Old 08-18-2013, 10:24 AM   #2226
fhughes90
Member#: 341775
2014 WRX - 5dr
Rally Blue
BUMP (sorry for the repeated comment, the pic did not upload last)
Originally Posted by Mach V Dan View Post
You're going to be limited mostly by how much "bulge" you want to have. A 235 width is a good match for an 8" wide wheel. If you wanted to go with something wider, like a 255, it would start to look kind of plump on the wheel.
Here's a 255 on a an 18x8" +48 wheel:
That's not TOO bad, but I probably wouldn't go any wider.
Any of those widths will have no problems with clearing the suspension and fenders.
--Dan
Mach V
FastWRX.com
This is the kind of setup I have been looking for!!
First off, let me begin by saying thank you Dan and everyone else on the thread with your excellent tips and expertise knowledge on the subject. This kind of information is very beneficial. Now to the point...
If you don't mind, what set of wheels are these? Rota Formula wheels? Also, you say the tire was a 255. Is this 255/35R18? I want to keep stock suspension/height. I'm assuming this car was lowered. I shouldn't have any issues with this selection of wheels/tires on stock height should I? Thanks for the help.
I really like this setup, but after reading some more its not preferred because of the handling loss (roll on corners). I would hate to diminish my handling, but how much worse is it? I see a 245/40R18 is recommended on an 18x8" wheel. I wish I could see in comparison...
fhughes90 is offline   Reply With Quote
Old 08-18-2013, 01:03 PM   #2227
NewfoundlandWRX
Member#: 365651
Originally Posted by SoobieDoobieDoooo View Post
18x9.5 et 35
265/35/18 Michelin Pilot Sports
H&R springs. Rolled rears ONLY. NO rubbing issues
This is the best looking set up I've seen so far, any issues with speedbumps / bad roads? What about handling? Did it improve or start to feel sloppy.
NewfoundlandWRX is offline   Reply With Quote
Old 08-18-2013, 07:33 PM   #2228
XsoberX
Member#: 289656
2011 Impreza WRX
Alright.. I've been using a tire calculator all last night and today, and running out to measure wheel distances... and I just want to know what people think.
So I'm looking at getting some wheels made, and the company claims that any size/fitment is possible, so now I'm toying with offset. Wheels and suspension are all stock right now, so 235/45/R17 +53 on 17x8 wheels
Possibility: OEM tires (for now) on 17x9 +44
According to tirerack, the factory Dunlops are recommended for 7.5-9" wheels, so I shouldn't be in any kind of dangerous stretch territory until I can afford some decent rubber. What I'm wondering is if that offset will be low enough to fill the wheel wells nicely. According to an offset calculator, the new wheels would stick out 22mm, or just over 3/4". However when I put in some of the wheel specs I see on here that look good, people are sitting out 1-1.5".
Thoughts? (if it matters, this is my DD that see's mostly city, and some gravel. Also used for auto-x)
XsoberX is offline   Reply With Quote
Old 08-18-2013, 10:04 PM   #2229
SWP408
Member#: 361231
2017 STI Limited
Crystal Black
Originally Posted by sc00by4life View Post
First. This isn't a picture request thread.
Second. Don't bump a couple hours of your first post. Just because of that, people won't help.
Actually read the thread before asking question. Seriously. Read the first post. That's all you had to do.
FIRST: Although this isn't an official picture thread, people are continuously posting pictures of their setup. Does that not make it reasonable to ask for pictures of a setup that I have not yet seen posted in the last 80+ pages?
SECOND: I bumped my post after ~19 hours (a day in actual time), not hours like you stated. Again, I don't find this unreasonable.
THIRD: I read the 1st page 10x times (not joking) and have not read or seen anything addressing my specific question for fitment of these specific wheels on stock suspension. If I did miss something please point it out for me. Much appreciated!
SWP408 is offline   Reply With Quote
Old 08-19-2013, 11:05 AM   #2230
MWRX13
Member#: 330274
2013 WRX
Pearl
Default Fitment for 19x10.5
i'm running stock suspension. willing to roll fenders. they are work emotion +32 offset its a deal i cant pass up on. anyone have experience running 19s?
