Tire & Wheel Forum sponsored by The Tire Rack |
01-27-2018, 09:24 PM | #4551 |
Member#: 471151
Vehicle:2011 WRX sedan Dark Gray Metallic |
I was looking at Rays Wheels and stumbled across this!
01-28-2018, 12:00 AM | #4552 | |
Member#: 481253
01-29-2018, 08:25 PM | #4553 |
Member#: 481308
Can someone suggest a tire size for a 18x9.5 +35 wheel? I have rear fenders rolled and front are untouched, have about 1 finger gap between top of the stock wheel/tire and fender arch, on coilovers. 2014 hatch, from what I understand from posts in this thread is 255/35/18 should be the biggest I want to go with, I was curious to see if this is correct, and if I need to get adjustable rear camber arms or not, I have cabmber plates in the front and should be good there.
02-01-2018, 08:48 PM | #4554 | |
Member#: 480332
RMIC
Vehicle:2008 STI GREY |
02-01-2018, 11:06 PM | #4555 | |
Member#: 370406
Vehicle:- |
02-14-2018, 01:13 PM | #4556 |
Member#: 365633
Vehicle:2013 WRX DGM |
I'm confused. I read the virtues of staying close to stock offset, but everyone and their brother run +30, +35, +38, etc?? Is it not that prematurely damaging/wearing?
02-14-2018, 01:30 PM | #4557 | |
Member#: 482121
2013 WRX Sedan
I have a stock height 2013 WRX Sedan. I’m looking at the the Enkei GTC01rr wheels for my ride in 18x9.5 / 5x100. This wheel only comes in a +35 offset, will this wheel work and what is the meatiest tire I can put without rolling the fenders. Thanks, Telly |
02-14-2018, 02:11 PM | #4558 | |
Member#: 348236
Vehicle:2011 STI Hatch PBP |
Subaru's seem to have either weak or bad quality wheel bearings from everything I've heard, but I have not seen a failure specifically from a different wheel offset. |
02-14-2018, 03:42 PM | #4559 | |
Member#: 12029
245/40R18.
Thanks, but it's not necessary to quote the entire first post. Quote:
--Dan Mach V FastWRX.com |
02-14-2018, 06:04 PM | #4560 |
Member#: 482125
I have a 2011 impreza sti hatch and i wanna know the best wheel and tire fitment for it. I dont plan on lowering it really at all if anything ill raise it in the winters. Its my daily so i dont want something geared towards strictly track.
02-14-2018, 06:56 PM | #4561 |
Member#: 331611
Vehicle:2013 Wrx 5dr DGM |
Hey I just ordered some nt03m 18x9.5 +40 offset for my car. looking for suggestions on tires. I don't mind a little stretch. The car is lowered and I put some pictures up for reference. I really don't want to roll my fenders so I don't mind raising the car up a bit. I also wouldn't mind a little stretch on the tires if I can avoid rolling the fenders. Any help would be appreciated.
https://i.imgur.com/SSUmHkj.jpg https://i.imgur.com/xN4TGSk.jpg |
02-16-2018, 05:17 PM | #4562 | ||
Member#: 12029
02-16-2018, 05:24 PM | #4563 |
Member#: 377862
^ True dat!
02-26-2018, 10:48 PM | #4564 |
Member#: 391692
So I've read pretty much the entire thread and my head is starting to spin with all of the different combinations that can be ran..
I have an 11' hatch, stock suspension and ride height. Not interested in rolling the fenders and will not be lowering the car. Ive basically narrowed my choices down to a few different options.. Any issues I would run into with running an 18x8.5 +35 with a 245/35 or 255/35? |
02-26-2018, 11:15 PM | #4565 | |
Member#: 391692
02-28-2018, 11:41 AM | #4566 |
Member#: 363673
Vehicle:2014 WRX (Sedan) DGM |
Just wanted to update: I have a 2014 WRX Sedan with stock Suspension. Got the Rota SVN-R in 18x9 +40 wrapped in MPSS 265/35. Just beware that upsizing will affect your cars performance. I found that upsizing tires made the car look great, I felt the car was a bit sluggish though. You'll be sacrificing some performance for aesthetics. I DID roll my rear fenders as there was slight rub, but no problems after the roll. No need to roll the front fenders. I put my stock wheels back on, 17x8+53 wrapped in brand new MPSS 235/45 and the car was much happier! It's night and day difference.. so just a heads up.
03-03-2018, 12:58 PM | #4567 |
Member#: 126131
SCIC
Vehicle:11 wrx sedan black pearl |
is 245/40 an okay tire to run on a 10" wheel?
03-03-2018, 02:20 PM | #4568 |
Member#: 377862
Too much stretch. IMO
03-03-2018, 02:36 PM | #4569 |
Member#: 348236
Most tire manufacturers recommend a 9.5" max width wheel for that tire, which means mainstream shops (Tire rack, discount tire, etc.) actually won't mount that.
Miguel at the street corner will though. Personally, I just think it would look stretched and I don't like that. |
03-03-2018, 04:13 PM | #4570 |
Member#: 126131
SCIC
i thought it would be stretched as well. saw them on some local cars and it seems it couldve passed for a 265. i'll probably go with a 265 though
03-04-2018, 08:48 PM | #4571 |
Member#: 395225
Questions on running taller tires on the stock sti, rims. 245/45/18s? Yes I know it will mess the speed up. Not lowered won't be lowering, looking to lift eventually but how much taller can be ran without hitting the struts
03-05-2018, 03:56 PM | #4572 |
Member#: 467756
After going through about 60+ pages in this thread I think I've come to a conclusion about the wheel and tire size I've been looking at, but I want to get a definitive answer
I'm looking at a 18x9 +35 wheel fitted with a 255/35/R18 tire. I'm running stock suspension with no plans to change it. Based on the research I've done, this set up will rub because a +35 offset is too low and the wheel will be pushed out too far. Is this a correct assumption? Thanks |
03-05-2018, 04:03 PM | #4573 | ||
Member#: 12029
03-17-2018, 04:55 PM | #4574 |
Member#: 470096
Vehicle:2014 WRX Sedan |
Quick question. I'm ordering summer wheels for my '14 WRX sedan. Decided on Work T7R's 18x9.5 +38. Tire size 265/35R18.
I'm lifted on King Springs, will I still have to roll the rear fenders? |
03-17-2018, 05:08 PM | #4575 |
Member#: 377862
Yes you will
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L | acetmi | Private 'Wanted' Classifieds | 0 | 06-14-2006 12:43 PM |
need somewhere to get wheels and tires asap | bubba03wrx | Southern California Impreza Club Forum -- SCIC | 22 | 04-02-2004 09:14 PM |
Wider wheels and tires in the rear | SilveRexy03 | Tire & Wheel | 14 | 11-04-2003 04:49 PM |
WEre is a good place to buy wheels and tires | MilfordSubaru | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 05-25-2002 01:14 PM |
Where to buy wheels and tires? | wilddave1 | Brakes, Steering & Suspension | 4 | 03-21-2002 02:20 PM |
