Tire & Wheel Forum sponsored by The Tire Rack |
12-17-2016, 04:31 AM | #4376 |
Member#: 459860
So you mean
18x9 +35 with 245/35/18 with standard suspension and no roll fender will be result in no rubbing at all ? Thank you for replying
12-17-2016, 11:42 AM | #4377 | |
Member#: 459860
So right now i try to find another set of 18x8.5 with et lower than 47 Which will not rubbed without any fender rolling How about et 35 ? Thanks before Last edited by Ibnualiguna; 12-17-2016 at 12:17 PM. |
12-18-2016, 12:02 PM | #4378 |
Member#: 333048
NWIC
Vehicle:2013 WRX VF52+E85+TP Road Tune |
Toyo Proxes R1R 245/35ZR17?
Anyone run these on 17x8 rim? Any feedback? Not many 245/35/R17 tires on the market, but the smaller size should help my 5 speed last longer. For more context - * For an aggressive street tire in the summer * 235/40R17s looks like a good choice, also smaller than stock 235/45s * Aware speedo will be off.. |
12-18-2016, 02:18 PM | #4379 | |
Member#: 431290
NWIC
Vehicle:2013 impreza silver |
Can you explain how smaller tires would make your tranny last longer? Not being sarcastic, I'm actually wondering if there is less load on the transmission due to what would replicate shorter gears I guess. I would think it would put a little more wear on everything because you'd have to be higher in the rps than normal to go the speed you want, especially on the highway (I'm aware it would be very minimal) |
12-18-2016, 03:29 PM | #4380 | |
Member#: 333048
NWIC
824/872 = ~94.5% So with the OEM tires in 2nd gear @7000RPMs I'm at 70MPH. With this smaller tire you end up at ~94.5% of 70MPH which is ~66MPH. Which also means less load on each gear. I'm more worried about load vs wear Last edited by krisk; 12-18-2016 at 03:44 PM. |
12-18-2016, 03:44 PM | #4381 | |
Member#: 431290
NWIC
Yes but if you were at true 70mph on both tires wouldn't that mean you would have more load on the smaller tires? |
12-18-2016, 04:39 PM | #4382 | |
Member#: 333048
NWIC
http://forums.nasioc.com/forums/show....php?t=1546987 |
12-27-2016, 12:39 PM | #4383 |
Member#: 447355
Hey guys so I'm looking to trade my rpf1s for some cosmis mr7 18x9 with a +25 offset.. I have a 2013 wrx hatch with a stock suspension and I ran 18x9 +35 rotas that I had to roll the rear fenders for.. was just curious if I'd be able to run the cosmis with the less amount of offset!
Thank you |
12-27-2016, 06:38 PM | #4384 | |
Member#: 431290
NWIC
Well they are the same width so just see if you have 10mm of clearance to spare when the suspension is compressed.. everyone's fender roll is different and so it's kinda hard to say for sure what will fit in other people's fenders |
12-27-2016, 09:15 PM | #4385 |
Member#: 447355
Thanks for the input i think I have enough room for that! My fenders are flat rolled if that's any constellation
12-31-2016, 01:49 PM | #4386 |
Member#: 458704
Best offset
Want to run 18x8 with huge brakes
Car is lowered Best offset with out rolling fenders? |
12-31-2016, 02:10 PM | #4387 |
Member#: 167544
NESIC
Vehicle:'12 DGM STi sedan '14 Audi S6, '16 XC90 |
01-02-2017, 09:50 AM | #4388 |
Member#: 460590
First post!
Hey everyone. So I sold my Civic and picked up a 2012 WRX Hatch and I'm looking at getting back into autocross after a 3 year hiatus. I've narrowed my tire/wheel search down to a Rota Titan 17x9 for the best tire/weight options. My question finally comes down to the offset choice. This wheel is available in +35 and +42 I had originally searched/set on +35 Avids but the titan looks a lot better in 17" diameter and is lighter to boot. I've played the Volk game when I autocrossed my Civic and I'm done with expensive wheels for a daily/autox car. Pros cons of +35 and +42 in 17x9? The car will never be dumped, probably mild drop once I get the coilover setup for autocross. Thanks all! |
01-03-2017, 01:44 AM | #4389 |
Member#: 324755
BAIC
Vehicle:2014 WRX Hatchback WRB |
One sticks out 7mm more than the other.
