04-16-2007, 04:59 PM | #176 | |
Member#: 125055
VIC
Vehicle:12 STI hatch |
04-16-2007, 05:57 PM | #177 |
Member#: 74792
VIC
^ah gotcha, yeah the tuning made a big difference... and you should get yourself a nice catback
04-16-2007, 06:50 PM | #178 |
Member#: 118148
VIC
Vehicle:2013 xc70 silver |
nice numbers amarpauld!
04-17-2007, 01:05 PM | #179 |
Member#: 41811
VIC
Vehicle:02 WRX White |
Nice Paul! I have been wondering what my car would dyno since I put on the catless DP.
Any feedback on what the intake was giving you? |
04-17-2007, 01:42 PM | #180 |
Member#: 74792
VIC
^Can't really say since I had the intake on for all those plots, only thing that changed was going from shelf map--> light tune-->...more tuned?
So, obviously it was pat's tuning that made the biggest difference, the intake might've done a little bit, but not much I suspect since I don't exactly have big power mods that could 'better' take advantage of it...(?) Besides, the intake was more of a 'fun mod' then anything |
04-17-2007, 01:52 PM | #181 |
Member#: 5851
VIC
Vehicle:17 Ford Escape SE Blk |
I think when we did the intake alone peak gains were about 8-10WHP but that was for a very small section. 3-5WHP gains were seen through much of the power band (it was quote awhile ago so not sure if that is right).
04-17-2007, 10:15 PM | #182 |
Member#: 97
you will be lucky if an intake nets you any gains at all WITHOUT tuning. this is just because of the way it affects the cars. Certain magazines that have "dyno comparisons" of intakes before and after dont let the car learn to that intake (and hence they run lean for the pull) and thus net the "huge gains" of 3-5hp (which you would gain anyways if you leaned it out the same amount with the stock intake). Also, 90***37;, no, make that 95%, of the intakes out there are "hot air intakes" despite all the body cladding attempts to make them "cold air intakes". If you have one that truly runs the same Air Fuel as the stocker, and increases flow, and isn't a hot air intake, then yes, you can have gains without tuning. However there are only 2 or 3 on the market that do that. The gains will all be less than 5% without tuning, more like 3% if that.
If you data log the air temp on the intake, you will see clearly that some intakes are "hot air" intakes. On a stock tune the hot air intake can zap a lot ofnpower as the stock ECu starts to pull timing when it sees 40C on the MAF (if you think that is high, check the temps that the MAF thinks its seeing out on a certain "big" intake while you sit at a stop light. It would make you shudder). But if you are maxing the MAF then an intake will instantly increase your output safely. Most people get intakes because they are maxing out the MAF, or have "completed" their mods and want every last bit out of it, or want a true cold air intake. Of course, those are the functional reasons. Normally, its a "low cost" item which can produce gains, if tuned for. I dunno. I once bought one for my RS because I didn't know what else I could buy for $350 that made me feel good :-) Last edited by patr; 04-18-2007 at 12:08 AM. |
04-17-2007, 11:57 PM | #183 |
Member#: 82465
VIC
Vehicle:2014 Forester 2.0 XT MBP |
The only difference between plots 56 and 67/68 is an APS cold air intake, and tuning. It was installed for more MAF headroom. Sounds good too.
04-18-2007, 12:47 AM | #184 | |
Member#: 125055
VIC
What I am interested in, is the way amar's previous plot was only 3-4 whp more than mine, but how much more pat was able to get out of it with the CT. |
04-18-2007, 01:57 AM | #185 |
Member#: 41811
VIC
Interesting. I remember reading that most Cold/Hot Air intakes are good for little for lightly tuned cars. And really you shouldn't bother unless your running 300+ on a WRX.
I'm all for the noise though, I mean I have a GFB 50/50 bov for that though...lol. Oddly enough I haven't run into issues with it. |
04-22-2007, 12:12 PM | #186 |
Member#: 19776
VIC
Vehicle:2012 GVF SWP Ninja Lime Green |
my slow ass wrx..
