Tire & Wheel Forum sponsored by The Tire Rack |
05-23-2014, 10:00 PM | #3226 |
Member#: 167544
NESIC
Vehicle:'12 DGM STi sedan '14 Audi S6, '16 XC90 |
Suspension is an entirely different conversation however. Too many variables to address in the fitment thread
05-23-2014, 10:19 PM | #3227 | |
Member#: 338724
Vehicle:2014 WRX Hatchback World Rally Blue |
05-24-2014, 07:00 AM | #3228 |
Member#: 167544
NESIC
05-24-2014, 11:50 AM | #3229 | |
Member#: 338724
Fortune 500 coils with swift springs set at 8k / 8k. Cusco lateral links in the back. This setup, it will take care of my rubbing issues as I'm worried about. I think I need about -2 deg all around. But with this setup would I be able to fit a 265.35? |
05-24-2014, 09:35 PM | #3230 | |
Member#: 167544
NESIC
On 255s with only 10mm drop from stock i'd be shocked if rubbing is any sort of issue for you. 265s should not be a problem so long as they are not super wide on section/tread width. do more research on the setup, i think you'll find that you're worrying too much. |
05-24-2014, 11:56 PM | #3231 | |
Member#: 338724
Thinking of running v12s or extreme contact dw tires |
05-27-2014, 02:56 AM | #3232 |
Member#: 208859
SCIC
Vehicle:2013 WRX SWP |
Thank you guys for your help. Success! 18x9.5 +40 Sumitomo htr z ii 265/35R18 Stock suspension fenders not rolled yet. |
05-27-2014, 09:13 AM | #3233 |
Member#: 357126
NESIC
Vehicle:2015 WRX Premium WRB |
Update for my nt03's: running 18x9.5 | +40 | 5x100 on my 2013 Wrx Hatch. Tires are Michelin PSS 265/35zr18. Rear fenders are rolled on stock suspension and I have posted in this thread before thay I have no rubbing issues. Just recently found out that with a car full of people (5' 10" guys ~150lb each) the rears do rub ever so slightly.
05-27-2014, 10:52 AM | #3234 | |
Member#: 311911
SCIC
Vehicle:2012 WRX Limited Sdn SWP (TP Stg 2) |
05-27-2014, 11:35 AM | #3235 | |
Member#: 338724
To be exact, PSS have a tread with of 10.1 vs 9 on a Continental dw. I've heard from multiple people they run wider so...I think this is the info that gives light to this. Not sure. Last edited by -Rizzo-; 05-27-2014 at 12:51 PM. |
05-27-2014, 08:06 PM | #3236 |
Member#: 357126
NESIC
Here are some pics to prove it. It's a very minor rub on big dips with 3 other people in the car. It has never rubbed from suspension flex in the rear with just me in the car. However, I did notice that it also rubs up front only in reverse when the wheel is turn all the way to either the left or right. That's also a very light rub and I can't even find where the tire's hitting the wheel well.
Rear left: (notice the mark on the outer most tread edge) Rear Right: Pic of the fender roll. Rears are basically flat: And lastly, the side profile: |
05-28-2014, 04:52 PM | #3237 |
Member#: 289425
Does anyone have experience fitting The Work VS-XX on 2011 STI?
I am looking at the following: 18x9.5 +38 BC BR Coilovers If i need to go smaller width i can. i would like to stay above 8.5" if possible. Also, you should probably know i don't want to stretch tires onto the wheels. I want to fit a 255 on them correctly. Really want a guaranteed fit before dropping 3K on wheels |
05-28-2014, 05:02 PM | #3238 | |
Member#: 321857
05-28-2014, 05:16 PM | #3239 |
Member#: 311911
SCIC
^^^That and well....yea....read the first post lol
06-01-2014, 09:05 PM | #3240 |
Member#: 370362
NESIC
Vehicle:2011 wrx |
this may already be in here i look quick but didn't see to much..
18x9.5 et+34 car is lowered on bc coils but will raise and roll rear fenders for sure. question is 255/35 tire? 245/40? will it work, i really do not want mexi poke.. |
06-02-2014, 03:38 AM | #3241 |
Member#: 208859
SCIC
Update: I ended up having the rear fenders shaved instead of rolled as suggested by the guy doing my fenders. I'm happy to say that there's no rubbing with one person in the front passenger seat. I will update if there's any rub having a full load (2 more ppl) of passengers in the car. |
06-02-2014, 09:02 AM | #3242 |
Member#: 321857
255/35. It might poke some depending on what your camber is set at, because that offset and width is pushing it.
06-02-2014, 10:50 AM | #3243 | |
Member#: 311911
SCIC
06-02-2014, 11:51 AM | #3244 | |
Member#: 333855
RMIC
Vehicle:1995 STI v2 Type RA white |
06-02-2014, 12:52 PM | #3245 |
Member#: 370362
NESIC
Vehicle:2011 wrx |
06-02-2014, 02:30 PM | #3246 |
Member#: 208859
SCIC
There's no fender liner on the rear fenders to remove so if it's gonna rust it's gonna rust either way. All in all, I'm happy I don't have anymore rubbing. I believe he knows what he is doing since it's tony the fender roller. He's been doing it for 10 years or so. He's pretty well known in the BMW, VW forums.
06-02-2014, 02:39 PM | #3247 |
Member#: 311911
SCIC
I just don't understand why trimming the fenders would be "recommended" over fender rolling when fender rolling is pretty damn easy haha Whatev though...as long as you're happy and later on if you slam it it doesn't cut your tires
06-02-2014, 02:47 PM | #3248 |
Member#: 321857
It's easier to cut than to do a good roll job.
06-02-2014, 07:09 PM | #3249 |
Member#: 97135
NWIC
06-03-2014, 09:10 AM | #3250 |
Member#: 321857
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L | acetmi | Private 'Wanted' Classifieds | 0 | 06-14-2006 12:43 PM |
need somewhere to get wheels and tires asap | bubba03wrx | Southern California Impreza Club Forum -- SCIC | 22 | 04-02-2004 09:14 PM |
Wider wheels and tires in the rear | SilveRexy03 | Tire & Wheel | 14 | 11-04-2003 04:49 PM |
WEre is a good place to buy wheels and tires | MilfordSubaru | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 05-25-2002 01:14 PM |
Where to buy wheels and tires? | wilddave1 | Brakes, Steering & Suspension | 4 | 03-21-2002 02:20 PM |