MWRX13 is offline   Reply With Quote
Old 08-19-2013, 06:15 PM   #2231
IrishC6
Member#: 345775
2011 Sti Hatch
Plasma Blue Pearl
I have a 2011 STI hatch, but fitment will be the same. I recently purchased a used set of Work 11r's in 18x9.5 +38 mm w/ Dunlop Z2 255/35's. I also have coilovers and adjustable control arms sitting in the garage. If I roll the rears could I get low enough to barely tuck the tire in the wheel well?
IrishC6 is offline   Reply With Quote
Old 08-19-2013, 08:54 PM   #2232
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
How low r u plus what do u have for camber correction.
Depending on those tires I'd say u r good for just a rear fender roll unless u r slammed then I'd say u would want some camber correction or some rear fender pull as well.
trev762 is offline   Reply With Quote
Old 08-20-2013, 01:49 AM   #2233
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
17x10 offset not sure.
I want custom made rpf1 in blanks can it be done? I laff now but hey beats buying works right now and in 18's. If its not poosible 17x9.5 offset +42 is what i guess ill stick w if i cant do x10. Probably need spacers and a bit of pull.
I heard this could cause wheel bearing failure?
Not looking for slammed/stance/tuck MOAR AGGRESSIVE!
JAMM0N is offline   Reply With Quote
Old 08-20-2013, 02:09 AM   #2234
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
With a +42 offset they shouldnt be to harsh on the wheel bearings but definately consider a jdm power steering cooler if not done so already
Old 08-20-2013, 08:28 AM   #2235
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
i cant find a power steering cooler anywhere for my car year. point me in the right direction. moar research but is it true? and is this the only way that will save my wheel bearings?
Old 08-20-2013, 09:19 AM   #2236
Mach V Dan
Member#: 12029
Please do not bump your posts. This thread gets plenty of traffic, so there's no need.
You're welcome.
Yes.
I think so, but it's been a long time ago.
I'm not sure. I don't show any record of us lowering the car.
No.
GRIP is not worse. But SHARPNESS of steering feel is worse when the tire is squishing around a lot.
Originally Posted by XsoberX View Post
So I'm looking at getting some wheels made...
Our Mach V Awesome wheels are 17x9 +42, and look like this:
Now, those two pics above are with 255/40R17. I don't have pic with 235/45R17 handy, but this is with 235/40R17 on our BRZ...
See pics of our white STI above.
Originally Posted by SWP408 View Post
Anyone have Rota g-forces in either 17" or 18" on a 11+ hatchback and stock suspension? If yes, can you share pictures and details on the tire and offset setup? Any rubbing problems?
The make/style of the wheel does not matter in terms of fitment. Find out the sizes this wheel comes in, and then ask fitment questions about size. This thread is not for comparing aesthetics. You can find pictures of those wheels on a car in other threads.
Most likely the exact size/offset/tire you are considering HAS been posted. Just not in that exact wheel style.
To reiterate, it doesn't matter if it's a Rota G-Force or an SSR MS-1, if it's the same offset and size, it fits the car the same.
19x10.5 +32?
You can pass up on. Do pass up on. It is far too wide to do anything useful with on your car.
There's pictures of my car on 19's on the VERY FIRST POST IN THIS THREAD. You're killing me here.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 08-20-2013, 09:24 AM   #2237
Mach V Dan
Member#: 12029
Please keep this thread on-topic. The topic is wheel fitment, not wheel shopping, wheel manufacturering, or...
Again, a topic that can be discussed elsewhere.
Please discuss in another thread.
--Dan
Mach V
FastWRX.com
Old 08-20-2013, 10:28 AM   #2238
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
got it sorry dan!
