04-26-2022, 08:02 PM | #1 |
Member#: 326377
SCIC
Vehicle:2006 WRX Wagon Aspen White |
AJ’s 2005 LGT EZ30R Turbo, 6mt
Picked up a rolling chassis in October 2020, and have been working on it slowly since then.
Started by adding sti Brembos all around, as well as a 2005 sti 6mt with matching R180. Went with a driveshaft shop 1 piece carbon fiber driveshaft, as well as their 1000hp rear axles. Added some aluminum front control arms, and Whiteline sway bars etc. Then I made the decision to complicate things and instead of a ej25 with plenty of off the shelf aftermarket options, I opted for a jdm ez30r. I began designing an equal length header, which took way longer to come up with a design than it should have. Picked up a gtx3584rs ii Built the primaries out of 321ss 1.5”sch 10 pipe. Picked up a haltech elite 2500 and premium harness Sent from my iPhone using Tapatalk Sent from my iPhone using Tapatalk
04-26-2022, 08:07 PM | #2 |
Member#: 326377
SCIC
Here’s some pictures from along the way
Sent from my iPhone using Tapatalk |
04-26-2022, 08:36 PM | #3 |
Subtly Outspoken
Moderator Member#: 238
Vehicle:OG05 STi 51E |
Very Cool.. interesting Drivetrain choice... I like it .. hopefully you are following Smeedia on You-tube.... WHen do you expect to get it running??
Good Luck Bill |
05-24-2022, 12:06 AM | #4 |
Member#: 326377
SCIC
Something like this Sent from my iPhone using Tapatalk |
05-25-2022, 02:15 AM | #5 |
Member#: 92894
BAIC
Vehicle:2015 Wrx - fury kit silver duh |
What are you HP goals? Any plans on building the motor?
05-25-2022, 09:08 AM | #6 |
Member#: 326377
SCIC
05-25-2022, 09:41 AM | #7 |
Member#: 179775
South East
Vehicle:03 WRX/15 FXT 14 BRZ/ 92 SVX |
Very cool build, nice work!
06-19-2022, 01:50 PM | #8 |
Member#: 326377
SCIC
Happy father day everyone! Sent from my iPhone using Tapatalk |
06-19-2022, 03:00 PM | #9 |
Member#: 525652
SWIC
Vehicle:2006 STI WR Blue |
Nice work on those headers, they are coming out great.
06-19-2022, 08:19 PM | #10 |
Member#: 326377
SCIC
06-21-2022, 06:42 AM | #11 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
Impressive fab job, came out great!
06-21-2022, 08:03 AM | #12 |
Member#: 179775
South East
That's awesome! Are you going with a rear mount radiator or is there clearance up front for everything?
06-21-2022, 08:08 AM | #13 | |
Member#: 326377
SCIC
I plan on doing front mount rad with an awic setup. I also added a bend at the collector to bring the turbo closer to the motor. I think I’ll be able to fit everything Sent from my iPhone using Tapatalk |
06-21-2022, 08:09 AM | #14 | |
Member#: 326377
SCIC
06-24-2022, 08:15 AM | #15 |
Member#: 179775
South East
Nice! Are you mounting the AWIC in the factory IC location?
06-24-2022, 09:10 AM | #16 |
Member#: 326377
SCIC
07-10-2022, 04:27 PM | #17 |
Member#: 326377
SCIC
Moved the turbo closer to the engine Sent from my iPhone using Tapatalk |
08-21-2022, 04:18 PM | #18 |
Member#: 531139
Sheesh
08-21-2022, 05:17 PM | #19 |
Member#: 326377
SCIC
Decided to open another can of worms by deleting the brake booster and abs, before I drop the motor back in. Going to get a chase bays dual piston kit. Sent from my iPhone using Tapatalk |
08-22-2022, 06:45 AM | #20 |
Member#: 524021
E. Canada
Vehicle:2021 STI 2002 WRX, 2023 Crosstrek |
This is a very interesting build. I love the detail pictures of the header fabrication. Do you do the welding yourself? The prep and execution look really good!
Do you anticipate needing additional shielding or a turbo blanket up front? |
08-22-2022, 08:04 AM | #21 | |
Member#: 326377
SCIC
Thank you! Yes, I’m a pipe welder by trade. This is my first (and last) header. So much work goes into prep, and purging etc. yes I plan on using a turbo blanket, as well as a heat shield to protect the pulley Sent from my iPhone using Tapatalk |
08-22-2022, 08:49 AM | #22 |
Member#: 454659
Vehicle:2004 WRX Wagon Java Black Pearl |
This thing is gonna be so wicked! Hope you share some startup videos when you get to that point.
08-22-2022, 09:22 AM | #23 |
Member#: 326377
SCIC
08-22-2022, 09:23 AM | #24 |
Member#: 326377
SCIC
09-05-2022, 12:20 AM | #25 |
Member#: 326377
SCIC
Spent a little on surge tank plumbing this week. 8an feed 6an return Ptfe braided line Sent from my iPhone using Tapatalk |