[IMG]http://i46.photobucket.com/albums/f139/Kichoman/PIR***37;2007/Dynograph.jpg[/IMG] ??.. wonder why it's a link.. oh well.. ps: there is a typo.. should be a vf30.. |
04-22-2007, 12:56 PM | #187 |
Member#: 125055
VIC
04-22-2007, 09:01 PM | #188 |
Member#: 19776
VIC
cool thx!
04-24-2007, 08:00 PM | #189 |
Member#: 5851
VIC
Click the link to get to a little montage of my car on the Dyno.
http://www.rocketrally.com/patrickri...m/videos/dyno/ |
04-24-2007, 11:45 PM | #190 | |
Member#: 125055
VIC
and you've got to reach your prime That's when you need to put yourself to the test, and show us a passage of time We're gonna need a montage! MONTAGE! Ooh, it takes a montage! MONTAGE! Show a lot of things happening at once, remind everyone of what's going on! And with every shot show a little improvement, to show it all would take too long! That's called a montage! MONTAGE! Ooh, we want a montage! MONTAGE! In anything that we want to go, from just a beginner to a pro We need a montage! MONTAGE! Even Rocky had a montage! MONTAGE! MONTAGE! MONTAGE! Anything that we want to go, from just a beginner to a pro We need a montage! MONTAGE! Ooh, it takes a montage! MONTAGE! Always fade out in a montage If you fade out it seems like more time has a passed in a montage Montage |
04-25-2007, 03:29 PM | #191 |
Member#: 5851
VIC
That's exactly what I was thinking when I posted that.
04-29-2007, 07:19 PM | #192 |
Member#: 138952
VIC
Vehicle:2011 STI Hatch Pearl White |
Hey just a quick question! Please note I am very new to this stuff so please be nice!
Anyways, when a car is on the dyno do the fans run at the same speed the entire time through a pull? Or do they increase in speed to try and simulate real world/street conditions? I know they would never be able to generate 100+mph worth of air flow but wouldn't the lack of "ram air" really affect things? I remember watching AMA superbike racing and the comentators were saying that the bikes HP would increase like 20hp at top speed because of the ram air effect on the engine... Wouldn't this also apply to cars? Wouldn't a car be getting way more air into it on the street than on the dyno? Thanks, Jay |
04-29-2007, 11:41 PM | #193 |
Member#: 97
its way more complicated than that, but in a nutshell
these are TURBO cars, there is NO ram air effect. The only thing that changs with any significnce is ambient air temp and intercoooler breathing (although there are a few soobs out there with NACA turbo inlets those guys know better). Furthermore, the majority of the cars are MAF based cars, the total air in gets measured, and tuned for, irrespective of whether its forced in or not. but to answer, the fans do have speed adjustment, but we've figured out the 'sweet spots' for most cars the intercooler fanning simulates realistic airflow on the intercooler for approx 100 km/h. This is not a "guess" - you can calculate the cross section and do the math. It is also not derived from math but actual emprical data: the car will run the exact same ignition timing on the street at reasonable temps (i.e. 25C) in 3rd/4th as it will on the dyno (or more i.e. it can get better, not worse, on the street). the fans run fixed during a pull for a number or reasons but primarily #1 is you always want as much fanning as you can get, but not too much, and variable rates muck up other things like steady state, gear tests, etc. Finally, as most people DO NOT KNOW, the subaru actually goes "negative" in airflow at certain high speeds. You can watch the detonation jack right up at high speed as the air is actually going over the scoop and not even entering it. we also run the rad fans and keep the engine temps in check we also run the heat extraction fans ( you dont see in the video but they are there ) all the pulls we 'normalize' the intake air temp (as measured by the MAF) so that for a given car the pulls are consistent, and we also use an ambient intake air temp sensor which sits beside the airbox inlet. we can hold a car at 4500 RPM for a while, because we have EXTRACTION FANS which you dont see in the video moving hot air out of the room. This is totally seperate from exhaust extraction, this is just heat extraction. There are very, very, very few dynos around where you can actually hold a car at high RPM on boost. All of the above gives you the best simulation for a road tune. The big problem is actually "over fanning" where you can run more timing but it dets on the street. Through experimentation the setup is pretty accurate. And if you did want ram air you could just put the blower on the intake, and you would get nice unrealistic dyno numbers. |
04-29-2007, 11:55 PM | #194 |
Member#: 138952
VIC
^^ Cool thanks!
