Tire & Wheel Forum sponsored by The Tire Rack |
08-11-2013, 11:20 PM | #2201 | |
Member#: 317045
Vehicle:2012 WRX Hatchback SWP |
57fxx
08-12-2013, 06:59 AM | #2202 |
Member#: 260603
BAIC
Vehicle:2012 WRX Premium Dark Grey Metallic |
Hey everyone! My first disclaimer is that I am a noob to the car world in general, and self-education by reading threads like these is helping a lot. I have a 2012 WRX, and have settled on Work Emotions either the XD9 or 11R. The XD9 is 18x9 with a +43 offset. The 11R is either 18x8.5 with a +47 or 18.9.5 with a +38.. Aside from being indecisive on which style I ultimately want, I'm curious if one wheel is a better choice over another?
08-12-2013, 03:29 PM | #2203 |
Member#: 220095
SWIC
Question I've been debating on for a while now.
I found a good deal on a 18x9 e35 set with 235s Star Specs on (It'll eventually go 245s once the SS wears out), I'm still on stock suspension as of now. The thing is winter is coming up in a few months and I dont want to get the set then put them on and buy coils then it's winter time and swap to the winter set, its either: 1: Get the 18x9s and rock them on stock suspension (wide wheels and stock suspension dont go together well), and get coilovers in the spring time. 2: Pass the killer deal and just stay on stock wheels and suspension until spring and probably will be spending more than the killer deal now. 3: Get the set and just hide it until spring (going to be hard to ignore it ha) 4: Your suggestions? |
08-12-2013, 04:30 PM | #2204 | |
Member#: 233957
Vehicle:2012 STI Hatch SWP |
08-13-2013, 12:09 PM | #2205 |
Member#: 220095
SWIC
Got a chance to use the 18x9 with dunlop star specs for autox this week, its either using my OEM 2013 WRX with OEM tires or use the 18x9 e35 Star Specs, my only concern is are they going to be rubbing in the rears since the fenders are not rolled, opinions?
08-15-2013, 09:15 AM | #2206 |
Member#: 306478
South East
Vehicle:2016 Focus RS stock |
Ok someone please help me with this!!! I want to see if I am on the right track as to figuring out fitment. I am on the fence between two different sized wheels. 18x9 +35, and 18x9.5 +44 (or 43 can't remember). Tires would be either 245/40 to 265/35 depending on clearance. Wrx has konis and RCE yellows.
Ok the numbers. Stock wheel is 8" wide offset is 2.087" leaving 1.913" from hub to outer lip. From hub to inner edge of wheel is 6.087". Next the 18x9 +35. Offset is 1.378" leaving it with a big lip and 3.122" from hub to outside edge of wheel. And 5.878" hub to inner edge of wheel. Next 18x9.5 +44. Offset is 3.018" leaving 1.732" hub to outer edge of wheel. And 7.768" hub to inner edge of wheel. So what's next is the big question. From this I can see the +35 wheel really moves the whole wheel out and would seem to run into clearance issues with the fender. The +44 wheel would be almost 1 3/4" closer to the strut on the inside but not come out nealry as far as the other wheel. The wheel bearing are prob gonna see more wear on that +35 wheel as well. Now I guess I need to get under the car and measure the space between the strut and wheel now and see what that is to check for clearance? It should be ok since the machv wicked awesome was designed for the GR widebody and that is the specs on that. Thanks for the insight. Edit.. It apparently isn't as cut and dry as I thought. I got a call back from my tuner and he informed me it would be 8mm closer to the shock body for the 9.5" +42 offset Last edited by Dmochowski; 08-15-2013 at 03:59 PM. |
08-15-2013, 12:10 PM | #2207 |
Member#: 355638
NESIC
Vehicle:2011 Wrx Obsidian Black |
I have an '11 wrx hatch and I'm looking at 18x10 +38 Work XD9s and I'm looking for a little bit of stretch.Is a 245/35r18 a lot of stretch using a Continental Extreme Contact DW? I am lowering it on Isc N1 coilovers but how low I go depends on the clearance. So is that gonna be a lot of stretch if anyone has any pictures for reference that would be nice. I've googled it and had no luck :/
08-15-2013, 12:55 PM | #2208 |
Member#: 324709
Vehicle:2012 WRX Sedan SWP |
08-15-2013, 01:49 PM | #2209 |
Member#: 289516
NWIC
Vehicle:2012 WRX ISM |
Yah don't stretch a 35. Thats just preposterous. Just run a 255. You will be ok.
08-15-2013, 03:36 PM | #2210 |
Member#: 236952
Vehicle:2010 WRX (SSM) Stg 2+ 310/370, 6sp R180 |
i wouldnt run less than 265 with a wheel that wide.
