Tire & Wheel Forum sponsored by The Tire Rack |
02-21-2017, 01:13 PM | #4426 |
Member#: 442346
Vehicle:2013 WRX SWP |
Anyone have pics of the 18x9.5 +38 rpf1's w/8mm spacers for clearing brembos? In particular, I'm looking for pics that show the flushness with the fender to see if it sticks out or not.
02-22-2017, 09:27 AM | #4427 | |
Member#: 12029
--Dan Mach V FastWRX.com |
03-02-2017, 12:05 AM | #4428 |
Member#: 463798
VIC
Vehicle:2013 STi Hatch WRB |
2013 sti wheel fitment
Mach help me out pls, I have a 2013 sti hatch, everything is stock except for rce sway bars, Can I run the Enkei PF07 18x9.5 +40 offset on 265/35 R18 BFGoodrich g-force sport comp-2 tires. Would I have to roll the fender and will there be any clearance issues with the strut or whatever? Hoping to get my summer setup ordered soon. Thanks
03-02-2017, 12:12 AM | #4429 | |
Member#: 12029
03-06-2017, 12:02 AM | #4430 |
Member#: 376415
So even if I was going with 18x8.5 wheels +30 would be a bad idea?
I dont know much about wheel fitment. |
03-06-2017, 08:29 AM | #4431 | |
Member#: 348236
Vehicle:2011 STI Hatch PBP |
This is an 18x8.5 with a +40 offset with 265/35 tires, so imagine an extra 10mm towards the fenders. There is almost an inch, and this is at basically full compression. |
03-07-2017, 12:29 PM | #4432 | |
Member#: 317045
Vehicle:2012 WRX Hatchback SWP |
From a steering response/feel perspective ... not very good. The further out you go from the stock offset the worse the steering feel/response becomes. The +30 offset pushes it out about 23 mm from the stock offset, and then the outer wheel lip is another 1/4 inch further due to the 0.5 inch wider wheels. Are you really set on the wheel design? If not, consider a wider wheel with a lower positive offset. For example, an 18x9, +40. That will only be about 3.65 mm inward than the +30 wheels and the +40 offset won't degrade steering feel as much. Still a good idea to roll. |
03-20-2017, 11:00 AM | #4433 |
Member#: 461774
Vehicle:2012 Sti hatch DMG |
Hate to be "that" guy but im buying summer wheels and tires soon for my 2012 sti hatch. Im looking at 18x10.5 wheels. They offer +40 and +20. Im wanting ti stay with stock metal but rolling the fenders doesnt bother me, just dont want to have to pull. Stock height and im looking to run 255/40 or 265/35.
Its also offered in a 18x9.5 with either +35 or +20 Any help is appreciated Last edited by Joe5688; 03-20-2017 at 11:24 AM. |
03-20-2017, 02:03 PM | #4434 | |
Member#: 12029
03-20-2017, 03:14 PM | #4435 |
Member#: 377862
03-20-2017, 05:32 PM | #4436 | |
Member#: 324755
BAIC
Vehicle:2014 WRX Hatchback WRB |
I have 18x9.5 +38 with 265/35 and they already poke out a few mms. 18x9.5 +40 to +45 would probably be perfect and only need a roll. |
03-20-2017, 06:55 PM | #4437 |
Member#: 461774
Ok thanks for your help. I wouldnt want more than a few degress of camber. Not looking for crazy flushness just something more aggressive looking than stock.
03-20-2017, 07:05 PM | #4438 | |
Member#: 461774
03-23-2017, 05:06 PM | #4439 |
Member#: 450437
Vehicle:2013 Subaru WRX Black |
Guide to fitting wheels and tires to the 2011-2014 WRX
Delete
03-24-2017, 12:51 PM | #4440 |
Member#: 383867
Vehicle:2013 WRX PBP |
Delete
03-30-2017, 09:05 PM | #4441 |
Member#: 457222
Vehicle:2014 WRX Hatchback Black |
Just went with 18x8.5" +45 rota grids in gold for my black WRX hatchback. So excited.