06-08-2007, 02:56 PM | #195 |
Member#: 65536
Vehicle:05 Impreza | STi Simple.less is more. |
Interesting. Around what speed does it goes negative in airflow??? Does this have to do with aerodynamics design problem at the front of the car??
06-08-2007, 03:15 PM | #196 |
Member#: 97
around 165 it starts to decrease
06-08-2007, 05:46 PM | #197 |
Member#: 121080
International
Vehicle:Who Dem? |
how do subarus that race get around that problem? Do they just alter the aerodynamics of the front?
07-13-2007, 04:55 AM | #198 |
Member#: 125450
VIC
Vehicle:Gone 07 SWP STi LTD 07 Nissan Nismo 4x4 |
I just had mine done on Monday at RR but my torque #'s are low not sure if the heat had something to do with it. I have a 07 STi Ltd with SPT intake, Cobb ap v2, and Cobb Catted DP with SPT 3" catback exhaust. I just did a track day at mission a couple of weeks ago and I think my clutch was slipping a little, could this be why? Or should I get an oil catch can? Maybe some oil getting by? I was getting some major flutter and weird surges but a protune deffently helped. I would highly recommend it to any 07STi owners out there. |
07-13-2007, 02:44 PM | #199 |
Member#: 5851
VIC
For the above chart, the BASELINE is the COBB tune. The others are ours. We would normally see greater increases. Part of the reason would be the catted DP, some blow-by could also gum thing up a bit. Plugs and injectors down the road will also make a difference.
For those that are doing track days, especially with sticky tires and good suspension I would STRONGLY recommend getting a catchcan and keeping a very good eye on your oil as these cars get a LOT of blow-by. |
07-13-2007, 03:39 PM | #200 |
Member#: 97
couple of comments, the after torque is not that low compared to other similar cars (post custom tune) with similar setups, its normally in the 270 range on our dyno, but yes it was hot. Like Jamie said, the blue line is the cobb stg 2 map. You can see the boost oscillations in the torque curve :-) The dyno is really used as a tool to compare before and after, so in that respect all is well.
FYI, if you go to a track, the catch can thing is really important, as is having the 'right' amount of oil. The blow by is not really blow by, its normally oil surging into the heads when pulling Gs then getting sucked into the intake. It looks like blow by :-) This is real, very real if you have stickies, suspension, or fast car, especially if you combine all three. Just be careful. Guys that install the "hawt JDM catch can" on the crank vent only never address this problem... and too much oil makes it worse. Too little drops the pressure on corners. You want it (normally without a dented can) probably just below halfway for a "normal" car without a baffled sump, lower as power+grip goes up if you dont baffle. |
I-Club/NASIOC: BC Member's Car Pics | Happy_Days | Vancouver Impreza Club Forum -- VIC | 8019 | 08-19-2021 06:16 PM |
Need Members' Help - Salvage Vehicle | Keenan | Southern California Impreza Club Forum -- SCIC | 5 | 06-09-2008 05:42 PM |
New High Score on our Dyno 415.8 whp | WHITE GF8 | Proven Power Bragging | 7 | 08-12-2005 02:05 AM |
2002 Headwaters Club Rally Stage Scores | jmullan | Motorsports | 0 | 05-13-2002 03:46 PM |
Dyno results posted from NW i-club Dyno Day! | sponaugle | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 26 | 06-04-2001 10:30 PM |
