Tire & Wheel Forum sponsored by The Tire Rack |
11-15-2017, 09:40 AM | #4526 | ||
Member#: 12029
--Dan Mach V FastWRX.com
11-22-2017, 02:14 PM | #4527 |
Member#: 455777
SCIC
Vehicle:2013 WRX Hatch Plasma Blue Pearl |
Enkei T6s
Hey y'all, Tirerack.com doesn't list an 18x9.5 for my car, the 2013 wrx hatch. But if i set a brz as my car, it has an option of the rear wheels being 18x9.5 with an offset of 45. My question is, will I run into fitment problems with that wheel and an 265/35 18 tire? The bolt pattern matches at 5-100 but i'm not sure what the bore diameter of the wheels are. Will I have problems when driving the car with full capacity, 4-5 passengers? Thanks y'all! The car is on stock suspension. Last edited by teewrxx; 11-22-2017 at 04:14 PM. |
11-22-2017, 02:41 PM | #4528 |
Member#: 348236
Vehicle:2011 STI Hatch PBP |
Are they the Enkei Raijin? They should fit on stock suspension, hub bore is the same, but the type of tire you get might force you to roll the rear fenders.
11-22-2017, 04:13 PM | #4529 |
Member#: 455777
SCIC
11-22-2017, 04:16 PM | #4530 | ||
Member#: 395955
Vehicle:2021 Mazda 3 Turbo 2017 MX-5 RF Club |
I'm also pretty sure that the 11-14 and 15+ cars share almost identical fender space and offsets. But I'm not sure if there's any variances from sedan to hatchback. |
11-22-2017, 05:28 PM | #4531 | |
Member#: 12029
--Dan Mach V FastWRX.com |
11-22-2017, 05:30 PM | #4532 | ||
Member#: 12029
11-22-2017, 07:14 PM | #4533 | |
Member#: 395955
I know. But stock offset is the same on both cars and fender clearance is very very close even with the difference in bodies. 18x9.5 +38 (common) fits about the same on both generations. At least the sedans. |
11-23-2017, 08:51 AM | #4534 |
Member#: 478112
I need help
Dear friends!!! I plan to install the Advan RZ2 r18 9.5jj +45 offset wheel disks with the tire Advan Neova AD08 245/40 r18 on the Impreza WRX STI 2010. Would they rub against the rear fenders? Will they stand on Brembo in front?
Thanks for any answers !!! If you have a photo with such parameters of the disks on the car, I will be grateful !!! Last edited by curren2007; 11-23-2017 at 08:56 AM. |
11-28-2017, 04:33 PM | #4535 | |||
Member#: 455777
SCIC
What if I run the 245 on the wheel? will it fit? Also am I to expect a "harsher" ride on 18's versus the 17? will I also "lose performance" as other people say? |
11-29-2017, 12:51 PM | #4536 | ||
Member#: 12029
Yes.
11-29-2017, 02:55 PM | #4537 | |
Member#: 455777
SCIC
11-30-2017, 10:32 AM | #4538 | |
Member#: 12029
11-30-2017, 06:17 PM | #4539 | |
Member#: 455777
SCIC
12-04-2017, 02:41 PM | #4540 |
Member#: 460590
At +45 you should be fine, especially with a 235. I run a 17x9 +38 Rota Titan and a 255/40r17 RT615k+ (Which runs really wide) on stock suspension and I get minor rubbing in the rear over significant bumps. I hear them scrub a few times a week tops. Lowering soon and adding camber which I'm hoping will alleviate the rubbing.
12-30-2017, 09:16 PM | #4541 |
Member#: 479798
Need help
Hey I’m looking for advice, I recently purchased 17x9, +30 wheels for my 2013 WRX, hatchback. I was hoping to run a 255/45 on these, will I have any fitment issues? I’m stock suspension. Any help would be great
01-01-2018, 10:54 PM | #4542 |
Member#: 475701
I have old rims sitting around in my garage that I took off my old car
They are rim size 17x10 with 15 offset and tire size 215/45/17 Will they fit my 2011 WRX hatchback? Will I experience any complications? Any info will help, thanks! Last edited by Dlc94; 01-01-2018 at 11:05 PM. |
01-02-2018, 06:58 PM | #4543 |
Member#: 151814
SCIC
Vehicle:2014 WRX SWP |
Don't know if your Serious, but 215 on 10" doesn't seem safe. Offset seems to low.
