Tire & Wheel Forum sponsored by The Tire Rack |
01-12-2017, 11:55 AM | #4401 |
Member#: 317045
Vehicle:2012 WRX Hatchback SWP |
primarily rubbing issues ...
what I should have said is to be sure you roll enuf to fit some wider tires in the future. With the +30 offset and 265 wide tires, you may have to pull a little on the rears if you go lower. I guess my whole point is the decisions you make now may save you some extra work and $$ in the future ...
01-12-2017, 12:10 PM | #4402 | |
Member#: 97135
NWIC
wants to go hella flush. jesus man. |
01-12-2017, 12:26 PM | #4403 | |
Member#: 449820
:/ Yes. Because it's not everyday I'll be on the track. I'm not going to be racing with these Enkeis. What's wrong with getting wheels to full out the wheel wells better? The weight of the Enkeis are the same as the Spec C wheels. It's not like I'm gonna lower the car or get the car bagged or anything which I think is ridiculous. And FYI it is a real Spec C imported from Japan. Jesus man. |
01-12-2017, 12:27 PM | #4404 | |
Member#: 449820
Ok thanks buddy. Will give it some more thought before venturing that way |
01-13-2017, 12:11 PM | #4405 |
Member#: 317045
oh, wow, your Spec C is in the USA! I just assumed you were in Japan. I had imported a non-US Miata into the USA back in 1996. Wish I still had it today.
01-23-2017, 01:11 PM | #4406 |
Member#: 432274
Vehicle:2011 Forester Silver |
Help
Please forgive my ignorance but I'm very new to this and I got a killer deal on some 3 piece wheels for my 11 wrx. I was hopping to get 18x9.5 +38 but the 3 piece wheels I found are 18x9 +38 fronts and +24 rears. Will the rears fit if i roll the fenders or will I have to make a pretty big flare? I also have access to a body shop and grew up around it and can do and light body work and paint myself.
01-28-2017, 05:28 PM | #4407 |
Member#: 442346
Vehicle:2013 WRX SWP |
After reading many threads, I found that 17x9 +35 RPF1's require ~8mm spacers when used with gold 04-07 Brembos. I also read that OEM 08+ WRX wheels clear the black 08+ Brembos but not the 04-07 Brembos, which leads me to believe that the 08+ Brembos are slightly slimmer. What spacers, if any, are required to clear 08+ Brembos with 17x9 +35 RPF1's?
01-28-2017, 05:41 PM | #4408 |
Member#: 370293
Vehicle:2012 wrx silver |
I have 08 black on my wrx front and rear with stock rims and i have to use a 2mm spacer to clear front but the rear doesn't need any spacers clears with plenty of room.
01-28-2017, 08:11 PM | #4409 |
Member#: 380952
Vehicle:2014 WRX WRBlue |
Hi all, just ordered some 17x8 5x100 rpf1 for my 2014 wrx. I searched and could not find a definitive answer if I would need hub centric spacers or not. It seems that the wheels may have changed at some point and they are no longer needed but some people have still needed them.
This is the Enkei part number I ordered... 379-780-8045SP will I need the spacers for these and if so what size? Also will the stock lug nuts fit or does it require a different style of lug nut? |
01-31-2017, 01:59 PM | #4410 | |
Member#: 383867
Vehicle:2013 WRX PBP |
1. The hub rings: Your wheels appear to be a 73mm bore, the WRX has a 56.1mm bore. I used this website: http://us.hubcentric-rings.com/custo.../?src=intpopup This site was the easiest way I found to get a custom size that I knew would fit perfectly. 2. The lugs: The stock lugs are "acorn" style and your new wheels are "conical" style. I suggest something like this: https://www.rallysportdirect.com/par...5-lug-nuts-red These are Rays lugs so you might want to get a different brand but I just included the link as an example. |
02-02-2017, 12:31 PM | #4411 | ||
Member#: 12029
"Acorn" is just a description of the style of lug nut, in terms of the overall shape -- compact, like a little acorn, as opposed to a long style. But an acorn lug nut could be conical or ball seat. The vast majority of "acorn" style lug nuts I have seen are conical seat. --Dan Mach V FastWRX.com |
02-02-2017, 01:03 PM | #4412 |
Member#: 383867
Thank you for clarifying this for me Dan! I apologize if any of my information was not totally correct.
02-05-2017, 05:48 PM | #4413 |
Member#: 391361
02-05-2017, 11:27 PM | #4414 |
Member#: 370293
Does anyone know of any steel wheels that would clear the 08+ sti brembos for.my 2012 wrx?
02-07-2017, 10:53 AM | #4415 |
Member#: 377862
^ I'm totally confident that yes, somebody would know that.
02-07-2017, 11:03 AM | #4416 |
Member#: 370293
I'm hoping there are some ppl that know of a set that'll work perfectly for a winter tire setup
02-07-2017, 11:26 AM | #4417 | |
Member#: 12029
02-07-2017, 11:27 AM | #4418 |
Member#: 370293
Yea but I have a wrx not a sti. Tire rack doesn't have option to tell them you have wrx with sti brembos that I am aware of.
02-07-2017, 12:05 PM | #4419 |
Member#: 370293
Yea not really trying to run spare tires as my winter setup lol
02-07-2017, 12:42 PM | #4420 | ||
Member#: 12029
02-07-2017, 03:29 PM | #4421 |
Member#: 370293
Thanks for the input but I do know I can run alloy wheels I have a second set of.rims already but I'd like to stick with steel if I can as they will be stronger for winter incase I run into any problems in the snow and ice
02-17-2017, 01:12 PM | #4422 |
Member#: 311911
SCIC
Vehicle:2012 WRX Limited Sdn SWP (TP Stg 2) |
Say you had an 18x9" +23 wheel. Would that not be the same as an 18.9.5 +38 as far as where the wheel would sit with the fender? (on any car for example) 15mm is .59 inches so pretty much half an inch which the 9" wheel would make up for with that +23 offset correct? Am I doing that right lol?
02-17-2017, 04:27 PM | #4423 | |
Member#: 12029
1/2" difference in wheel width = an additional 12.7mm of width. Divide by 2 (half of the additional width is on the inside, half on the outside) = 6.35mm. 23 + 6.35 = about 29mm. --Dan Mach V FastWRX.com |
02-17-2017, 05:22 PM | #4424 | |
Member#: 311911
SCIC
02-20-2017, 04:44 AM | #4425 |
Member#: 463273
Hey Guys,
Thinking about running Ventus V12 Evo's on Enkei Raijins 18x9.5. Will I have an issue running the V12's with 265/40R18? I kinda would like to avoid rolling fenders if I can but I would still like to eliminate as much wheel gap as possible. Thanks for the input. |
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L | acetmi | Private 'Wanted' Classifieds | 0 | 06-14-2006 12:43 PM |
need somewhere to get wheels and tires asap | bubba03wrx | Southern California Impreza Club Forum -- SCIC | 22 | 04-02-2004 09:14 PM |
Wider wheels and tires in the rear | SilveRexy03 | Tire & Wheel | 14 | 11-04-2003 04:49 PM |
WEre is a good place to buy wheels and tires | MilfordSubaru | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 05-25-2002 01:14 PM |
Where to buy wheels and tires? | wilddave1 | Brakes, Steering & Suspension | 4 | 03-21-2002 02:20 PM |
