile, but the Auto Start Stop feature still turns on automatically regardless of which key fob I use. I figure this applies to anyone with an Outback, Forester, Ascent, or Legacy. I know WRX/STis don't have all this fancy touchscreen only stuff, at least they have some manual knobs lol
09-20-2020, 12:43 AM | #2 |
Member#: 383291
Vehicle:2004 Forester XT Cayenne Red |
It is impossible to permanently disable, due to fleet fuel economy numbers. Take it up with the EPA or California if you want it changed, we'll all sign the petition.
09-20-2020, 07:46 AM | #3 |
Member#: 337634
What is the point of the digital button to turn it on and off for? You mean no matter what I do in the settings, it will automatically just turn itself back on?
09-26-2020, 03:59 PM | #4 |
Member#: 518914
If it's like Ford, then every time you turn the car on, you'd have to press the button to disable it. Not familiar with these newer Subarus, but didn't realize they had it as well.
09-27-2020, 02:01 PM | #5 | |
Member#: 149347
Vehicle:05 LGT ,09 SpecB Black/silver |
You need to turn it off every time. |
09-27-2020, 02:53 PM | #6 |
Member#: 21145
Vehicle:2002 Enemy of Aku |
There is no way you are going to be able to permanently shut off that feature. The whole idea is to promote fuel savings by not having the engine running when you are stopped in traffic.
I've read where people have attempted to permanently shut it off by dicking around with the ECU / sensors. The end result was they shut it off, but created a number of other issues with other systems in the car which are difficult to correct, if at all. |
09-27-2020, 04:14 PM | #7 | |
Member#: 153088
Vehicle:2005 Baja Turbo 95&96 Sambar 06 Forester |
To be a little bit more accurate, it's the fact that an engine not running is not putting emissions into the air. Fuel savings is a nice byproduct of that. And, no, as stated already, it cannot be permanently turned off. Gotta turn it off with every cycle of the ignition. |
09-27-2020, 07:52 PM | #8 |
Member#: 89283
Vehicle:2017 WRX Premium ISM |
This also goes for Ascent, Forester, Crosstrek, Legacy.....
09-28-2020, 09:15 AM | #9 |
Add Lightness
Moderator Member#: 13699
Vehicle:2021 Building It Better |
Pretend it's an electric car. You stop. Car shuts off. You want to go, you step on the gas and it starts and goes.
Now, I can see where if this were a Jeep Wrangler and you were trying to crawl over boulders and suddenly lose power, that's a problem. But for a street vehicle, just deal with it. |
09-28-2020, 09:46 AM | #10 |
Member#: 383291
You can modulate the brake pedal to prevent it from activating, if you apply more or less pressure than the system is looking for it will leave the engine on. You can also cancel it at a stop by applying more pedal pressure.
09-29-2020, 08:37 AM | #11 | |
Member#: 21145
Just don't look down and crash the car while doing so. |
09-29-2020, 01:19 PM | #12 |
Member#: 767
Vehicle:04 FXT 20 OB Onyx XT |
If she has the latest software update (ending with 504) then at least it does make it a two step process instead of a three step process. That update also adds vertical CarPlay as well as fixes some connectivity issues.
No personal experience, but this company has an Autostop Eliminator that will remember the last setting. https://www.autostopeliminator.com/c...top-eliminator The Forester version has been out for a while and the Outback version is new. Modulating the brake pedal is for those that don't want to monkey around with the screen. My wife uses the brake method when she drives my car, although I agree that it's very easy to turn it off, especially now that it only takes two presses of the screen. Last edited by bluesubie; 09-29-2020 at 02:56 PM. |
09-30-2020, 01:13 PM | #13 | |
Member#: 498642
Vehicle:'19 WRX Ltd 6M dgm '08 Mustang GT (the toy) |
The 'extreme weather' warning screen on our WRX almost never responds to me when I try to cancel it, so I've stopped bothering to try. And I've had touch screens lock up on me mid-word when signing in at a local medical facility, though the admin person could pick up and continue from where I got locked out with no difficulty whatsoever. Those are the recent ones. It probably involves some body electrical thing, capacitance or resistivity, where the screen's electronics can't handle individual body values that are outside of the expected range(s). Norm |
01-22-2021, 06:49 AM | #14 |
Member#: 466134
I just saw a video review on the 2021 Outback and the Stop/Start button on the screen was front and centre in between the home button and car icon. It must be a software update, anyone have info on this?? I want it as it will make life so much easier!!!