Old 08-20-2013, 10:52 AM   #2239
Tomekkplk
Member#: 358657
2013 WRX
Ice Silver Metallic
same^, rpf1's coming soon
Tomekkplk is offline   Reply With Quote
Old 08-20-2013, 10:58 AM   #2240
wrxscal412
Member#: 351604
2018 RS3
I am looking to run 19x9 +43 (smoking deal on a wheel set) on a 13 WRX hatch with stock suspension/stock brakes. I plan to roll the rears and hope that setup and offset would keep the tire fairly flush? Would anyone know if this setup would require spacers? Also on that same wheel what would most guys run for tire size (do not want to look stretched) assuming this is even a possible setup for this car? 265/35R19?? I want nice grip without a ton of change in the steering feel and dynamics.
wrxscal412 is offline   Reply With Quote
Old 08-20-2013, 11:39 AM   #2241
J_Maher_WRX
Member#: 290307
You can't run that size tire. Well you could, but the overall diameter of the 19" wheel with a 265/35 would almost a full inch larger than stock... Aka it would make your gearing even taller, have a BIG affect on your speedometer and actually make your car slower. You want a 265/30 if you want to run that 19" wheel, that will bring the overall diameter very close to stock and therefore should have no issues rubbing with that offset with a slight roll in the rear. And at that tire size the speedometer will have very little difference from stock. However, know that that tire is going to be very low profile and harsh riding.
Depending on what tire you choose as well will affect how well it fits on the wheel too as some tires are wider/narrower than others. A 265 Michelin Pilot Super Sport for example would probably look a little big for the wheel. I would recommend going with an 18" wheel with a 35series tire to give a little more comfortable ride. Especially with the stock rotors that are pitifully small to begin with :-/
J_Maher_WRX is offline   Reply With Quote
Old 08-20-2013, 11:50 AM   #2242
Kostya
Member#: 149658
2011 WRX 4dr
Have: oem 235/45r17 on stock rims (2011 wrx 4dr)
Want A: 235/40r17 stock rims
Want B: 245/40r17 stock rims
Will either A or B be fit fine? The car is stock right now, and will be for a while, just need new tires and want to get something good.
255/40r17 would be too much?
Kostya is offline   Reply With Quote
Old 08-20-2013, 02:21 PM   #2243
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
235/40 is a bit short, 255/40 will bulge
colin1234567 is offline   Reply With Quote
Old 08-20-2013, 02:51 PM   #2244
mugentheman215
Member#: 356317
Default Rota Grids
I was planning on running a set of Rota Grids 17x9 5x100 +42 with 245/40-17 tires on my 2013 WRX, from what I have read it looks like there should be no issues but mainly the tire size is what I was wondering about.
mugentheman215 is offline   Reply With Quote
Old 08-20-2013, 03:23 PM   #2245
Mach V Dan
Member#: 12029
Originally Posted by mugentheman215 View Post
...but mainly the tire size is what I was wondering about.
What exactly were you wondering about the tire size?
--Dan
Mach V
FastWRX.com
Old 08-20-2013, 03:49 PM   #2246
mugentheman215
Member#: 356317
Sorry to be more specific, was wondering if that tire size will work well with the wheels, also a confirmation that there should be no issues with that setup(rubbing, needing fenders rolled, etc).
Old 08-20-2013, 08:18 PM   #2247
Scnsaracer
Member#: 319511
2013 STI Sedan
Ice Silver Metallic
I don't see where this was answered so here goes. I have work emotions 18 9.5 38 with 265 35 mich pss. My rears are rolled and they clear fine so I would say a 255 tire should have plenty of space between the tire and fender they will tuck nicely after a roll. The front won't give you any issues unless you really slam it. My car has about 1 finger all around.
Scnsaracer is offline   Reply With Quote
Old 08-20-2013, 08:19 PM   #2248
Scnsaracer
Member#: 319511
2013 STI Sedan
Ice Silver Metallic
Old 08-20-2013, 10:42 PM   #2249
13whiteguywrx
Member#: 351622
2013 Wrx
XXR 527s 18x8.75 +35 running 245 40 18s
Stock suspension no rubbing no fender modifications
Excuse crappy cell photos
13whiteguywrx is offline   Reply With Quote
Old 08-21-2013, 08:38 PM   #2250
Mach V Dan
Member#: 12029
It should fit with no issues.
--Dan
Mach V
FastWRX.com
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
