01-20-2003, 12:39 AM | #1 |
Member#: 31986
Vehicle:2004 wrx sti wrb |
2004 STI curb weight?
hey i was just wondering if any body knows the curb weight of the new sti I have been trying to find out but had no luck finding the info on the web I would think it can be much heavier if any than the 2003 wrx
01-20-2003, 12:50 AM | #2 |
Member#: 23984
NWIC
Vehicle:2004 Forester XT Java Black Pearl |
It hasn't been released yet.
01-26-2003, 12:46 PM | #3 |
Member#: 2070
Vehicle:2012 Audi S5 Brilliant black |
here is your answer from global subaru...http://www.subaru-global.com/lineup/impreza/index.html
it is mentioned there that the curb weight in kg is 1450 x 2.2=3190 lbs. I just noticed it is the 2.0l so you can probably assume that the 2.5 might be heavier. Just my .02c Hope this helps |
01-26-2003, 02:20 PM | #4 |
Member#: 8351
Vehicle:2002 WRX Wagon |
No, it hasn't been released yet!
No, that isn't correct. That data sheet does not apply to the car we're getting. SOA has not released it yet. This has been discussed in a number of threads, but reasonable curb weight estimates are from 3000lbs up to 3200 lbs or so.
TRS |
01-26-2003, 02:31 PM | #5 |
Member#: 4011
Vehicle:2021 Type R LE Yellow |
Japanese's weight is not accurate. They take the jack, spare, no fluids and etc.. sort of like motorcycles number fudging wise.
For example an evo VII GSR 1400KG convert......3086LBS RS 1320KG Convert......2910LBS The 2L sti is 104 lbs heavier than the JDM evo. I figure the JDM GSR (ACD/AYC=U.S safty addition of bumper wt) and our STi is 2.5L so..... I'm saying the U.S. STI weighs ~3375-3400lbs to be realistic. I didn't take account of the weight of DCCD and I have no idea if that adds weight. I know the AYC for the evo is heavy. |
01-26-2003, 02:44 PM | #6 |
Member#: 8351
gtr-
Hehe. Looks like you're hoping it will weight 3400lbs!!! (I can see why). As I said before, this is all covered in other threads. There is no significant "safety" conversion for the STi as there was for the EVO. TRS |
01-26-2003, 05:59 PM | #7 |
Member#: 2997
It'll weigh over 3300lbs. If it was lighter than the Evo they would've announced it already. Do you REALLY think they don't know what it weighs yet? Same with price. They are trying to keep the hype up over the pure fact it has more hp than the Evo and the Dccd. I think the 2 cars will be close in performance because the Sti will weigh more and the Evo has better gearing. Just my opinion. I guess we'll see in a few months
01-26-2003, 07:37 PM | #8 |
Member#: 5489
NWIC
Vehicle:2013 FR-S AVO Orange |
No, they don't know what it will weigh yet. Really. They are still working on that. And it won't weigh 3400lb's, not even close to that.
Cheers, Paul Hansen |
01-26-2003, 07:47 PM | #9 |
Member#: 1305
AKIC
Vehicle:2000 Impreza |
Yea, the EVO's specs were released because it's done and ready for sale. That's why it'll be here in what, a month or so? The STI is still 4 or 5 months out. Why do you think that is, because they're still working on the production version.
01-26-2003, 08:16 PM | #10 | |
Member#: 2997
I mean really. I guess its possible they are busting there butts trying to shave a little weight here and there...but I doubt it. We already know it comes minus the stereo, etc. We know hp/torque, that it'll have dccd, etc. Hardly sounds like they are still working on it. Why don't you think it'll be over 3300lbs shirokuma? |
01-26-2003, 09:48 PM | #11 |
Member#: 5489
NWIC
You saw hand-built custom cars at the auto-show.
Yes, the final, production car will be like them - but they haven't finished it. And yes, they are very busy shaving off weight. And, for certain reasons, 3300lbs would be too heavy for some certain goals to be met, thus they are making sure it will not be that heavy. Last, and not least, it is not based on the standard STi body shell. It's based on the Spec C bodyshell with further tweaking. Cheers, Paul Hansen |
01-26-2003, 10:58 PM | #12 |
Member#: 4011
shirokuma,
The JDM WRX weighs 1340kg Agreed? The JDM 2L STi weighs 1450KG Agreed? Difference in wt between sti and wrx is 110KG for the two cars right? 1kg=2.20462262185 110KG=242.508LBS US WRX weights 3085 lbs I feel Adding the wt difference between JDM STI and JDM WRX to the U.S. WRX is Fair??? 3085lbs + 242.046lbs = 3327.5lbs So it's 3327.5lbs is my guess if we do not have DCCD and 2.5L but we do so how in the world would you think it's under 3300lbs? Do you really believe the amount of weight saved from the rear glass and the stereo will be more than the 2.5L and DCCD? We have A/C and it's has spec c glass to account for that big wing, J/K. |
01-26-2003, 11:02 PM | #13 |
Member#: 2997
My guess is that they are trying to get it to just under 3300lbs. We'll see.
