05-04-2020, 05:29 PM | #26 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
I'm definitely curious to hear more about the 2.35 and the G30. What do you have done for the internals/heads?
05-07-2020, 08:59 AM | #27 |
Member#: 512373
Vehicle:1998 Gc8 wrx |
The motor is a deshele built long rod destroked 2.5 closed deck 14mm head studs and all the goodies, the exact cam specs I haven’t been told as yet but it’s very lumpy,I’m still waiting on more dyno time since the last session when I have more info I’ll post it
05-08-2020, 12:19 AM | #28 |
Member#: 513924
SCIC
Vehicle:2005 WRX STi White |
I’d like to know more about your spoolinator kit with this turbo . I really want to stay in the stock location and not go rotated . My motor is currently at CSS , going closed deck .
07-13-2020, 12:14 PM | #29 |
Member#: 339923
Vehicle:2006 Impreza WRX STi grey |
Reviving an older thread. any new info with these?
07-14-2020, 03:05 AM | #30 |
Member#: 92894
BAIC
Vehicle:2015 Wrx - fury kit silver duh |
What exactly are you looking for besides the basic information you can find from Garrett, ATP-turbo and or Full-Race?
07-14-2020, 04:03 PM | #31 |
Member#: 339923
looking for numbers, spool time on the street. I primarily do autocross and trackcross, initially i was leaning towards a 3071 gen 2, but i'm considering these too. ideally id like something that can hit in the area of 450-500whp/tq with the fastest spool possible (on e85) . i understand there are limitations but it seems hard to find what these are actually doing minus the speculation. ive found very limited info on them. and only like one guy running them.
07-14-2020, 06:06 PM | #32 | |
Member#: 328635
Vehicle:2004 STi GTX3076R Rally Blue |
07-15-2020, 01:38 AM | #33 |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
There is one guy that I sae had the g30 770 which is the eqivalent of a 3071
Here you go not sure why he isnt impressed. there are alot of people makeing 400 on 20 psi on a g25 660, hows does that not impressive, there is one guy that got tuned at Yimi that is making 550 on his bug with a ej257 on a g25 660 |
07-15-2020, 02:57 AM | #34 |
Member#: 92894
BAIC
Yea that's Ibrahim's car, super cool dude. The G30-770 just wasn't reaching his power goals lol. He's since upgraded to a G30-900.
Here's another video of inside the car, you can see it's takes off around 3900 rpms and pull to redline. I would like to that turbo on E85 Another video of them on GR STi |
08-19-2020, 04:35 PM | #35 |
Member#: 29292
SCIC
Here a g30 660 on a 2.1
08-19-2020, 04:36 PM | #36 |
Member#: 29292
SCIC
Heres a g30 660 on a 2.1
483 whp isnt bad |
09-07-2020, 10:24 AM | #37 |
Member#: 512373
So just updating the car has gone 570hp atw on 98 with water meth, the motor is a destroked 2.5 closed deck so 2.3 with head work and cams with the g30/770
09-08-2020, 03:42 PM | #38 |
Member#: 517390
Vehicle:2005 WRX STI OBP |
I am currently in the process of building my motor and will be using the G30-900. I will share the results once I have them. Car is currently at Surgeline in Portland.
Build details: IAG-#700 longblock IAG TGV deletes Cobb fuel rails 1300 injectors Fuel Lab Fuel Pressure Regulator AEM 320 In Tank Fuel Pump (may also be doing a Radium Engineering MPFST Dual Walbro 460 in Surge Tank pumps) Cobb FMIC Killer B oil Pickup Killer B Holy EL Header/up-pipe Group N engine mounts Cobb AOS G30-900 Turbo Custom downpipe and dumptube This will be a street car so chose not to go to the G35 for now in hopes I would get a bit quicker spool on the G30. I can always go bigger if I get bored |
09-08-2020, 05:57 PM | #39 | |
Member#: 29292
SCIC
09-25-2020, 01:19 PM | #40 |
Member#: 339923
i'm excited to see that build^^
ive been searching hard and trying to decide if i should go with a g30-660 or 770......i really hope more people start posting them here in depth. i'd like to see how they spool, would be especially cool if there was a spool comparison to the gtx gen2 counterparts. |
09-26-2020, 07:51 PM | #41 |
Member#: 92894
BAIC
What's your end goal with the car? I literally was torn between those two but ended going with the G30-770.
09-26-2020, 09:15 PM | #42 | |
Member#: 29292
SCIC
09-26-2020, 10:41 PM | #43 |
Member#: 140444
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
I'm really curious where these all hit full boost in 3rd gear. Full boost at around 4000 was something I got used to pretty quickly, but I'd hate to have the powerband get any narrower.
09-27-2020, 01:46 PM | #44 |
Member#: 29292
SCIC
09-27-2020, 02:09 PM | #45 |
Member#: 269226
09-27-2020, 02:16 PM | #46 | |
Member#: 269226
09-28-2020, 10:37 AM | #47 | |
Member#: 339923
also an edit, I do plan on going rotated. further edit - car is a 2006 sti with a 2.5 "stage 2 tuff" iag shortblock. oem heads. Full bolt ons. still on a tmic (spearco). i'm happy to share anymore info about it if it'll help or if someone is curious Last edited by Karlot; 09-28-2020 at 10:51 AM. |
09-28-2020, 10:53 AM | #48 |
Member#: 339923
dang, for 300rpm i'd just go with the 770 lol. it is a trackcross/autocross car now, and i'll likely end up moving into road courses as my budget allows, but it will still be a street car, even if it only sees the street like 10x per year lol
09-29-2020, 04:18 PM | #49 | |
Member#: 328635
The main thing to keep in mind is that with stock heads power WILL drop off after 6500rpm so you really need to maximize what you produce in the lower range to make the most out of the set-up. IMO |
09-30-2020, 08:26 AM | #50 | |
Member#: 339923
and i do understand that power will start to fall at 6500. i will likely have to just stick with that for now and shift around 6500 to stay into the powerband. eventually i would like to build the heads. havent done too much research into that at the moment. i may run 272 cams but i'm not sure if that would be the right choice as i know it would help mid range and a bit into the upper end, but id lose some down low. but that's a whole different subject. |
