Tire & Wheel Forum sponsored by The Tire Rack |
02-19-2015, 05:33 PM | #3726 | |
Member#: 97135
NWIC
within eyesight of a 9.5 +40 wheel, a 265 will most likely require a rear roll. honestly, if you are looking at 8.5"+ wheels you shouldn't be scared of rolling fenders, otherwise you shouldn't be looking at wheels that big.
02-19-2015, 05:36 PM | #3727 |
Member#: 324205
Vehicle:F30 335i; 2016 Crosstrek; 2013 WRX(sold) |
If you going with a 9.5 wide wheel and a proper sized tire you will have to roll the rear fenders. Period. If you don't want to roll your fenders don't even consider a wheel this wide. Stop with this offset and not all tires are created equal talk. There's not one person on here that's running a 265 or 255 on a 9.5 wheel on these cars that hasn't had to roll in the rear.
02-19-2015, 09:33 PM | #3728 | |
Member#: 398867
Vehicle:2013 WRB WRX HATCH 2008 Suzuki RMZ250 |
02-19-2015, 09:38 PM | #3729 | ||
Member#: 393036
Vehicle:2013 Impreza WRX 5dr Dark Gray Metallic |
02-21-2015, 01:09 AM | #3730 |
Member#: 394262
Vehicle:2011 STi Pearl White |
I'm about to buy some tires and would like a bit more info on fittment of wheel, tire and amount of -camber required to fit them without rubbing on a 11 STi hatch.
wheel = 18x9.5+38 (already own them so can't change this size) tire = Michelin Pilot Super Sport 265/35/R18 (or possible 255/35/R18 if the 265 requires too much -camber) current suspension mods = KW V3 coilovers, rear LCA's, Com-C front strut mounts, front/rear sways, front roll center adjust current alignment on stock wheels and tires = -1.5 camber all around I'm planning to stay just slightly lower then stock, no big drop maybe like 1/2" and would like to keep -camber to a minimum for daily driving. questions: will it require just a slight roll or flat for the 265 tire? (I'm not a fan of rolling flat because then the fenders can become flimsy) about how much -camber will I need with the 265 & 255? obviously I would prefer the 265 since it's closer to the stock size, but don't want to have too much -camber for daily driving. Last edited by H00LiG4N; 02-22-2015 at 08:36 AM. |
02-22-2015, 12:53 PM | #3731 |
Member#: 162616
17x9 Rota Titan 5x100/e42 with 265/40R17
I have done a lot of reading and searching on here and based on what I have seen I was thinking of going with the following setup.
17x9 Rota Titan 5x100/e42 with 265/40R17 tires The main reason I am thinking 265 vs 255 is due to the loss in tire diameter with a 255/40R17. I hadn't seen anyone mention this exact setup so I was just curious if anyone had any experience or input on whether on not this will work well. I have a 2011 WRX hatch on stock suspension. I do not plan on lowering at all and the rear fenders were already rolled by the previous owner. Since the fenders are already rolled, I am pretty sure I shouldn't see any issues on the outside, but I am still a bit concerned with the strut clearance on the inside. |
02-23-2015, 02:13 PM | #3732 | ||
Member#: 12029
--Dan Mach V FastWRX.com |
02-23-2015, 02:16 PM | #3733 | ||
Member#: 12029
02-23-2015, 05:28 PM | #3734 | |
Member#: 394262
I was looking at this. http://www.nationaltoolwarehouse.com...FdgVgQodwQUAiQ Last edited by H00LiG4N; 02-23-2015 at 05:36 PM. |
02-25-2015, 02:48 PM | #3735 |
Member#: 329938
SCIC
Vehicle:2013 WRX WRB |
I sourced a 18x10 + 38 rpf1 wheel that is on its way. I am getting 265/35/18 Potenza S-04 tires with it. I am less than an inch lowered currently on stock struts with Tanabe GF210 springs. I am also getting a roll in the rear that is going to be flat or pretty close to it.
