Old 05-17-2017, 01:56 PM   #4476
RSX_02
Member#: 376415
Smile Fitment question
Hi. Im looking to run a 18x9.5 +35 on stock height. Do you know if this will call for fender rolling or if they will clear with no issue. Thanks in advance for any help!
I have a 11 wrx compact.
RSX_02 is offline   Reply With Quote
Old 05-17-2017, 02:07 PM   #4477
erniev
Member#: 440682
short answer , yes. Roll.
erniev is offline   Reply With Quote
Old 05-18-2017, 11:11 AM   #4478
Mach V Dan
Member#: 12029
First of all, you haven't told us what tire you are trying to run. Secondly, if you read the VERY FIRST POST it goes into considerable detail explaining that you should run a higher offset to have any chance of fitting without rolling.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 05-18-2017, 04:03 PM   #4479
RSX_02
Member#: 376415
--Dan
Mach V
FastWRX.com
I'd like to stay near a stock tire size. & I don't mind rolling if I have to I just want to make sure they are going to fit before ordering.
Old 05-18-2017, 04:04 PM   #4480
RSX_02
Member#: 376415
If rolled do uk if any rubbing issues?
Old 05-18-2017, 11:48 PM   #4481
erniev
Member#: 440682
That's tough to say since I'm running 10mm more offset than you.
Old 05-22-2017, 02:40 PM   #4482
deeefour
Member#: 357646
While I like the look of an 18" wheel for my '11 WRX hatch, I feel uneasy enough about my stock wheels on CT roads with the stock sidewall.
I want a 9.5" wide wheel, but unlike most people here I'm looking at staying at 17" diameter.
I'm looking at WedsSport SA-72R, 17x9.5 +38mm, 5x100.
The issue I'm having is finding options for tires. I want 265/40/17 tires because they match the stock diameter, but can only find the following:
- Bridgestone Potenza RE760 @ $157/ea
- Michelin Pilot Sport PS2 @ $307/ea
- Goodyear Eagle F1 Supercar @ $323/ea
The Potenza's don't get incredible reviews, and I don't want to spend $1200+ on tires.
It seems clear what I want to do is uncommon, but are there other options I'm missing?
deeefour is offline   Reply With Quote
Old 05-22-2017, 03:17 PM   #4483
rich260z
Member#: 348236
2011 STI Hatch
PBP
You're out of luck if you want to keep a stock size diameter. Most people who who do wide 17's go with a 255/40 since that size is common and plentiful, or a 275, but that might barely fit depending on your camber and suspension.
rich260z is offline   Reply With Quote
Old 06-10-2017, 01:10 AM   #4484
imkale
Member#: 274609
Advan RSDF 18x9.5 +40 (thanks RavSpec!)
Potenza S-04s 265 35r18 (thanks Tire Rack!)
RCE Tarmac 2s (thanks RCE!)
Rolled rear fenders (thanks Group 2!)
Everything fits beautifully
Still working on adjusting ride height.
I'll try to get some more pics up soon.
imkale is offline   Reply With Quote
Old 06-18-2017, 05:21 PM   #4485
lkft
Member#: 469527
First time poster here, greetings!
Here's a pic of my 2013 base WRX
I just picked up a nice set of BBS RGRs in the 17x7.5, 5X100, +48 format. Will I have any fitment issues? I plan on using the OEM tire size. A couple of pics of the wheels, they are supposed to be shipped to me this week so I don't have them yet. Thanks in advance!
lkft is offline   Reply With Quote
Old 06-19-2017, 09:25 AM   #4486
rich260z
Member#: 348236
2011 STI Hatch
PBP
No you won't have issues, but you went down to a thinner wheel (7.5" vs 8")
It'll sit in exactly the same spot. If you all you care about is how the wheel looks, then you're good to go.
Old 06-19-2017, 09:50 AM   #4487
lkft
Member#: 469527
Thanks for the info, really appreciate it! I've had some concerns since I've never done this before and there's a bunch of conflicting info out there. For example tirerack has a compatibility checker that says these wheels are not compatible so go figure! Would the thinner wheel size affect my being able to use the OEM tire size? I think the tire size is fine for my needs since I'm just a DD with a very short commute. Any need for spacers? Thanks again!
Old 06-19-2017, 09:55 AM   #4488
rich260z
Member#: 348236
2011 STI Hatch
PBP
That's stupid that tire rack would say they aren't compatible. As for the width, that will not be an issue, all tires have a specified range, and a 235/45 the lowest recommended width is 7.5. So you're good.
If I were you and wanted a larger track width, I would add spacers, but it is not needed.
If you want a simple remove and replace then don't bother.
If you want it to be "flush" you can get a 20mm or 25mm bolt on spacer.