08-15-2013, 06:28 PM | #2211 |
Member#: 362867
Vehicle:2013 WRX WRB |
I am in kind of the same boat as the guy above. I am looking at Rota Grids in 18x9.5 +38 running federal SS595 in 255/35/18. Dropped on isc N1s. Dropped about 1.75"
Used this calculator, and I think i will be good. http://www.rimsntires.com/specs.jsp Can someone confirm before I make the purchase? |
08-15-2013, 06:30 PM | #2212 | |
Member#: 362867
08-15-2013, 06:40 PM | #2213 | |
Member#: 324205
Vehicle:F30 335i; 2016 Crosstrek; 2013 WRX(sold) |
This is pretty standard fitment for these cars. Will need a roll front and rear and you're good.
08-15-2013, 06:41 PM | #2214 |
Member#: 362867
08-15-2013, 08:11 PM | #2215 | |
Member#: 306478
South East
08-16-2013, 03:17 PM | #2216 | |
Member#: 12029
In general, we do NOT like rolling the front fenders on this car. It's only a single layer of metal, and it's very hard to avoid rippling or distorting the fender by rolling it. There's a good amount of clearance, so even very large tires can fit without rolling the fronts, assuming you keep your offset high, as I advise in the very first post of this thread. --Dan Mach V FastWRX.com |
08-16-2013, 03:22 PM | #2217 |
Member#: 324205
I needed to have the fronts rolled as well with a 265/35 18x9.5 +40, and yes, the fenders don't look so good anymore. I guess at least now I can run a more aggressive setup in the future.
08-16-2013, 07:04 PM | #2218 | |
Member#: 362867
08-16-2013, 11:37 PM | #2219 |
Member#: 361231
Vehicle:2017 STI Limited Crystal Black |
Anyone have Rota g-forces in either 17" or 18" on a 11+ hatchback and stock suspension? If yes, can you share pictures and details on the tire and offset setup? Any rubbing problems?
08-17-2013, 01:55 PM | #2220 |
Member#: 246071
Vehicle:2010 impreza 2.5i white |
http:// http://m1319.photobucket.com...l?o=0&newest=1
http:// http://s1319.photobucket.com...tml?sort=3&o=3 Couple shots of my fast hayukas 18x9 +35 offset. Rolled aggressively in the rear. Stock suspension. |
08-17-2013, 02:46 PM | #2221 | |
Member#: 362867
08-17-2013, 04:16 PM | #2222 |
Member#: 337792
South East
Vehicle:2013 WRX SWP |
Here's what I'm looking at. 18 x 9.5" +48. Wondering how the fit will be on my 13 WRX hatch with the New Tein Street Flex set to Tein spec. I believe its around 1.5" lower. Wondering how flush these will sit and if I will need to roll or pull fenders at all? Thanks in advance for any help!
08-17-2013, 06:58 PM | #2223 |
Member#: 361231
08-17-2013, 07:11 PM | #2224 |
Member#: 97135
NWIC
08-18-2013, 10:17 AM | #2225 |
Member#: 341775
South East
Vehicle:2014 WRX - 5dr Rally Blue |
BUMP
Originally Posted by Mach V Dan View Post You're going to be limited mostly by how much "bulge" you want to have. A 235 width is a good match for an 8" wide wheel. If you wanted to go with something wider, like a 255, it would start to look kind of plump on the wheel. Here's a 255 on a an 18x8" +48 wheel: That's not TOO bad, but I probably wouldn't go any wider. Any of those widths will have no problems with clearing the suspension and fenders. --Dan Mach V FastWRX.com This is the kind of setup I have been looking for!! First off, let me begin by saying thank you Dan and everyone else on the thread with your excellent tips and expertise knowledge on the subject. This kind of information is very beneficial. Now to the point... If you don't mind, what set of wheels are these? Rota Formula wheels? Also, you say the tire was a 255. Is this 255/35R18? I want to keep stock suspension/height. I'm assuming this car was lowered. I shouldn't have any issues with this selection of wheels/tires on stock height should I? Thanks for the help. I really like this setup, but after reading some more its not preferred because of the handling loss (roll on corners). I would hate to diminish my handling, but how much worse is it? I see a 245/40R18 is recommended on an 18x8" wheel. I wish I could see in comparison... |
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L | acetmi | Private 'Wanted' Classifieds | 0 | 06-14-2006 12:43 PM |
need somewhere to get wheels and tires asap | bubba03wrx | Southern California Impreza Club Forum -- SCIC | 22 | 04-02-2004 09:14 PM |
Wider wheels and tires in the rear | SilveRexy03 | Tire & Wheel | 14 | 11-04-2003 04:49 PM |
WEre is a good place to buy wheels and tires | MilfordSubaru | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 05-25-2002 01:14 PM |
Where to buy wheels and tires? | wilddave1 | Brakes, Steering & Suspension | 4 | 03-21-2002 02:20 PM |