Subaru WRX/STI offset range is in the 30's. +15 offset might touch suspension or some trailing arm. Also will require a custom alignment. |
01-04-2018, 05:38 PM | #4544 | |||
Member#: 12029
True.
01-22-2018, 01:37 AM | #4545 |
Member#: 480332
RMIC
Vehicle:2008 STI GREY |
I have had my eye on the Firehawk Indy 500's in 275/35's on 18x9.5 +35's for my 2008 STI. Currently I am on stock suspension but plan on getting coilovers at some point. I just don't plan on going any lower than an inch because of the s***ty roads here in Colorado. Comparing the Indy 500's and MSS, the 275 Indy 500 have a narrower contact patch than the MSS by 0.5" in 265's. The section with on the 275 Indy 500's are .2 of an inch larger than the 265 MSS. I got my fenders rolled in the rear already. Trying to make up my mind on 265's or 275's, I like the idea that the 275's are 25.6" tall compared to the stock 245/40's that are 25.7" Where the 265's are 25.3" tall.
I've already went through tons of post and looked at so many pictures, I just don't want to get the 275's and run into fitment issues. I think I'd be good but there's really no way to tell without test fitting. Dunlop SP 600 stock tire specs:245/40ZR18 93W SL 200 A A1,433 lbs. 51 psi 10/32" 25 lbs. 8-9.5" 8.5" 9.8" 8.4"25.7"813 265 Indy 500 specs: 265/35R18 97W XL 340 A A1,609 lbs. 50 psi 10/32" 25 lbs. 9-10.5" 9.5" 10.7" 8.9"25.3"823 265 MSS specs:265/35ZR18 (97Y) XL 300 AA A1,609 lbs. 50 psi 10/32" 26 lbs. 9-10.5" 9.5" 10.7" 9.8"25.3"822 275 Indy 500 specs:275/35R18 95W SL 340 A A 1,521 lbs. 51 psi 10/32" 26 lbs. 9-11" 9.5" 10.9" 9.3" 25.6" 815 |
01-22-2018, 11:26 PM | #4546 |
Member#: 370406
Vehicle:- |
Could I get help identifying the wheels on the car in the background, I've searched through a bunch of brand name and off brand 10 spoke wheels and found may similar ones, but not these exact ones, I love that setup. I know they're both member's cars, but even searching their profiles for history posts I came up with nothing.
01-22-2018, 11:43 PM | #4547 | |
Member#: 480332
RMIC
01-23-2018, 12:39 AM | #4548 |
Member#: 370406
Vehicle:- |
^Really appreciate that!
01-27-2018, 05:45 PM | #4549 |
Member#: 481253
Thoughts about this setup?
14 wrx hatch w/stock suspension Wheels: Enkei Raijin 18x9.5 +45 Tire Size: 265/35 or 255/35 Tire Brand: suggestions? If anyone has this setup, have to roll the rears? thanks! Last edited by cbuckles17; 01-27-2018 at 05:53 PM. |
01-27-2018, 08:28 PM | #4550 | |
Member#: 348236
6
I used 265/35 to keep the tire diameter the same as stock which I would recommend. You'll have to roll the rears with all stock suspension no matter the tire, if you want something more dd friendly, the Michelin pilot super sports are great. If you want something more summer aggressive, I'd look at the hankook rs4, direzza star specs, or nitto nt05s. Whatever fits in your budget. |
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L | acetmi | Private 'Wanted' Classifieds | 0 | 06-14-2006 12:43 PM |
need somewhere to get wheels and tires asap | bubba03wrx | Southern California Impreza Club Forum -- SCIC | 22 | 04-02-2004 09:14 PM |
Wider wheels and tires in the rear | SilveRexy03 | Tire & Wheel | 14 | 11-04-2003 04:49 PM |
WEre is a good place to buy wheels and tires | MilfordSubaru | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 05-25-2002 01:14 PM |
Where to buy wheels and tires? | wilddave1 | Brakes, Steering & Suspension | 4 | 03-21-2002 02:20 PM |