You'd probably see slightly better steering feel with the +42 and have less potential fender issues when introducing that drop, although that depends more on tire selection. If you'd prefer to have a more "flush" look, then +35 is the way to go. I used RPF1s in 17x9 +35 and they looked great in terms of flush fitment. Speaking of which, I am selling my RPF1s with 245/40R17 Michelin Pilot Super Sports which weighs at ~39lbs per corner. Sale thread here |
01-03-2017, 06:32 AM | #4390 |
Member#: 460590
I was thinking that the difference between the two might be my tire options and clearance therein.
After some thought, the two are close enough a spacer isn't out of the question if I'm not thrilled with +42. |
01-03-2017, 07:05 AM | #4391 |
Member#: 460590
Double post
01-03-2017, 11:46 AM | #4392 |
Member#: 317045
Vehicle:2012 WRX Hatchback SWP |
01-03-2017, 12:24 PM | #4393 | |
Member#: 459450
Also this site was great for comparing offsets and tire specs (using manufacturer measurements) for clearance. http://www.rimsntires.com/specspro.jsp |
01-03-2017, 03:00 PM | #4394 | |
Member#: 460590
Thanks, I've been using http://www.wheel-size.com/calc/?whee...cl=50mm&sr=0mm Shows the difference between the tire position and rim position as well in the same tool. Pictures of your car on the setup? How does it look on the stock suspension? been debating running the 235 on the 9" wheel for my first season then upgrading once I get some seat time. I'm just really disappointed in the factory offset and don't want to spend $2-300 and on spacers/extended lugs then worry about that. The titans are a good wheel and fix my cosmetic twitch with the car. Subaru could have done a better job on the wheel offset. Last edited by Hondabaru; 01-03-2017 at 03:27 PM. |
01-03-2017, 08:30 PM | #4395 |
Member#: 459450
I won't be putting the wheels on til spring. I realize the way I worded my post was a bit confusing, sorry haha. I'm on my stocks with snow tires right now.
On page 75 there is a red hatch with 17x9 +45 RPF's at stock height that sold me on the +42 offset. He is on 255/40 Falkens and they run a little wider (10.5" section width) and it looked perfect. The +42 titans with 265/40 Fed EVOS (10.8" section width) should be pretty flush. I'm already prepared to roll my rears if I need to. Last edited by Nick_C18; 01-04-2017 at 01:07 AM. |
01-09-2017, 10:31 PM | #4396 |
Member#: 449820
Guide to fitting wheels and tires to the 2011-2014 WRX
Hey guys,
First post here. I'm looking to get some new wheels for my 2013 spec C. It's on stock suspension and wanna go with a concave 5 or 6 spoke wheel and a flush fitment; maybe a LITTLE poke if anything. Would be used as a daily. I have a very short commute. And I'm keeping the spec C wheels for the odd track day. Keeping stock suspension for now as well. Was wondering if an 18x9.5 +30 wheel would accomplish what I want ? Would be using the 245/40/18 tyres for now. I don't mind the mild stretch if it helps with fitment. Specifically looking at the Enkei Kojin wheels. I know the offset is low compared to stock but it's the only 5 spoke concave wheel I like a lot. Any advice would be greatly appreciated. Thanks in advance! |
01-10-2017, 11:55 AM | #4397 | |
Member#: 311911
SCIC
Vehicle:2012 WRX Limited Sdn SWP (TP Stg 2) |
01-10-2017, 02:26 PM | #4398 | |
Member#: 449820
I don't WANT poke.. I just wouldn't MIND it lol. I could live with rolled rears and I'm basically the only person in the cars 99.9% of the times.. lol Will try it out and let you guys know! Thanks! |
01-11-2017, 01:33 PM | #4399 |
Member#: 317045
@ scotty_buttons
Say you go with the Enkei 18x9.5 +30 wheel and 245/40-18 tire combination and you get the fenders rolled. Everything may work out for you fine now. But if you go to a wider tire in the future then you may run into issues. Something to think about now before you commit the time and $$$. |
01-11-2017, 10:36 PM | #4400 | |
Member#: 449820
Hmmm.. what issues we're talking about here specifically? |
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L | acetmi | Private 'Wanted' Classifieds | 0 | 06-14-2006 12:43 PM |
need somewhere to get wheels and tires asap | bubba03wrx | Southern California Impreza Club Forum -- SCIC | 22 | 04-02-2004 09:14 PM |
Wider wheels and tires in the rear | SilveRexy03 | Tire & Wheel | 14 | 11-04-2003 04:49 PM |
WEre is a good place to buy wheels and tires | MilfordSubaru | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 05-25-2002 01:14 PM |
Where to buy wheels and tires? | wilddave1 | Brakes, Steering & Suspension | 4 | 03-21-2002 02:20 PM |