01-22-2021, 08:14 AM | #15 | |
Member#: 428511
Vehicle:2016 STI |
a) some cars that have the feature can simply permanently disable it (jeep grand cherokee for instance) b) most cars don't even have the feature at all If it was regulatory every car would have it |
01-22-2021, 08:22 AM | #16 | |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Just a guess. My CR-Z has auto-stop with a manual, at first it was disconcerting but I've gotten used to it. The implementation is actually quite good and restarting is seamless as soon as you put it in gear. As for the '21 I highly doubt that an earlier model can be updated for that, you'd need to buy a new one. |
01-22-2021, 10:07 AM | #17 |
Member#: 138994
Vehicle:2006 WRX, 6MT, 5x114 |
Engine Start-Stop a feature solely for MFR fuel consumption improvement then marketed to the consumer as a customer friendly feature.
It is not what I would say called for in regulation at the moment. As noted above, if the feature is active during emissions certification then it most certainly is involved and thus MFR can't allow permanent deactivation (only inconvenient temporary deactivation). Eventually most if not all cars will have this feature someday. Features like this are not typically spread across all product platforms at the same time. Usually spreads to new product at re-design points and targeting areas that offer the most fuel efficiency credit (for the MFR). MFRs implement engine Start-Stop differently of course. So they can vary between seemless-ish to outright intrusive in operation. Sitting at a stoplight and some cars next to you are startling/distracting when the systems activates and deactivates. So much disappoint...if only that effort spend on bandages like this were put to use in areas that could have larger impact. Last edited by JarHarms; 01-22-2021 at 10:13 AM. Reason: People can blah, blah, blah all day long about it being an environment saving feature. |
01-22-2021, 11:32 AM | #18 | |
Member#: 428511
Vehicle:2016 STI |
Emissions at idle are some of the worst of all because of how much timing is needed for a good idle. I'm not saying it's a big deal or necessary but it is emissions, not fuel economy. |
01-22-2021, 12:56 PM | #19 | |
Member#: 138994
I was not being critical of your post, just being cynical of Start-Stop in general. |
01-22-2021, 01:24 PM | #20 | |
Member#: 428511
Vehicle:2016 STI |
maybe in horrible city traffic or something where you are stopped for 80% of the total time it could serve a purpose, but in rural areas like where I am you are driving 98% of the time and maybe hit a light or two for 10 seconds, 20 at most |
01-22-2021, 06:05 PM | #21 | |
Member#: 337634
I would love to see some long term studies or even just plain use over a 20-30 year period to see cars with the auto start-stop feature vs. cars w/o them and the life span of the OEM starter of the same two vehicles with one equipped with AS and one w/o it. |
01-28-2021, 04:14 AM | #22 | |
Member#: 521841
Vehicle:2018 STI Limited Dark Grey Metallic |
01-28-2021, 07:00 AM | #23 | |
Member#: 498642
Norm |
01-28-2021, 11:55 AM | #24 |
Member#: 428511
Vehicle:2016 STI |
Hell I have to flip my center console switch to S# every single start up.
It's just a reflex at this point although I certainly wish I didn't have to do it |
06-14-2021, 02:21 PM | #25 |
Member#: 473188
E. Canada
Vehicle:2009 WRX STI |
Question--is auto/start/stop turned off if you pull a trailer?
I have a brand new subie trailer hitch with wiring just installed on my Forester ('19). If i hook up to the trailer wiring will it defeat auto/start/stop? There is so much extra and unnecessary engine wear and starter motor wear;...i don't like that. I used to belong to the TorontoSubaruClub for years and years. Can't find them now. Have they closed? |