Shirokuma, do you think it'll be lighter than the US Evo? |
01-26-2003, 11:04 PM | #14 |
Member#: 8351
For those of you who think it'll weigh 3300, 3400lbs, etc. You are forgetting that there is already a light-weight STi, the spec C (with all the goodies we will get). The weight of the MY02/03 US WRX seems irrelevant--it is history. Look at it like this.
The current (new front-end design) JDM STi curb weight is 1440 kg (3168lbs). That would seem to be the upper limit to what our car will weigh. The STi RA Spec C (with 17" wheels) weighs 1350kg (2970lbs). That would seem to be a good low end estimate, as the major thing we have that it doesn't is AC/(heat?). The specs on the US STi more closely resemble a Spec C than a STi. __Closer to a spec c than an STi__ if you doubt it, list them all out and summarize the differences. Sure, the spec c removes a bunch of small things and that adds up, but it also has what looks to be a heavier twin-scroll manifold and downpipe. The composite intake manifold, 2.5L displacement (maybe a wash, probably not significant either direction), and DBW of the US STi all reduce weight though, and counter that somewhat. The spec c (17" rims) has a spoiler, just not the big one. The spec c also doesn't get a front strut bar (neither do we, but the JDM STi does...). The more I look at it, I think we are getting a slightly more civilized version of the spec c... The EVO is still potent, and Subaru needs to get the weight and price right yet. They've nailed it so far, my bet is that they are going to put two more nails in the coffin yet. TRS ps- From what Jon (in CT) said about the gas guzzler tax and keeping weight low (to help mileage) makes a lot of sense as to why the weight and MSRP aren't known yet. If the MPG is too low (below 22.5 I think) then we get a $1000 gas guzzler tax... Keeping the weight down means a lot to Subaru now. And if shirokuma is right about the spec c shell being used for our STi... Last edited by ToddStratton; 01-26-2003 at 11:40 PM. |
01-26-2003, 11:37 PM | #15 | |
Member#: 5489
NWIC
In other words, it weighs 22lbs more than a standard JDM WRX. So take this a little farther, add in the fact that STi is trying to lighten it further than that, and you get a USDM STi that could weigh less than the USDM WRX. And, yes, that is their goal, and no, they are not finished yet, and certainly were not finished with the production car by the time of the auto shows. Cheers, Paul Hansen |
01-26-2003, 11:39 PM | #16 | |
Member#: 5489
NWIC
It weighs 1320kg without the (relatively) heavy 17" wheel package and brembos. Cheers, Paul Hansen |
01-26-2003, 11:40 PM | #17 | |
Member#: 5489
NWIC
01-26-2003, 11:47 PM | #18 |
Member#: 8281
Vehicle:1967 Alfa Romeo GTA |
I really like what I am hearing from Paul Hansen's rumour mill - spec C weight. I wonder what other trickeries in addition to the spec C shell, composite manifold, drive-by-wire STI will have up their sleeves to achieve this weight goal. This cannot be easy to do. I can't wait to see how far they are gonna get with this.
01-27-2003, 12:26 AM | #19 |
Member#: 2997
The more I think about it, Subaru really has to bring a product that will justify the 4k or so higher price tag than the Evo. Just like the Evo has justified its 4k or so price increase over the regular Wrx. We are really going to have 3 different levels of cars with 3 levels of price tags. Although, the Evo and Sti will probably be close to each other when it comes to handling.
01-27-2003, 12:41 AM | #20 |
Member#: 8351
And for those of you thinking "if they are really serious about weight, why don't we get the lighter spec c with 16" wheels" ...cause it looks like this:
And all the talk about having no pass-through in the rear seat. Also just like the spec c. http://www.subaru.co.jp/impreza/sedan/08/08_02.html TRS |
STi curb weight speculation poll | superg | News & Rumors | 11 | 03-28-2007 04:43 PM |
Curb Weight vs Gross Weight | Kevin Thomas | Normally Aspirated Powertrain | 11 | 11-06-2006 10:58 PM |
differences between Curb weight and Gross Vehicle Weight ? | Extraze | General Community | 19 | 06-23-2004 11:26 PM |
curb weight vs. gross weight | mtn-boy | Technical Forum Archive | 2 | 08-05-2000 02:53 PM |