I have seen others fit this set up before but they were on coilovers and I know there are a lot of variables still in play but I just wanted some guidance on things to look out for that I am missing? And lastly, the famous questions, will this fit/work? Thanks Last edited by CZDeaver; 02-25-2015 at 06:34 PM. |
02-26-2015, 01:12 AM | #3736 | |
Member#: 12029
It seems pretty simple to me. 1. Ask question. 2. Get knowledge. 3. Buy wheel. But for the record, yes, your tires should fit fine on those wheels (although the wheels are needlessly wide), and should clear the fenders. Probably. --Dan Mach V FastWRX.com |
02-26-2015, 12:12 PM | #3737 | ||
Member#: 329938
SCIC
I added the famous questions line... the will it fit after my original post... I knew it would fit... I should have added a or or something to let you know it was... you know.... a joke . I really just wanted to be sure I wasn't missing something. I have contingencies if it doesn't like LCA's but again just trying to make sure I am not missing anything. Thanks again! I know you do a lot for the Subaru community and I appreciate it! |
02-26-2015, 05:49 PM | #3738 |
Member#: 372000
Vehicle:2011 WRX |
What's everyone's opinion on nankang ns-20s? Found someone that can get a set of 245/40/18 new for $270, which seems pretty damn good to me. Was originally after 255/35, but hard to pass up that deal.
02-26-2015, 05:58 PM | #3739 |
Member#: 97135
NWIC
"pretty damn good deal" only applies to dollar signs, not product quality, not quality per dollar.
does it really matter what we say? keep thinking with your wallet and buy whatever you want. |
02-26-2015, 10:56 PM | #3740 |
Member#: 375240
Anyone have any fit info for 18x8.5 3SDM wheel on a 2011 wrx?
02-26-2015, 11:03 PM | #3741 |
Member#: 378001
Vehicle:2011 WRX OBP |
First thread will answer that... Same size as the STi wheel. If I remember the offset is around 42? So throw a 245/40 on them and you have a stock STi setup...
02-27-2015, 01:10 PM | #3742 |
Member#: 394262
Stock STi offset is 55
02-27-2015, 01:28 PM | #3743 |
Member#: 378001
Sorry I meant the offset of the 3sdm's
02-27-2015, 09:53 PM | #3744 |
Member#: 263219
About about everyone stop rolling, just cut the fender mount a flare
02-28-2015, 09:47 AM | #3745 |
Member#: 359125
NESIC
Vehicle:2013 WRX 317hp/353tq WRB |
So Im going to buy Rota torques for a 13 Wrx. They are 18x9.5 offset 35. Im going to roll the fender and my plan was to buy 255/35 P Zero Nero GT tires for it. I already have coilovers. Will they fit without any major rubbing. I been searching for a while but I couldn't find any similar setup.
03-01-2015, 12:02 PM | #3746 |
Member#: 375088
Vehicle:2014 WRX |
I really appreciate this thread, really helped!
Got SSR 18x9.5 offset 40 with 265 35 tires to fit on my 2014 WRX hatch with out rubbing issues or having to roll my fenders. Stock spring and struts. |
03-01-2015, 12:05 PM | #3747 |
Member#: 319511
TXIC
Vehicle:2013 STI Sedan Ice Silver Metallic |
Oaf02z what happens to your fender liners with those flares?
03-01-2015, 03:53 PM | #3748 | |
Member#: 325249
Vehicle:2012 wrx dgm |
depends how low you are. but youl be fine Sent from my iPhone using NASIOC |
03-01-2015, 08:15 PM | #3749 |
Member#: 308205
Vehicle:12 Grocery Getter WRX WRB |
Thread helped me out so much on deciding for my '12 WRX, going to be running a 265/35/18 Bridgestone RE760 (anyone have any problems w/ these tires?) on my 18x10+38 XD-9s on Isc N1 coils, rolled front and rear fenders. Anyone see me running into any issues?
03-01-2015, 08:18 PM | #3750 |
Member#: 319511
TXIC
I have a similar setup except 18x9.5 38 265 35 18 michellen pilot super sports. Front and rears rolled. Lowered to about half a finger gap all around and my only issue is rubbing on the front fender liners near the bumper.
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L | acetmi | Private 'Wanted' Classifieds | 0 | 06-14-2006 12:43 PM |
need somewhere to get wheels and tires asap | bubba03wrx | Southern California Impreza Club Forum -- SCIC | 22 | 04-02-2004 09:14 PM |
Wider wheels and tires in the rear | SilveRexy03 | Tire & Wheel | 14 | 11-04-2003 04:49 PM |
WEre is a good place to buy wheels and tires | MilfordSubaru | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 05-25-2002 01:14 PM |
Where to buy wheels and tires? | wilddave1 | Brakes, Steering & Suspension | 4 | 03-21-2002 02:20 PM |