Old 06-19-2017, 10:25 AM   #4489
lkft
Member#: 469527
Great! Thanks that's all I'm really interested in is a simple RR of the wheel. The stock OEM wheels are far from being flush and it looks fine to me so that's good. I consider the BBS wheels to be a nice upgrade since I like the looks and they're forged so there will be some weight savings as well.
Old 06-20-2017, 04:09 PM   #4490
SG02WRX
Member#: 151814
2014 WRX SWP
Default Pic Request
Any one have a picture of RCE Blacks on 17x9?
SG02WRX is offline   Reply With Quote
Old 06-26-2017, 04:30 PM   #4491
lkft
Member#: 469527
*Update*
Just got the wheels in and took them to the local hole in the wall tire joint and the valve stems for the BBSs are smaller than typical. Anyone know the specific size? Am I going to be able to reuse the existing pressure sensors?
Old 06-26-2017, 05:06 PM   #4492
redline23
Member#: 285799
2012 WRX 5-Door
That's the setup I'm running. Needed to roll the rear fenders.
Mach v awesome 17x9 with 255/40/17 Direzza Zii
redline23 is offline   Reply With Quote
Old 06-27-2017, 02:02 PM   #4493
SG02WRX
Member#: 151814
2014 WRX SWP
Looks Great. You made my decision easier
Thanks for posting.
Old 07-09-2017, 04:22 AM   #4494
pdcon37
Member#: 447237
first time poster here guys so be easy. am also new to the whole bigger tire thing also, so I am just curious whats the biggest tire I can Fit under my car? 2008 STI, it has Eibach lowering springs and 20mm spacers all around. the wheels are the stock 18x8.5 bbs. thanks
pdcon37 is offline   Reply With Quote
Old 07-09-2017, 09:17 AM   #4495
Kokin
Member#: 324755
2014 WRX Hatchback
Not much you can do if you plan to stick with those specs (stock 8.5" wheels, 1" drop springs, 20mm spacers put you at +35 offset). Going any wider will probably require you to roll your rear fenders and the larger sizes will mess up your odometer, meaning your speed in the dash will be slightly lower than the actual speed you're going.
If you're really set on going larger, then look for 255/40r18 or 265/40r18. Just be warned that you're going to a larger diameter, meaning it's similar to having taller gears that give you worse acceleration but better top speed.
You would ideally want 275/35r18 as it is the closest diameter to the stock tire, but that would usually need 18x9.5 or 18x10 wheels, preferably with around +40 offset for easier fitment.
Kokin is offline   Reply With Quote
Old 07-13-2017, 03:51 PM   #4496
ahdez
Member#: 453214
2013 WRX Hatch
hi i have a 13 wrx hatch and i was wondering if anyone is running 18x8??
i want some nt03s but i can only get 18x8 +35
would this be flush or would i need spacers???
ahdez is offline   Reply With Quote
Old 07-13-2017, 04:45 PM   #4497
ryann.mendoza
Member#: 208859
2013 WRX
I have a 2013 wrx hatchback and im running nt03 18x9.5 +40 with 265/35r18 tires
Pic for reference
ryann.mendoza is offline   Reply With Quote
Old 07-13-2017, 05:30 PM   #4498
DFreshLeish
Member#: 377464
OK, so I tried to search through all of this and find the answer, but I can't seem to so I apologize in advance for the n00b question...
I have a '14 4-door WRX that I want to put 18's on, and eventually lower slightly (maybe an inch, nothing crazy). The way I understand, I should be able to slap on some 18x9.5 wheels on 265/35R18 tires and be pretty much at the stock size. My question comes with lowering afterwards; at this wheel and tire spec, at what change in height does there have to be adjustment in order for the tires to stay flat and not wear irregular? Is it once there is any adjustment at all, or if I lower an inch should I be able to get away with the same caster/camber/ etc?
tl;dr: Can I lower my car and not mess it up myself?
DFreshLeish is offline   Reply With Quote
Old 07-13-2017, 06:13 PM   #4499
rich260z
Member#: 348236
2011 STI Hatch
PBP
You're talking about messing your alignment up from lowering the car? well that can be fixed a number of ways, but the easiest would be get some adjustable top hats for the front, and get some adjustable rear lateral links for the rear. At most you can probably get by with stock alignment specs, but if you want anything more serious then you'll need some aftermarket parts.
With lowering springs this is pretty much not needed, with coilovers and more than 1" of drop then it will be needed.
I'm selling some adjustable rear lateral links for cheap if you're interested.
https://forums.nasioc.com/forums/sho....php?t=2845095
Old 07-13-2017, 10:05 PM   #4500
ahdez
Member#: 453214
2013 WRX Hatch
Pic for reference
ugh i want that setup but i cant find that size in stock anywhere anymore
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
