Tire & Wheel Forum sponsored by The Tire Rack |
12-01-2014, 07:02 PM | #3551 |
Member#: 306479
SWIC
Vehicle:2012 WRX Limited Satin White Pearl |
Will be just fine on stock suspension. 265-35 Is perfect for 9.5 wheel.
-Reese
12-01-2014, 07:33 PM | #3552 |
Member#: 407589
Vehicle:2011 Wrx Blue |
Okay I apologize, but i did read it and he said he doesn't recommend a +25 or a +30 offset and that a +40 offset will work give or take a couple mm. So a +35 is right in the middle of working and what he doesn't recommend. So that is why I asked and I wanted to make sure that I had no issues with rubbing. So I'm sorry that I wanted to double check before i go and spend $1000 on rims and tires. Like I said that was my first post so clearly I don't really know what I'm doing. So there is no need to get mad. I also stated I know very little about wheels and tires, so I don't know what effects tire size. Next time I will do A little bit more reading before I post something. sorry for the inconvenience. Thank you Reese.
12-01-2014, 07:37 PM | #3553 | |
Member#: 378001
Vehicle:2011 WRX OBP |
12-01-2014, 07:44 PM | #3554 | |
Member#: 407589
12-02-2014, 11:36 AM | #3555 |
Member#: 317045
Vehicle:2012 WRX Hatchback SWP |
budget more money
12-02-2014, 03:55 PM | #3556 | |
Member#: 97135
NWIC
"within eyesight" is a good rule of thumb when looking at fitments. |
12-02-2014, 05:25 PM | #3557 |
Member#: 407589
Yeah that was just a rough estimate. But with the rims I want it will be right around $1500.
12-02-2014, 05:26 PM | #3558 |
Member#: 407589
12-03-2014, 03:30 PM | #3559 |
Member#: 301179
BAIC
Vehicle:2013 WRX Limited SWP |
12-03-2014, 03:45 PM | #3560 |
Member#: 321857
12-03-2014, 05:22 PM | #3561 |
Member#: 378001
^^^this. I run 255/40 on my 17x9 and it's perfect. But 255/35 would be the tour for an 18x9 I would run.
12-03-2014, 05:28 PM | #3562 |
Member#: 97135
NWIC
12-03-2014, 10:01 PM | #3563 |
Member#: 349732
Vehicle:2016 wrx premium wr blue |
SORRY TO DO THIS. 2014 4dr wrx. need summer wheels n tires. 18x8 45mm offset. what tire size would work best, 245-40 or 255-30? not a big fan of mud flaps so i dont want too much tire "outside" the wheel wells. guy i talked to at tirerack was as clueless as i. just was a lil more meat and close the gap. thank all.
12-04-2014, 01:04 AM | #3564 | |
Member#: 97135
NWIC
235/40 or 245/40. Sent from my iPhone using NASIOC |
12-04-2014, 09:15 AM | #3565 | |
Member#: 321857
12-04-2014, 06:26 PM | #3566 |
Member#: 349732
thanks
12-05-2014, 09:01 PM | #3567 |
Member#: 370560
NESIC
Vehicle:2017 STI DGM |
Does anyone know if 2015 sti wheels will fit a 2014 sti
12-05-2014, 09:02 PM | #3568 |
Member#: 378001
12-06-2014, 06:50 PM | #3569 |
Member#: 370560
NESIC
Really!? The ******* at the dealership told me the 2015 sti wheels were 1/2 wider so I wasn't sure about clearance. Thanks man
12-06-2014, 08:40 PM | #3570 | |
Member#: 378001
The 2015 wrx are now that size as well where as the older wrx are 17x8 55 offset and 5x100 bolt pattern. So maybe he was referencing that? Nonetheless you can fit an 18x9 +42 with no issue if you were going wider |
12-06-2014, 08:41 PM | #3571 |
Member#: 370560
NESIC
Good point thanks man
12-07-2014, 01:46 AM | #3572 |
Member#: 343207
SCIC
for those who interested in keeping stock suspension. This is 18x9.5+38 offset on contential Extremecontact dw 265/35/18. Rears rolled. No rub (test with 4 adults in car prob around 800lbs) Sent from my SM-G900T using NASIOC mobile app Last edited by Romp_; 12-07-2014 at 05:32 PM. |
12-07-2014, 10:06 AM | #3573 | |
Member#: 317045
2015 WRX has 17x8 wheels, and the same size tires as the 2014 WRX. |
12-07-2014, 10:38 AM | #3574 |
Member#: 378001
12-09-2014, 02:58 PM | #3575 |
Member#: 36838
Vehicle:2001 B50 RSTi Sedan 2011 DGM WRX hatch |
Has anyone tried putting taller tires on the 2011+ WRX?
I'm thinking... now that I have the slightly taller king springs on (King "standard height") I have a bit more wheel gap. I'm thinking that instead of going to a 9.5" wheel, to only move up to an 8.5" and then go with a slightly taller tire to fill some of the gap. Thoughts? 25.3" is the stock diameter, how large do you think I could go with a 235-245 width tire? I'm thinking of using an 18x8.5 +48 wheel. Thanks, -- Dave Last edited by AcquaCow; 12-09-2014 at 03:41 PM. |
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L | acetmi | Private 'Wanted' Classifieds | 0 | 06-14-2006 12:43 PM |
need somewhere to get wheels and tires asap | bubba03wrx | Southern California Impreza Club Forum -- SCIC | 22 | 04-02-2004 09:14 PM |
Wider wheels and tires in the rear | SilveRexy03 | Tire & Wheel | 14 | 11-04-2003 04:49 PM |
WEre is a good place to buy wheels and tires | MilfordSubaru | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 05-25-2002 01:14 PM |
Where to buy wheels and tires? | wilddave1 | Brakes, Steering & Suspension | 4 | 03-21-2002 02:20 PM |