04-02-2017, 11:13 PM | #4442 |
Member#: 358692
South East
Vehicle:2013 wrx sedan OBP |
Coilover Clearance
Quick question for you guys
Recently, I installed tein coilovers and white line adjustable LCAs on my 13 wrx. I'm on the stock wheel with a 245/40/17. Alignment from local shop was good. Yesterday, I tried to lower the car a little and I am having clearance issues on the inside, the tire rubs the coilover. Lifted it back up to previous height. Did I adjust the camber in doing so? Can I not go lower because of the wider tire on the stock wheel/offset? I have a set of WedsSports sa-15R 18x9.5 +48 waiting to go on 265/35/18 Michelin as/3s. Will I have rubbing issues when installing these? I plan on getting another alignment the day I put them on, but need to be able to get to the shop without rubbing my way there. Thanks for the help. |
04-02-2017, 11:50 PM | #4443 |
Member#: 36838
Vehicle:2001 B50 RSTi Sedan 2011 DGM WRX hatch |
I assume this is on a sedan? Is the tire hitting the coilover body, or the lower adjustable spring perch?
If hitting the perch, you may need a different wheel offset, narrower perch, or shorter spring with a helper. If hitting the coilover body, your camber likely changed and you need to change it back. As wide as you are planning on going, you may need a shorter spring with a helper. |
04-03-2017, 01:38 PM | #4444 | |
Member#: 358692
South East
It was literally rubbing on the spring. It was fine before I tried to lower it a bit more. I think once I get my weds on, suspension set a right height, and alignment, I'll be fine. Just curious if it is because of the wider tire on the stock wheel/offset. I'm getting the tires put on my weds tomorrow and hopefully an alignment Wednesday morning. Will let y'all know how it goes. |
04-03-2017, 06:20 PM | #4445 | |
Member#: 465467
04-05-2017, 01:51 PM | #4446 | |
Member#: 358692
South East
Sad day
Update: these weds sport sa15r +48 do NOT clear the Tein Flex Z coilovers. It rubs the collar under the front springs. Unfortunately, I am going to have to use a 10mm spacer and longer studs. I'm just hoping that they do not stick out past the fender. |
04-05-2017, 07:36 PM | #4447 |
Member#: 324755
BAIC
That basically puts you at 18x9.5 +38. At stock height, the wheels poke out just a little bit on the front, but looks very flush at the rear. Since you are lowered, it will probably be flush with the fender.
04-05-2017, 07:43 PM | #4448 |
Member#: 324755
BAIC
What tire pressure do you guys run with the bigger setups? For daily usage, I've read people run the stock 33/32 PSI up to 40/38 PSI.
I have 18x9.5 +38 with 265/35 MPSS and do 35/34 PSI. Any higher and bumps feel very harsh, while the stock 33/32 PSI doesn't give as good of a feedback. |
04-06-2017, 05:37 PM | #4449 |
Member#: 12029
Sorry. It's a problem with the hosting service, Photobucket. It would be huge work for me to migrate all the photos to a new hosting place, AND then to update all the URLs. Photobucket says they are working to fix the issue.
04-07-2017, 07:47 PM | #4450 |
Member#: 465692
Vehicle:2011 WRX Hatchback Lightning Red |
2011 WRX fitment question
Hi,
I have a 2011 WRX hatchback, I am currently running the stock wheels and stock suspension with an STi brembo kit the previous owner put on the vehicle. I am looking at buying some new wheels soon, a set of Enkei T6S, 18x9.5 +45mm offset. I have been trying to figure out if these will clear my brembos, and I'm not having much luck. I don't want to buy these and then find out they don't clear, so if anyone has any experience with this I'd love to hear it, thanks! Also, will I need to roll my fenders at all? The tires i'm putting on are Hankook Ventus V12 Pros, 235/40/R18 |
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L | acetmi | Private 'Wanted' Classifieds | 0 | 06-14-2006 12:43 PM |
need somewhere to get wheels and tires asap | bubba03wrx | Southern California Impreza Club Forum -- SCIC | 22 | 04-02-2004 09:14 PM |
Wider wheels and tires in the rear | SilveRexy03 | Tire & Wheel | 14 | 11-04-2003 04:49 PM |
WEre is a good place to buy wheels and tires | MilfordSubaru | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 05-25-2002 01:14 PM |
Where to buy wheels and tires? | wilddave1 | Brakes, Steering & Suspension | 4 | 03-21-2002 02:20 PM |
